Question about As Seen On TV Clapper Plus
Clapper goes off every few minutes with no stimulus to do so
I clap the thing on (it's set on "away" as the other setting is less sensitive) and just a few minutes later---3 to 5 minutes?---the thing goes off by itself! Also, will not clap off at all! :>(
suzanne.
  • Jacy Perry May 11, 2010
    I'd like to try to help. I know nothing about this though. So if it is a monitor (like a baby one) it could get interference from something else like baby monitors and r/c cars do. If not it could be a wire in it. Hopefully I could help a little if not sorry. Best of luck.
While in the Away setting, the clapper will turn on when it detects any noise over a specific threshold. After ten minutes of inactivity, it will turn off. This setting is meant as way turn on the lights as soon as you walk in the door or to startle might be intruders. If you slide the switch to Lo or Hi mode, the clapper will respond to your claps or any loud noises that sound similar. Hi is high sensitivity, for quieter rooms; Lo is low sensitivity, for louder areas.
Posted on Apr 01, 2009
What's clapper
Urban Dictionary: clapper
www.urbandictionary.com/define.php?term=clapper
Urban DictionaryA stripper who is able to make her behind shake so vigorously that the cheeks clap, or the behind that claps.
Clapper: For Your Car - Curbed LAla.curbed.com/archives/2011/01/parking.phpCurbedJan 24, 2011 - Shoppers who have lost track of their vehicle amid a maze of concrete ... What Really Happened at Rustic Canyon's Rumored N Ranch?"The Clapper" for your car - Honda-Techhonda-tech.com/audio-security.../%22-clapper%22-your-car-1068326/... Send a message via AIM to VAAJ. Default Re: "The Clapper" for your car (PHiZ) ... I like the idea... What is the US dollar for that? AU $99.00. Bbasso is offline ...Emoji Quiz Clapper board, Blue car, Oncoming car, Red car ...
Dec 08, 2015 | Cars & Trucks
2002 honda accord, alarm goes off after about ten minutes when I lock doors from inside with the power locks. I don't have a FOB for the car just the key, any reason why this is happening?
If you lock the car from outside with the key does it happen? If still goes off recomend replace alarm, if not alarm not reading doors locked from auto door locking system
Apr 05, 2015 | 2002 Honda Accord
I plugged a heating system into my clapper and now it is not working. The lights on the clapper don't go on when I clap. I think it glitches out but don't know how to fix it and now I'm really upset. What...
Clappers are only designed to manage less than 500 watts. Heaters are typically much more...greater than 900 watts. You likely burned it out and will need to send it in for replacement. good luck
Feb 01, 2015 | Miscellaneous
The cursor jumps around when I'm typing -- for example when I'm typing, it will just click itself up a few lines and start typing in the middle of another word
The touch pad can cause this problem. Go to control panel to make it less sensitive. I often drag a finger by accident over the pad and away goes the cursor. It is a major grump of mine also.
This web site shows the details, if you need them, to adjust the touch pad. http://www.ehow.com/how_2292964_adjust-vista-laptop-touchpad-settings.html
I do this for fun, so 4 thumbs if it answers your question.
Sep 25, 2010 | Dell Inspiron 1525 Notebook
Clicking from motor at start up. Goes away after a few minutes
I would bet money on sticky lifters .,why not put an oil flush through the motor ad with new oil and filter see if it goes away that is what i would do -----"yuodoit"
Sep 11, 2009 | 2005 Chevrolet Corvette
I'm having trouble setting the timing belt back to its setting.Can you give me more less an idea of how it has to be done? Thanks,Maritza
Very sensitive set up.There are special tools needed that make things much easier on the 3.0 liter.If you miss time it you can bend valves & due major damage to valves & heads.Best advise I can give from afar is get yourself a good haynes manual.They are not bad if you have done a few of them & have the special tools.hope this helps
May 20, 2009 | 2003 Saturn L-Series
Does not work
open it up. Insert an ear plug into the hole for the Mic. I got mine to respond to the distinct claps and not be confused by the noise caused by women's shoes forexample... The Radio control works by HOLDING the button for 1 sec not more. Test it with any LAMP.
Dec 27, 2008 | As Seen On TV Clapper Plus
Clapper plus
Sliding the switch down to the HOME (LO) position will put the Clapper Plus into the low sensitivity mode. This is helpful if there is a lot of external noise in the room. By placing the switch in the HOME (HI) position it will put the Clapper Plus into the high sensitivity mode for quiet clappers or if you are far away from the Clapper. In the AWAY mode appliances will turn on with the detection of any sound but will only stay on for 10 minutes.
Dec 06, 2008 | As Seen On TV Clapper Plus
Blue color spread over the pictures
This sounds classic to a thermo problem where a part(s) are becoming thermo sensitive with aga and use. When the set is cold and then warmed up, the defective part(s) is changing characteristics.
Some components became thermo sensitive that are driving the display. Or an embeded component in the display itself became thermo sensitive. It is very possible that the fault is on the board that does the X - Y addressing or on the backplane electronics of the display screen itself.
Using the set with defective components is a bad idea. If the part(s) fail completely and go shorted or opened, other more costly damage can be done.
The service rep for the manufacture of your set is equiped and trained to be able to troubleshoot and service your set.
You will have to take the set in to have it serviced.
Jerry G.
Apr 17, 2008 | Vizio GV46L 46 in. LCD Television
As Seen On TV Clapper Plus Logo
375 people viewed this question
Top As Seen On TV Toys Experts
Andrew Taylor
Andrew Taylor
Are you an As Seen On TV Toy Expert? Answer questions, earn points and help others
