Question about Lello Kitchen Appliances - Others
Need source for replacing shaft that turns the mixing paddles
    Champion:
  • 287 Answers
Once again, eBay! You can replace just about every part for them.
Posted on Apr 25, 2014
Why do all functions work but the mixture is not mixing?
Check to be sure the mixing paddle is properly affixed to the mixing post.
If the motor is turming and the mixing paddle is properly seated on the post inside the mixing bowl but it still does not turn, be sure the post can turn freely and is ont stuck in place. You may need to replace the mixing bowl.
If the motor is not turning you will probably need to seek out a repair service.
Mar 03, 2015 | Kitchen Appliances - Others
Tip
Bringing and blending aplliances
Generally, a blade or grinding or blending/mixing part that is permanently attached to a metal shaft from the appliance motor is held on that shaft by a 'shear pin'. This pin breaks when something is put in the appliance that the grinder, mixer, blender can't gring, mix, or blend. This is to protect the motor from overload. Afterwards, The motor will continue to turn, but the blade or paddle, or whatever will not turn.
The shear pin needs to be replaced.
The shear pin passes through one side of the base of the bade/grinder/paddle assembly, through the motor shaft, and out the other side of the blade/grinder/paddle.
The piece of the pin must be removed from the shaft, and from the two sides of the blending/grinding part. This is generally a press-fit, and some effort may be required to accomplish this.
When the pieces have been removed, a common 'roll pin' of the appropriate diameter should be inserted to hol the turning part on the shaft. It must fit tightly, and some effort should be required to insert the new pin. // '); }// ]]> Back to Edit // '); }// ]]> Publish preview_graphic.jpg
on Feb 07, 2010 | Food Processors
Tip
Grinding and blending appliances
on Feb 07, 2010 | Coffee Makers & Espresso Machines
Mixing paddle slips off pin
We have never heard of this problem before. I spoke with our KitchenAid technician as well and he has never seen this problem in the over 20 years of working on KitchenAid mixers.
Are you sure that the beater is hooked on all of the way, and there isn't anything in the beater stopping it from turning and clicking into place? Is the pin stuck? If the pin is not sticking out all of the way, or the spring is bad/damanged it is possible the beater could come loose. You would want to replace the agitator shaft.
Agitator Shaft: http://www.mendingshed.com/kacentershaft.html
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Apr 03, 2013 | KitchenAid K45SS Classic Stand Mixer
Mixing paddles come off during mixing, am using teflon tape on shaft to hold paddles on, what is a better fix?
Sound like you need new shafts or paddles and I know the paddles can cost $30 each. so think about a new model or buy one at a thrift store and try those paddle or use the machine. I got a great one for $10 . :)
Jul 30, 2017 | Black & Decker B2300 Bread Machine
Tip
Failure of grinding, blending, or mixing kitchen appliances
on Feb 07, 2010 | Blenders
The machine gets warm but the paddle doesn't turn.
Hi, The paddle should turn freely by hand with the bread pan out of the machine. Make sure the pan is inserted in the machine correctly. If the motor shaft turns but the paddle doesn't then the sealed bearing that the paddle rotates on has failed and is frozen so the paddle does not turn.. You may need a new bread pan. Hank
Jul 01, 2010 | Kenmore KTR2205SPR Bread Maker
Panasonic SD-250 not mixing. Pan was submerged in water.
Hello LT,
There is a sealed bearing and shaft on the bottom of the bread pan that the paddle sits on. Submerging the whole pan in water may have caused water to seep into the bearing on the bottom of the pan, or the whole pan might be worn. Slight resistant in 2 places on 360 degree is not bad. Let everything dry out and we will try a few things. First, put the paddle in the empty pan and place it in the machine. Start a kneading cycle and look trough the lid to see if the paddle is spinning freely and with smooth motion 360 degrees. Watch it until you are sure it will run freely for the entire cycle. If it does not run freely, stop the machine and take the pan out. Now start the kneading cycle again with the pan out and look at the motor shaft at the bottom of the machine to see it it is running freely. If it is running freely, then the problem is with the pan, and the pan needs replacement. If the motor shaft is not turning freely, then the belt is slipping in the machine and needs to be replaced. If everything runs smoothly check the kneading time to make sure your mix has enough time to knead correctly. Hank
Nov 14, 2009 | Panasonic Kitchen Appliances - Others
The paddle will not stay on the shaft while mixing dough.
Probably the paddle and shaft are worn. Both are replaceable. Buy a new Paddle and a Kneader mounting shaft unit (Part No. ADA 29A115)
Panasonic Parts
National Parts Center at 800-332-5368 between the hours of 9:00 a.m. and 8:00 p.m. EST Monday through Friday.
Nov 16, 2008 | Panasonic SD-YD250 Bread Maker
Kitchen Appliances - Others Logo
71 people viewed this question
Top Lello Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Lello Kitchen Appliances - Other Expert? Answer questions, earn points and help others
