Question about Sharp VC-H973U VHS VCR
Sharp VC-H973U suddenly unable to play/record tapes
My Sharp VCH973U just started not being able to play tapes. When I insert one, it takes it in readily, but when I press 'play' it makes a grinding sound, runs a few seconds, then stops (it doesn't spit the tape out). When I do eject the tape, though the tape isn't mangled or broken, it won't quite let it go - like it's caught around a spindle. What I like best about this unit is that I can program timed recordings from the front panel without having to use the remote (in case that breaks and is irreplaceable). Any solutions? Is it something I can fix myself? Is it worth taking to a shop to repair? Or should I just scrap it?
  • Sharp Master
  • 5,126 Answers
With these things it's best to see what is going on to see if it can be fixed. So what I suggest you do is take the top cover off and using an old tape which you don't mind getting mangled insert it and watch where it gets tangled up. Without looking into it you can't determine what's faulty.
Posted on Jan 27, 2013
2 Suggested Answers
mybradley7
  • 242 Answers
SOURCE: vc-a573u (a) stop working
clean the heads.
Posted on Jul 16, 2010
How can I get my tape to eject?Sharp VC-A560. Played my taped, rewound, but tape would not eject. Tried to play again and it would not play.What can I do?
Unplug from wall outlet - find the wheel that ejects the tape when you slowly turn it. It's usually on the right side when the cover is open. Avoid touching any metal parts.
Mar 01, 2015 | Sharp VC-A560U VHS VCR
Sound and just a Static picture when playing a VCR tape on a Sharp 13vt-N100
More likely a damaged tape got inserted, if the video heads get blocked or even partly blocked every tape after will do this, heads can be cleaned manually (careful if not sure how to do it) or a cleaning tape MAY clear this up or not.
Oct 15, 2012 | Sharp 13VT-N100 Combo
Want to record VHS to DVD on my Toshiba DVR620KU but do not want to connect to my TV set. Is this possible? My TV is older and does not have the input/output jacks. I just want to put in a VHS tape and a...
If the entire VHS is full then you can easily transfer the VHS contents to the DVD. The video will play while it is recording onto the DVD, but you don't have to have it hooked up to any TV for it to record. Now if you don't know how long the VHS content is that you want to record to DVD, then you will have to hook up the player to a TV so that you can press stop when you reach the end of the content you want recorded. At least this is true in the way that I use to transfer VHS to DVD:
1) Turn on the unit
2) Insert VHS tape
3) Insert DVD-+R or DVD-+ RW
4) Using remote, press VCR
5)Using remote, press play then pause the tape where you want to start recording.
6)Using remote, press DVD
7) Using the remote, press DUBBING. The VHS should start to play and the DVD should start recording
When using this method, don't hit the RECORD button!
I hope this helps!
Sep 05, 2011 | Toshiba DVR620 DVD Recorder/VCR
When I push play there are lines and rolling and I can not control with tracking .
Always best to see if a good clean will do the trick. You can do this yourself better than a cleaning tape, but you can try one if you don't like the idea of messing with the VCR yourself. If you want to do the work, then get some Servisol Video 40 (you can find it on-line). Take the top cover off the VCR - disconect from the mains first. Then spray the servisol where the tape touches, especially the tape heads. If you don't know what to spray then after you take off the top of the VCR insert a tape and press play and watch where the tape touches. Remove tape turn off power and spray. You can use a cotton bud in the tricky areas too. Allow to dry and try a tape. You might have to do the clean again depending how dirty the VCR was. If the VCR lives in a smoke filled room that will make more work to clean it.
If it still doesn't stop rolling then you might have got a head fault.
Aug 20, 2011 | GE VG2040 VCR
Hello, I have a JVC GR-DV800U and when I insert a tape that has recorded footage on it and press play it just gives me the blue screen with the date and time all flashing slashes. It does play tapes...
This is usually caused by an oxidized, misaligned or defective Audio/Video drum. You can try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be serviced by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair cost low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Aug 13, 2011 | JVC Video Cameras
There is a "key" on
Sounds like you have put a child lock on it. If you don't have the manual to remove it, then visit the Sharp website, they might have a PDF free of it, or should help otherwise.
Jun 24, 2011 | Sharp VC-H973U VHS VCR
I need instruction to set recording for sharp h952 vcr
You need remote to get menu to set the clock then go to timed recording setting. Then you load a new tape, then shut down the vcr and wait for the timer to start the vcr and recording for you.
If you need a manual, google for sharp vcr manual download free from sharp website.
Aug 26, 2010 | Sharp VC-H952U VHS VCR
My aiwa vdeo cassette recorder which spits tapes all the time
I would go to wallmart and buy a vcr head cleaner read the instrutions on it and see if that fixis the problem ...
May 29, 2010 | Sharp VC-H973U VHS VCR
Televison & Video Logo
60 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
