Question about Dometic Refrigerators
How to get it to go off and run on gas - Dometic Refrigerators
    New Friend:
  • 169 Answers
Turn the on / off button to on, then change the auto button to auto, it will choose between ac or gas, with a preference to ac.
Posted on Jan 22, 2013
Why won't it keep running?
some times gas tank vent gets clogged . Loosen gas cap and see if it stays running to verify clogged vent.
Ethanol gas can ruin the Seat or Needle valve in the carburetor. A result of that can be very slow flow of gas into the carb. So maybe you can run it for a while but then the Fuel bowl empties and engine dies. Wait a while and there is enough gas in Bowl to repeat running.
Jan 05, 2016 | Garden
Gas will not flow from tank to motor while running
Everybody had a crack at this problem, another thing would check is these engines sometimes have a primary fuel filter inside the tank itself. Drain the fuel and gently blow compressed air back through fuel line towards tank then rinse the tank out with fuel, refill and try run engine again
Aug 07, 2014 | Honda 8 HP Engine
Ran out of gas now wont start 2001 sebring?
I assume you put fuel in the tank. This car uses a small high pressure fuel pump to pump gas to the engine, this pump is located inside the fuel tank, the tiny pump depends on the gas it sits in for cooling and for lubrication, if you run out of gas you quickly damage the pump, in fact any time you run below 1/8 tank you cause it to run hot, so you might get away with running out of gas once or twice by you always run the risk of the pump freezing up from lack of lubrication and cooling when you run out of gas, which is what you have likely done.
Jun 07, 2012 | 2001 Chrysler Sebring
It runs like it is out of gas. i replaced the fuel pump and filter. all cylinders are firing. when running, runs like it is out of gas, then starts running fine, and when i give it a lil bit of gas, push...
You got fire and fuel .............. you may have water in your fuel system or your fuel injectors may be bad . Try some stp gas treatment before checking injectors .
Dec 29, 2010 | 1991 Chevrolet Cavalier
Is there any difference in bottle gas heater and natural gas heater
by bottle i am assuming you mean propane. yes there is a difference , natural gas is mostly methane gas (ch4) a very small molecule, propane is (c3h8) a much larger molecule. so they require different gas nozzles and cannot run a unit on the other fuel, some can be converted to run other gas. generally natural gas units are cheaper to run, but cost more for installation as a gas line has to be run to the unit and benefit of not running out of fuel. hope this helps.
Apr 23, 2010 | Pentair Minimax Ch 250,000 Btu Natural Gas...
Cougar runs like running out of gas or bad gas
REPLACE THE FUEL FILTER 1ST, THEN TEST THE FUEL PRESSURE AND SEE IF ITIS OK.
Aug 13, 2009 | 2002 Mercury Cougar
Weedeater lawn mower shuts off, but still has 3/4 tank of gas
On some mowers...if the gas cap vent is not working properly, it will run fine for about 15 or 20 minutes, start spitting and sputtering, if you loosen the cap, and let air back into the tank it starts running normally again.
Apr 05, 2009 | Garden
Gas dryer/will not heat
If when you run it you smell gas please stop running it!
You should shut the gas valve off immediately anyway!
If the gas heater isn't working when your running it it's probably the Valve that activates the gas (Selenoid) or the Ingnitor that lights it!
It could be the burner which distributes the gas in which case you would smell gas.
My best guess......the ignitor!
Jan 20, 2009 | Kenmore 73952 Gas Dryer
Gas dryer
If when you run it you smell gas stop running it!
You should shut the gas valve off immediately!
If the gas heater isn't working when your running it it's probably the Valve the activates the gas (Selenoid) or the Ingnitor that lights it!
Refrigerators Logo
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
