Washcycle selector knob needs replaceing model whdsr316goww
  • Washing Mach... Master
  • 17,130 Answers
Please check for spares: Washing machine
Posted on Jan 22, 2013
3 Suggested Answers
ginko
  • 19396 Answers
SOURCE: GE WASHER MODEL NUMBER WHDSR316GOWW,
Here you find all parts for your appliance.
Click on the diagrams to get the exploded view.
Posted on Sep 02, 2008
  • 1937 Answers
SOURCE: I have a Kenmore washer model number: 110.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.+82427130&pathTaken=partSearch
Look at the section / diagram for the Console and you should see the part you need with the Sears part number and price:
The "Manufacturers Substitute" is a Whirlpool part number and you should be able to find one at a local appliance parts dealer.
If not, you can order one from Sears.
Posted on Apr 08, 2010
How to replace frigidaire gallery washer knob?
Good afternoon friend, that's a great question!
I understand that you are trying to replace the selector knob on your Frigidaire washer, GLTF2940E. Normally this is not a DIY job and we would recommend having a technician come out to the home in order to properly disassemble your front panel and replace the selector knob as needed. Hope this is helpful. -Matt
Jul 29, 2014 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Washer will not start
I know how frustrating it can be when appliances do not function properly.
This particular washer has a test that we can run to see any errors. This can be confusing on this model.
Activating the service diagnostic modes.
You can start with the cycle selector knob at any position.
  1. Be sure the washer is in standby mode (plugged in with all indicators off).
  2. Perform the following sequence of movement using the cycle selector knob. NOTE: After reset, sequence "a" through "e" must be completed within 6 seconds. When it tells you to rotate the cycle selector knob, it means 1 click, not a full turn. Once you have completed the cycle knob turns reset and "a" through "e", turn the cycle selector 1 click clockwise from the position it is already in. This is the fault code display mode. Then press the start button. Each time you turn the cycle selector knob 1 click clockwise after pressing start will show you an error code. Note: this washer stores 4 codes if any. The error codes on this washer are displayed in this format: F5 E3, F7 E1, etc...
If there are no error codes stored, you will need to replace the control board. Here is a link to the part.
Oct 17, 2012 | Whirlpool Washing Machines
Program selector knob continues to turn
COULD BE THE SPLINES ON THE SPINDLE PULL KNOB OF AND SEE IF CRACKED OR THE SPLINDES WORN ON INSIDE OF KNOB .IF OK THE SELECTOR NEEDS REPLACING.
HOPE THIS HELPS
NORMAN
Aug 23, 2011 | Indesit W 123 Front Load Washer
I have an older a/c model no. A494901 (?). The control knob broke off. Is it very hard to replace it with a new knob? And, where would I get a new knob? Thanks, -Fran O'Neill
Depending on your break is the stem leading from the settings selector switch still there or did it break to. If it broke as well you will need to replace both the selector switch and the knob. If not the knob can be obtained from your local Sears Repair Center.
Jul 05, 2011 | Kenmore Heating & Cooling
Viking Husqvarna Model 6020 stitch selector will not turn.
look at the cam gear. This is the unit that the cam connects to. It could have a crack or be split completely. If there is a crack the cam stack will have to be replaced. The parts are hard to get and a good technician is needed.
Apr 23, 2010 | Husqvarna Viking 1
How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Apr 22, 2008 | Whirlpool LTE6234D Top Load Stacked...
MIELE DISHWASHER NEEDS A NEW KNOB
give me a couple of days and ill get back to you on that one.
do you need a part number for the knob?
Feb 18, 2008 | Dishwashers
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
