Needacpowercable cord too loose
    Genius:
  • 1,003 Answers
Replace power supply or have a qualified service outlet replace the power connector.
Posted on Jan 21, 2013
My charger is loose so I need a USB charger where can I buy one
try amazon if you are looking for just the cord.
Nov 10, 2013 | Tablets & eReaders
Loose cord
Recoil spring may be getting old and stretching, but more than likely, your pull cord is old and it has become stretched. Try replacing pull cord first.
Apr 12, 2013 | Briggs & Stratton Garden
Power cord is shorting out
The cable guy may have bumped the power connector and loosened it. Try pushing it in firmly. Sometimes the power connections get loose over time
Oct 03, 2012 | Toshiba Televison & Video
Toro 6.5 recoil handle cord loose
yes you will need to remove the top cover to replace the starter cord
Apr 22, 2012 | Toro Garden
THE CHARGING CORD IS LOOSE ON THE GARMIN CONNECTOR PORT--IS THIS REPAIRABLE
Yes it is repairable. What need to be done is that you get the connector port replaced. It is quite technical, so with a technical hand, you will be able to do the job effectively. You get a replacement charging port, then you open up the device and replace the charging port.
Before you do that, try to use another charging cord to see if it will be loose, if it is not loose, try to replace your charging cord instead, but if it is loose, then you have to change the connection port of the gps.
Jan 05, 2011 | Garmin GPS
Hello heres my problem the power cord tip gets so hot and burns even ive replaced the battery ive replaced the cord and the tip and its stil happening help please
Seems that your notebook's power socket, where you plug the power cord, is damaged & is causing a loose connection. The loose connection causes the power socket as well as the power cord's tip to overheat & burn.
Oct 30, 2009 | Compaq Presario M2000 Notebook
The Radio always goes back to 9 all the time with out turning the truck off just all of a sudden it will go to nine, also i have to hold the mic with tension on the cord or it just gets right statticy,...
Sounds like you have a loose connection to power. Check your ground. It is probably loosing power and restarting on 9.
Its definitely that if it is the same power cord you are using.
Also, there could be a problem with the mic cord or jack.
Oct 13, 2009 | Cobra 18 WX ST 40-Channels Base CB Radio
Power cord is loose, power cuts off
If its the Auto wind cord then fault could bre internal contacts, not easy to get into suggest best to go to service centre.....
Oct 10, 2009 | Miele s558 Silver Moon Vacuum
DYSON DC04 how to remove switch housing to check
its most likely not the switch, check the power cord.. check where the cord meets to the vacuum. the cord could be going bad and most likely not a loose wire.
Sep 10, 2009 | Vacuums
Starter cord loose on Bolens 4.5 HP lawn mower
Need to remove the pull cord assembly. Something is amiss in there. If you don't want to attempt it, I'd take it to a shop.
May 12, 2009 | Garden
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
Electro Med Services...
