Question about Intermatic Hardware & Accessories
I need replacement timer motors for T 103 Intermatic timers.Where can I order them from?
Intermatic part numbers are WG 733-1 and WG 430-3
  • Intermatic Master
  • 5,245 Answers
1) Copy fo0llowing links:
http://waterheatertimer.org/How-to-replace-Intermatic-clock-motor.html#clock
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#Hz
2) The suffix, -1 and -3 are not important.
3) WG733 is 208-277 Volt clock motor, normally found on sprinkler timer or T1900 series. WG430 is 120Volt clock motor normally found on T1400 series.
4) T103 timer is stock 120Volts, but can be changed into different voltage timer by changing clock motor.
Posted on Jan 22, 2013
  • 94 Answers
SOURCE: INstruction manual needed Intermatic HB800RCL
To download the file you need Acrobat reader 7 at least. I just tried it and I was able to get it. It was slow but got it. Go for it and hop this was helpful!
Posted on Aug 23, 2009
SOURCE: how to replace clock in intermatic timer
I need to replace the timer on a model #ML600TW
Posted on Oct 19, 2009
  • 41 Answers
SOURCE: how can in connect the timer intermatic T 103
nuetrals go under the same terminal, power in goes on the LINE terminal, power out goes on the LOAD terminal, pull out disk gently and set to time of day and release back in, set on/off settings and turn on power. make sure the manual leaver is on the OFF position for timing mode to work.
Posted on Dec 02, 2009
gotgeek2
  • 565 Answers
SOURCE: Replacement of on/off trippers for intermatic low voltage timers
These should work:
http://www.nextag.com/timer-trippers/shop-html
Posted on Jan 02, 2010
SOURCE: How do I wire an
The T-103 has a 120Volt clock motor
From there, the wiring can go two directions depending on your Load voltage (load is the fan, light or motor that timer turns on-off)
Here is a link that shows exact wiring:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T103
When wiring the T-103, steps 1-2-3 are true for 120V or 240V installation:
1) A white Neutral wire is always connected to terminal A (Neutral wire connects to Neutral busbar in breaker box)
2) A black Hot wire is always connected to terminal 1 >> this hot wire can come from 120V or 240V breaker
3) Black wire going to Load (fan, light, motor) is always connected to terminal 2
The following step is true for 120V Load
4) if Load is 120V, then white wire from Load connects to terminal A
The following steps are true for 240V Load
5) Only the neutral wire connects to terminal A as described in (1
6) The second Black hot from breaker box (240V has 2 hot wires) connects to terminal 3
7) The second White going to Load connects to terminal 4
Here are 2 more links that show how 120V and 240V circuits are wired
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/B220C.html
Posted on Oct 22, 2010
I have an intermatic model t106m pool timer switch that has stopped keeping the time. I have checked the breakers and find nothing tripped. The swith can still be manually turned on and off. Please...
Open following link for T106 240volt troubleshoot and repair steps.
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
Timer is probably repairable if manual override clicks crisp and clean and load turns on-off.
If the timer dial is not rotating or not on time, then replace clock motor. WG number is printed on clock motor.
If dial is rotating on time, then replace 156T1978A trippers.
Jul 03, 2011 | Solar Intermatic Single Pole Model Ej341c...
I have WG 1573-10D motor in my timer and it is connected to electrical transformer. I replaced the motor and the timer doesn't work. What current operates this motor?
208-277 Volt 40 amp 5HP at 240Volt
http://www.grainger.com/Grainger/INTERMATIC-Time-Clock-Motor-1PNK2?Pid=search
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t104%20-%20english.ashx
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 09, 2011 | Hardware & Accessories
Trippers on paragon 4003 are broken
Paragon 4003 uses x2772 tripper
http://waterheatertimer.org/Paragon-timers-and-manuals.html
1) As of November 2010 or before, Paragon is no longer making timers or parts except defrost timers.
4003 is not defrost timer.
2) Do google search for x2772 tripper.
I have seen x2772 tripper selling for more than a new Intermatic timer.
3) Intermatic has cross reference if you want to buy new timer:
http://www.intermatic.com/customer%20service/competitive%20cross%20reference.aspx
For example 4003-00 crossover to Intermatic is T-103
Grainger sells T-103 for $70
4) For T-103 wiring:
5) Add a comment with specific model number if you want more help finding replacement timer, or need crossover wiring.
6) Add a comment for more free help.
For a price, fixya expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 11, 2011 | Hardware & Accessories
Hello I need to replace a paragon model 4003-0 can you tell me what is compatable to this model? thanks maury
As you probably know, Paragon is no longer making timers and parts except defrost timers.
4003-00 is not a defrost timer
4003-00 is DPST 120Volt timer 24-hour mechanical timer
Paragon timers and manuals
Intermatic cross reference shows that T-103 is replacement for 4003-00
T-103 has 120Volt clock motor and can control 1 or 2 - 120V loads or 1 - 240Volt load
Dec 29, 2010 | Paragon GENERIC REPLACMENT MECHANISM 110V...
Need manual to set timer
You posted under T-100 series outdoor timer
If you have different timer, add a comment with timer model number located inside cover.
T-104, T-103, T-101 timer manuals show on following page:
If your timer has R suffix, like T-101R, that means box is Raintight for outdoor use.
T-101R and T-101 mechanisms are identical except for box. T-101 box is indoor use.
Click model number and drop-down menu reveals link to manual
http://www.intermatic.com/products/timers/mechanical%20time%20switches/24%20hour%20dial.aspx
If you need simple wiring diagrams, and explanation for each T-104, T-103, T-101 timer:
Here's how to set Intermatic T100 series timers:
Lift and rotate yellow dial until current time lines up with silver pointer.
Silver pointer is stationary at 6 o'clock position.
Put ON-OFF trippers on dial at times you want ON OFF functions.
Minimum on-off is 1 hour because of tripper width.
If timer is not working, add a comment and we'll troubleshoot.
These timers have replacement trippers and clock motors at Grainger
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
How timer works:
Clock motor, located on back of mechanism, rotates yellow dial.
Trippers on dial push lever that turns power ON and OFF.
Off tripper pushes lever one direction.
ON tripper pushes lever opposite direction.
When lever is pushed, manual override lever clicks back and forth with audible click sound.
Nov 29, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Intermatic T101R turns off automatically, but does not turn on automatically again when "On" pin rotates through to the set time. "On" pin is screwed on tight and I verified it is the...
If timer has been working fine up until now, you probably need a new tripper pin
http://www.grainger.com/Grainger/INTERMATIC-Timer-Tripper-2E054?Pid=search
If lever is worn out, then you need new timer.
You can but a T-101 and swap insides without changing box
The T-103 will also work because it has a 120V clock motor
The T-104 is a 240V timer and will not work
You can buy the replacement timer mechanism and swap out
http://www.grainger.com/Grainger/INTERMATIC-5225438-2E021?Pid=search
http://www.grainger.com/Grainger/INTERMATIC-24-Hour-Dial-Timer-Mechanism-2E354?Pid=search
http://www.lowes.com/T-103
When wiring new timer, put wires back the same as old timer
For T101 and T-103 wiring schematic, see following link
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Oct 28, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Replacing timer motor
T-104 has 240Volt clock motor
WH-40 water heater timer has same 240Volt clock motor
T-101 has 120Volt clock motor
T-100 series 120Volt and 240Volt clock motors sell at Grainger for $16
See large image of clock motor on back of Intermatic timer
http://waterheatertimer.org/images/Back-of-T-104-800.jpg
To replace clock motor you need 6-sided star-screwdriver from auto parts store or hardware
You may also need tweezers or magnetic screwdriver if tiny screws fall down behind timer when replacing
Steps:
Order 120 or 240 volt clock motor
Turn off power to timer
Remove plastic cover over screw terminals
Take photo of wiring or make a drawing
Note exactly which terminals the clock wires connect to
Clock motor wires can connect to either terminal, there is not a plus or minus wire to clock
Loosen screws on front of timer to remove white-colored clock motor wires
Push the spring retainer located inside box at top ... this will release timer mechanism from box
Tip timer out and then lift up to release timer
Replace clock motor that is held by 2 screws
Keep clock wires away from other timer parts on back of timer
Snap timer back into box
Re-attach wires to terminals just like they were before
Tighten screws very tight against copper wires
Turn on power
Check that dial is rotating as time passes
See more
Oct 17, 2010 | Intermatic T-104R3 220v timer in a rain...
Hello i have an intermatic model #t104r 208-277 volt my problem is that it works manually but it doesnt work automatically? whats wrong?
If you can also manually turn the dial so that the load turns ON and OFF, then the timer motor is bad :-( Replacements are available here for about $30:
http://www.aplussupply.com/intermatic/timer.htm
Scroll down to "WG 1573", Timer motor 208-277"
Dec 10, 2009 | Intermatic T104R 208-277Volt 40-amp Timer...
Hardware & Accessories Logo
212 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Hippy_dd
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
