Question about Ovens
Bottom element the clip that slide onto the spade broke off.
Can any clip be use to replace the broken one off, or does it require a special clip?
the oven was build in august of 1975, i think it very hard to read the numbers on the unit, no glass on door,
  • 124 Answers
Since the element gets extremely hot when in operation, you need clips that are very heat resistant, which can be obtained from the Original Equipment Manufacturer. As far as the model number, it usually a plate that the on the surface that the oven door contacts. If you provide the model number, an owner's manual can be obtained.
Posted on Jan 27, 2009
Neff 1541 not heating with replacement element
Yes two red flecked on same terminal and the black flecked on the other side terminal of the element. Bobs your Uncle......HEAT! Make sure they are a tight fit. New spades if required.
Oct 03, 2017 | Neff Ovens
HOW TO REMOVE FAN FORCED ELEMENT
All I needed was a phillips screw driver, a small hex socket drive and an 8mm wrench.
1. Turn off the mains at the switch board. There might be a switch near the oven or stove too, turn that off as well. Check that the power is off!
2. Remove the screws holding the oven to the cupboards. Mine was held in by 4 timber screws on the edge.
3. Slide the oven out of the wall. I used a small table to support it.
4. Remove the hex drive screws that hold the top lid on.
5. Using a trusted multimeter CHECK THAT POWER IS OFF! There are now exposed power terminals.
6. Undo the supply power terminals and remove the cable. I taped mine up.
7. Remove the back cover - more hex screws.
8. Pull the spade terminals off the heater element.
8. Inside the oven remove the shelves and side racks. They pop off the wall.
9. Pull the rear fan shield towards you. It should pop out at the top and then lift off 2 small tabs.
10. Remove the phillips screw at the bottom of the heater element.
11. Remove the 2 spring clips.
12. The element can now slide down and towards you.
13. Replace the element and put it all back together in reverse order.
Oct 08, 2014 | Ovens
Oven will not heat
the bake element has failed. they can be had for around 20 dollars. Unplug unit before
replacing the element. Usually will only need 1/4 inch nut driver to remove two
screws inside oven and slide out element and unplug the spade connectors.
The model and serial should be located behind the lower drawer on the left side.
An appliance parts store should carry this in stock since many models utilize the
same element. Hope this helps.
Sep 25, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
The oven will not heat up. model # RF315PXEW serial # RG3219362 i was cleaning it and the top element( where the connector slides onto the element) touched the back of the stove and created a spark. i...
Test element for continuity first and if it has continuity you need to look elsewhere, possibly at they switch or thermostat as you said you shorted it out, let me know after you have done continuity and i will help you further if required, David "The Famous Forry"
Sep 30, 2017 | Whirlpool Ovens
How do i replace the heating element in a diplomat aca3200 oven?
make sure the oven is switched off.remove all trays etc from oven,remove 2 posidrive screws from bottom of fan plate,remove fan plate,the element is around the fan,remove 2 posi screws from where the element goes through the side of oven and the one screw that holds the top of the element to the back of the oven.slowly pull the element out and remove the 2 poz and neg spade connectors.refit as removed.
Dec 30, 2010 | Ovens
I have a Kenmore Elite stove and the broiler element will not heat up, the element it's self is okay
number 1 unplug unit inspect the outlet which element plugs into you will see prongs that clip onto element make sure there not burnt thoes prongs are in ceremic caseings make sure they not broken or chiped causing a bad connection i hope that helps
Apr 08, 2010 | Kenmore Ovens
Dual Oven - upper oven bake element replaced but no heat from it
Usually no internal fuses, and most of the time the controller is rated for fault interupt current.... age will degrade them though...
How did you change the element without pulling out the stove? is it a 'click/plug' in? might be that the socket is messed up...
You should not have to disassemble the cabinet, should just be a few screws and the unit slides out... sometimes hidden behind small movable pannels..
Peace
Feb 27, 2010 | Ovens
Hi i have a very old 1970? whirlpool electric single oven
It sounds like you burned out the oven heating element control board.
Jul 18, 2017 | Whirlpool Ovens
I need to replace my bake element on the bottom of the oven. I have removed the plate but do not know how the wires disconnect
they are just a push-on spade terminal,pull them off replace the element and carefully push-on the terminals to the element
Nov 18, 2009 | Whirlpool GSC278PJS Oven
Frigidaire GM deluxe electri dean (electric oven wall unit)
if you feel through the insulation you can find the two wires that attach to the element pull them through to plug the element back on but there is no plug per say but first are you sure the element is good were there no wires on the element when you removed it should have been two spade connectors with wires on them attached to the element hold my rating till you reply
Jan 11, 2008 | Frigidaire FEB27S5A Electric Single Oven
Ovens Logo
79 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
