Question about Besta CD-27
Lcd screen no display
New battery use
  • 56 Answers
DOES IT HAVE A WAY TO PLUG IN AN EXTERNAL MONITOR IF NOT THAN I THINK LCD IS BROKEN, YOU CAN ALWAY TAKE IT TO A COMPUTER STORE THAT REPAIRS THEM AND SEE IF IT WORKS
CANDYMANGANDY
Posted on Jan 27, 2009
How to replace LCD screen
To replace the the LCD screen of your laptop, You need to be very careful in replacing this screen. Please kindly follow the steps below to be able to guide You in replacing the screen.
  1. Shut down the Acer laptop, unplug the AC power adapter and all extensive devices.
  2. Remove the battery pack from the battery tray that is at the bottom of the screen.
  3. Open the display panel as far as You can open it.
  4. Pry the rubber screw covers from the display panel's front cover with a small, flat-head screwdriver.
  5. The front panel is the front plastic piece covering the LCD screen.
  6. Remove the Phillips-head screws fastening the front cover to the display panel.
  7. Remove the front cover from the laptop with your fingers.
  8. Remove the Phillips-head screws from each side of the LCD screen that fasten the screen to its metal frame inside the display panel.
  9. Tilt the screen forward, then disconnect the large ribbon cable from the connector on the back side of the screen.
  10. Peel away any tape securing the cable in place. Lift the screen out of the display panel.
  11. Place the new screen inside the display panel.
  12. Reconnect the LCD ribbon cable to the back of the new screen.
  13. Align the screw holes on each side of the screen with the screw holes on the metal framing inside the display panel.
  14. Replace the LCD screen's retaining screws.
  15. Replace the display panel's front cover, and its retaining Phillips-head screws.
  16. Then replace the rubber screw covers.
  17. Replace the battery pack, then reconnect all cables and devices to the laptop.
That is how to replace the screen of your phone.
Hope this was helpful. Thank You for using FixYa!!
Jan 12, 2011 | Acer Extensa 5620 Notebook PC
Display screen unreadable. Removing battery
You have an (unfixable) LCD screen problem - the Liquid Crystal Display is dying (or broken by impact).
The best you can do (without a spare LCD screen and soldering/electronic repair skills) is hope that
there's a workaround that lets you use the phone without the LCD screen working.
Exploring a workaround: call the cordless from your cell phone, and see if you can answer by just using the keypad - if so, then the cordless works and it can be used until the whole phone dies (rather than just the LCD screen).
Most consumers just end up buying a new cordless about every year since these units take too much accidental abuse to last long.
If you decide to scrap the unit, save the battery for recycling at your nearest Home Depot.
They accept
old rechargeable batteries of any type - NiCad types used in cordless phones are especially toxic
(the (heavy metal) cadmium poisons spermatogenesis). Even better, save the battery for your
other GE 25932 5.8 GHz cordless phone - if you have a pair, then its mate's battery is old too.
Jan 02, 2011 | GE 25932 Cordless Phone
I have a Casio 1470 pathfinder watch. I did not use it for several years The batteries ran down, have replaced them and now have no display or functions
mcdevito75 here, I would see the jeweler who installed the new batteries and ask to have the battery install double checked so they are makeing proper contact with the LCD movement. In the meantime you can try to hold down the MODE button for a few seconds and see if the display appears, also if the display screen has turned very dark, your Casio may have had it, as the LCD display could have gone bad. New batteries should bring up a display even after the watch has been stored. Hopefully the display is still a grayish color and the new batteries need re-alignment.
Aug 11, 2010 | Casio Watches
New battery but lcd still no backlight
You probably have a bad inverter or backlight in the display. The inverter is what provides power for the light, and it's usually what goes bad. Replacements for most brands are available online from a number of sources. A Google search will usually turn up several, as well as detailed steps to change it if yours is a common brand. A computer service shop could give an estimate if you're not comfortable doing the repair yourself.
If the backlight itself is bad, that's much harder to change since it's built into the display panel. It's easiest to replace the display, but that can be a costly part. Most servicers won't try replacing the backlight because of the time involved. Again, get an estimate and then decide whether to fix it or replace it.
Hope this helps. Thanks for using Fixya!
Feb 19, 2010 | Computers & Internet
Dell Latitude D620 no display on main screen!!
If you have already replaced the LCD inverter cable and still the problem is there . You also told that the display is working fine when connected to the external monitor. This mean the Video controller on the motherboard is fine. This lead us to the conclusion that you would have replace the whole LCD assembly and not the inverter cable alone.
Thanks for using fixya
Proton
Aug 31, 2009 | Dell Latitude D620 Notebook
BLACK SCREEN WITH COLOURED LINES ON LG KF700. BATTERY WENT OFF, TURNED BACK ON AND HAD THIS PROBLEM.
Sounds like your lcd screen is damaged. Here is a link that shows how to replace the broken LCD Screen on the LG KF700. There are links to buy a new KF700 LCD screen
LG KF700 LCD Display Screen Replacement
Aug 26, 2009 | LG KF700 Triband 3G HSDPA 3MP A2DP Phone...
Samsung s860 digital camera turns on and then goes to blank screen and will do nothing else, to turn off it requires battery removal. same story with new batteries.
Dear customer
thanks for ur inquiry for ur product
If the LCD screen is blank or black when you have your camera in the Camera or Play mode, the camera may need service. To determine if this is the case, follow these steps:
1. Press the Menu button to see if the LCD screen can display the OSD (On Screen Display). 2. Set your camera to Play mode, and then see if the LCD screen displays a picture. 3. To eliminate the possibility of a user setting causing the problem, put the unit into Auto mode by rotating the dial on the units exterior to Auto Mode. Note: The word "Auto" appears on the screen when this mode is activated. 4. If putting the camera into Auto mode does not resolve the problem, test the unit in Play mode. If the unit operates normally in Play mode, but the screen in Camera mode is blank, your camera requires service which you can arrange by Creating a Service Ticket below. Note: Because your camera has an automatic LCD display shutdown feature, its normal for the LCD to stop displaying when the camera has been on for along period of time. This feature prolongs battery life.
urs sincerely
Harrish
Jul 10, 2008 | Samsung Cameras
Blank LCD screen on shooting mode, but does show settings. Will not take pictures. Replaying mode works, shows pictures taken before screen went blank. New batteries. What is going on??? Is it...
The Display button manually turns the LCD display on or off to save batteries. If you accidentally had turned the LCD off, It should only take one press of the button to turn it back on and leave it that way. As such, it's not you but the camera. The A570 IS is relatively new. Your camera is likely still under warranty. If so, contact Canon for warranty repair (see the following link):
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2113&fcategoryid=221&modelid=14905
Mar 15, 2008 | Canon PowerShot A570 IS Digital Camera
Dell C400 will not boot using LCD screen when cold
I have seen this problem before, after booting to the external monitor go into the display settings and try setting the resolution to 1024 X 768 and the color settng to 16 bit or preferably 32 bit. If you can do this, then shut down the laptop remove the external monitor and try booting on the LCD display. BPCS
Nov 17, 2007 | Dell Latitude C400 Notebook
Only displays white screen
Hi, Its a strip problem,when u change your mobile strip then screen willbe ok! By: M.Qasim Butt
Apr 13, 2007 | Motorola Mobility RAZR V3
Besta CD-27 Logo
202 people viewed this question
Top Besta Office Equipment & Supplies Experts
ray gallant
Are you a Besta Office Equipment and Supply Expert? Answer questions, earn points and help others
