Question about Stamina Products Stamina 1305 Indoor Cycle Exercise Bike
Left pedal keeps falling off - Stamina Products Stamina 1305 Indoor Cycle Exercise Bike
The left pedal keeps falling off. I use a wrench to reattach it and tighten it down, and then within five minutes of starting to use it, it starts to loosen and eventually (20 minutes or so) falls of
Try using "locktite" thread lock to help keep it from loosening. U can buy it at automotive or hardware stores.
Or use fingernail polish on the threads as a cheap substitute
Nov 22, 2014 | Nordic Track NordicTrack GX4.0 Recumbent...
I have replaced both my front brake pads and rotors, we have bled and rebled all the lines to make sure there wasn't any air in the lines by using a special tube thing to do this (sorry but I am not...
brakes can be a pain to fig out. first thing that pops in my mind is air in your lines. your van has ABS on it, you have to bleed your brakes a certain way. what im thanking is air in the ABS pump. alot of cars, you bleed your brakes RIGHT FRONT then LEFT REAR then LEFT FRONT then RIGHT REAR with ABS also the set up you are using to bleed your brakes if you dont use it right it will let air back in to your system. make shur your calpers arnt leaking
i hope this helps if not just let me know and i can give you some more tips
stockam auto
Jul 11, 2011 | 2005 Chrysler Town & Country
Left pedal on stepper falls to ground in workout
YOU MAYBE HAVING AN ISSUE WITH THE SPROCKETS THAT HOLD THE DRIVE CHAINS ON BOTH PEDALS. YOU CAN PURCHASE THEM SEPARATELY OR A COMPLETE HUB ASSEMBLY. TO REACH STAIRMASTER/NAUTILUS @ 1-800-864-1270
Feb 26, 2010 | Stairmaster 4600PT Stepper
88 dodge shadow idles very ruff. pedal to floor to start.
i have an 88 dodge shadow turbo with a five speed. the car will fall on its face at 5500rpm coming out of first gear. and its rpm range gets lover with each gear. the fuel pressure rises when it fall on its face. the car never dies just falls then picks back up and will fall again unless you keep it under the that rpm. then it is fine. what could be the problem?
Jul 17, 2009 | 1988 Dodge Shadow
Drive belt keep falling off
you have belt guides near your pulleys that helps to keep the belt on during no engagement
you need to check to see if they are missing or bent and adjust as close to the pulley and belt as possible without interfereing with the belt and pulleys while engaged.IE: no rubbing against the pulley or belt while engaged or moving.
May 31, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Stairmaster 4600pt pedal falls without warning
i have the stairmaster 4000pt which was bought new in 2003. in 2007, i started experiencing the same problem, the right pedal would sometime slip and fall to the floor. i called the local fitness store and they came and replaced the hub assembly and that resolved the problem until now. The left pedal is now slipping.
Apr 14, 2009 | Stairmaster 4600PT Stepper
Smart cycle pedal??
We had the same problem with the right pedal continually falling off. I purchased some "J.B. Weld" from Ace Hardware, applied it to the stud on the pedal, re-tightened it back on the sprocket arm and let it set 24 hours. This was over a month ago and it has not come off or loose. It gets peddled pretty furiously at times and still holds. The cost of the J.B. Weld which is in two small tubes, mixed together and applied is less than $7.00. I am once again my Grand-daughters hero....
Mar 06, 2009 | Toys
Bike pedal arm keeps falling off as i pedal.
You need a new crank arm. If you ride with the nut loosened what happens is the square part of the bottom bracket shaft wears the hole out in the aluminum crank and it no longer fits snugly no matter how much you tighten it down.
Mar 03, 2009 | Cycling
Engine stalls when stepping on gas pedal and will not idle on its own.
Have you checked the ignition timing? Maybe you need to turn the distributor to the left or right if you don't have the timing light gun
Oct 02, 2008 | 1990 Honda CRX
Stamina Products Stamina 1305 Indoor Cycle Exercise Bike Logo
26 people viewed this question
Top Stamina Products Exercise & Fitness Experts
Electro Med Services...
Tom Chichester
Are you a Stamina Products Exercise and Fitnes Expert? Answer questions, earn points and help others
