Question about Acer Aspire Computers & Internet
Headphone jack does not work - Aspire Acer Computers & Internet
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Acer Master
  • 1,001 Answers
Headphone is easy to pair to most Smart Phones and Bluetooth-enabled Tablet.You can wear the earphone while you're running or working out, and do not have to stick your iPhone in pocket.make you enjoy the exercise. Amazon com Charm sonic Bluetooth Headphones for Gym Runing Exercise Green...
Posted on Dec 14, 2016
  • Acer Master
  • 27,725 Answers
The headphone jack on the computer connects to the sound card, a hardware device that controls audio input and output on the PC. The card contains a digital-to-analog converter that converts analog audio into digital signals and visa-versa. The performance of the headphone jack, therefore, depends on how well the sound card functions; if the card doesn't work, then the headphones connected to the PC won't output sound. Reconfiguring the audio settings will often fix problems with audio output on the headphone jack, but if the former fails to resolve the issue, replacing the sound card in its entirety is sometimes the only means of repair.
Click "Start." Enter "sound" into the search box. Select "Sound" from beneath Control Panel. Double-click "Headphones." If no "Headphones" option is available, double-click "Speakers." Click "Properties" on the General tab. Check the Device Status field for errors. Look up the message on Microsoft Support for more assistance, if applicable. Close the window if the Device Status field reads "This Device Is Working Properly." Go to the "Levels" tab. Click the speaker button to unmute the volume if the icon contains a red circle-backslash symbol. Drag the top slider to the right to increase the headphone volume. Go to the "Enhancements" tab. Check "Disable all Sound Effects." Go to Applications, and then clear "Allow Applications to Take Exclusive Control of This Device." Click "OK" to close Headphones Properties or Speakers Properties. Test the audio. If the headphones fail to output sound, unplug the headphones from the computer. Reconnect the headphones to the PC. Headphone jacks are color-coded lime green on most PCs. Look for the headphones symbol if the jacks are not color-coded. Plug the headphones into the line-out port on the back of the computer if the headphone jack on the front of the PC fails to work, or visa-versa. Test the headphones. If headphones still won't emit sound, the sound card most likely requires replacement. b> Replacing the Sound Card b> Shut down the computer. Remove the power cord from the back of the PC. Disconnect the keyboard, mouse, monitor and all other peripheral devices. Loosen the screws found on the back of the case, then slide the cover panel off of the case. Touch the chassis to protect the hardware from electrostatic discharge, or ESD. Set the computer on its side. Locate the sound card found on the opposite of the audio jacks and loosen the screw that secures the card to the computer. If no expansion card is located opposite the jacks, the computer uses an integrated sound card which can't be removed. Remove the new audio card from its protective packaging. Line up the card with an available expansion slot on the motherboard, then push the card down into the slot to install the new audio jacks. Screw the card to the computer case. Reassemble the computer. Turn on the PC. Boot in to Windows and insert the CD that came with the new expansion card. Follow the onscreen instructions to install the sound card software to the computer. Plug the headphones into the new line-out jack. Hope this helps.
Posted on Jan 21, 2013
The speakers no long produce sound after using the headphone jack,,disconnected jack , still no sound
When you plug in the headphones, the jack itself routes the signal away from the speakers. When you unplug the headphones, the jack has contacts that close again, routing signal to the speakers. If the jack contacts are dirty, they won't close correctly. I suspect were you to clean the contacts, you'd solve the problem.
Feb 25, 2015 | RCA Rt2760 Home Theater Receiver
My headphone jack does not work, sound still comes out from the speaker when i plug head phone. please what should i do?
it shows that the headphone may gone bad, or the jack of your pc needs repair, check your headphone to some other computer if it ok then go for repair the jack from some qualified technician
Jan 11, 2013 | Computers & Internet
Headphone jack requires bending the headphone jack to a side to get stereo. this is the coby mp725 16 gig love the unit. got it as a gift. had to send my first unit in due to headphone jack not working....
This problem is common with a lot of MP3 players. It is caused by excessive movement of the headphone jack and causes the headphone jack has worked loose from the circuit board.
To fix this problem the MP3 player needs dismantling and the headphone jack needs resoldering onto the circuit board to get the headphone working properly.
Jun 30, 2011 | Coby MP725Digital Media Player
Aspire 3680 headphone jack recognizes any headphone plugged in but no sound from the headphone jack, the internal speakers work but not the headphone, running vista
check first you headphone jack speaker. if its working well, then the line from phone jack male to speaker continuity.
Apr 02, 2010 | Acer Aspire 3680 Laptop
Rear headphone jack is not working!
Go into the case and unplug the frount headphone jack to enable the rear, some motherboards are particular on this issue.
Apr 22, 2009 | E-Machines T2898 (764296109563) PC Desktop
Sound is working but internal speaker is not working
Connecting headphones to the system will disabled the internal speakers until the headphone jack is disconnected, at which such time the internal speakers should function again.
If you disconnect the headphones and the internal speakers are not re-activated, then there may be damaged to the microswitch in the jack. (Try rebooting after the headphones are disconnected too)
Mar 01, 2009 | Dell Latitude D410 Notebook
Toshiba A10 headphone jack problem
I think you are on the right track, if the headphone jack is worn and shorting out itll kill the speakers because it thinks headphones are plgged in, ebay would be a good start for parts, maybe even call toshiba and speak to their tech support.
Dec 13, 2008 | Toshiba Satelite A10 Notebook
My headphones won't work!
look at the headphone jack, if it has 3 band, it is a stereo jack. the computer is mono.
you need a 2 band jack.
if you look at the jack on the computer, you will see blue(left) and green (right). you canna try to use the green jack.
go to any electroic shop and get a stereo to mono converter.
Dec 05, 2008 | Sky Hawk Computers (PSR5601W-SL) ATX...
Headphone jack not working.
If you have a headphone jack at the front and the back, it may be a wire to the front panel is not connected properly on the Motherboard.
Aug 03, 2007 | RaidMax Samurai 908 Yellow Mid Tower ATX...
Button/Jack
Replace the player - there is no repair for this
Jul 02, 2007 | iLO (2 GB) MP3 Player
Computers & Internet Logo
122 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
