WONT PRINT
SOURCE: Service error 5100 on my canon Pixma mp110
just replaced the ink cartridges and reset the counters, evrth ok now :-)
SOURCE: canon pixma ip1300 initialisation problem
I have a canon ip 1300 produces an error(both LED's are alternately blinking one blink for the green led and 5 blink from the orange led) then it will produce an error 5600.
SOURCE: Canon Pixma iP2000 wont print black ink?
Canon IP 2000 / reset
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
SOURCE: Canon PIXMA IP3600 Service error 6C10, and doesnn't print at all
Try keeping the paper only in the bottom tray (there's a tray in the bottom) Try pulling any paper out of the top and just close that top tray. Open up the head so that u can see the ink cartridges and turn the printer on and off and maybe it will center itself again. If it's still not working (even if lights aren't red and print head wont align in the center) try manually moving the head back and forth like 18 times so you can lubricate that rail in the back that's holding it. After that, re-turn it off and on again.
