Question about Garden
Biggs and stratton 12.5h,p.over heating
The engine is clean,however sit for awhile.
  • bud jackson Jan 23, 2013
    after mowing for awhile,about .5 acres gets extremely hot .
    Sergeant:
  • 322 Answers
Is there enough oil in it, the blower housing clean, and not running to fast?
Posted on Jan 23, 2013
2 Suggested Answers
  • 110 Answers
SOURCE: Briggs and stratton 6.5 Ohv dies after running for
This is a classic symptom of a blocked fuel cap vent. Next time it dies, remove the cap, wait 30 seconds or so (for carb to re-fill), then try to re-start. If it works, replace the cao.
Posted on Aug 08, 2010
How do you start a biggs stratton 450 series rotorvator
Usually the 450 series only a recoil starter....a pull rope to start it. Meaning you have to pull the starter rope to start it.
Apr 28, 2014 | Briggs & Stratton Garden
Briggs and Stratton 14.5 OHV 287707
You need pull spark plug so it can over. Let sit awhile be for trying to start.
Mar 10, 2014 | Garden
Sprint 40
Sprint 40 is a Biggs and Stratton engine.
Jun 27, 2013 | Garden
Tries to turn over then wont let it sit awhile then it starts
It could be starter heatsoak (starter gets hot from engine heat and needs to cool down first).
You can fix it by putting heat wrap on the starter.
Feb 27, 2013 | 2003 Kia Sorento
What do I need to troublshoot if my lawn mower want crank after sitting up for awhile
I assume you have checked to make sure you have spark at the plug. Just hold it against any metal surface to make sure you have good spark. Also you may have a carburator that is now gummed up. I would check that out, Also you could spray some start fluid into the carb or filter to see if it starts at all.
Aug 09, 2012 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Briggs and stratton 6.5 Ohv dies after running for about 10-15 minutes. I let it sit awhile then runs again. This is a vertical shaft lawnmower engine.
Aug 07, 2010 | Briggs & Stratton Garden
Changing oil in Biggs and Stratton engine
Use 10W30 weight oil. The capacity is 1.5 Quarts (48 ounces) with filter change. I highly recommend you use 100% synthetic oil in an air cooled engine. Change the oil and filter every 50 hours of use.
Apr 23, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Started briggs 15.5 hp engine. Ran for 5 minutes large plume of white smoke came from exhaust and now oil is dripping from exhaust pipe. clean air filter and has good oil level.
make sure you have the correct amount of oil in it and that its not overfull. after that replace the points and condenser underneath the flywheel that is underneath the shround on the top of the motor. make sure the points are gauged right. you can buy a manual for biggs and straton that will tell u what to gauge the points at. you will need "feeler gauges" to re-gauge the points. they are a little set of gauges that are really thin pieces of spring metal.
Dec 26, 2009 | Briggs & Stratton Garden
My Biggs and stratton446777 rockers dont move as it spins over
you my have a broken rod pull spark plugs out and see if pistons are moving,if so check for bent push rods,if push rods aren't bent then you may have bad cam
Apr 28, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
15 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
