Question about Nespresso Le Cube
Not enough water running when making coffe
The amount of water / coffee is extremely little. Hardly any water going through when making coffee
  • 38 Answers
Is the water ending up in the tray?
Posted on Jan 21, 2013
My keurig B40 coffee maker just pure out water hardly any coffee. It makes it taste like a weak coffee even when it's should be strong. It was blocked and we try vinegar but that wasn't the problem. We...
Look at the top needle, there should be a rubber like seal that sits around its base. This seals the needle so all the water with pressure goes the the cup. If the seals not there, it can't build the water pressure necessary to go through the coffee inside the cup, thus coming out around needle and out around cup, making it mostly water in your coffe cup.
Mar 03, 2011 | Keurig Elite B40 Coffee Maker
How to clean the coffee pot
mix half white vinegar and water together...then pour this solution in just as you would if you were making coffe....minus the coffe grounds of course... then run it through a cycle and then run clear water through again... and you will be good to go...do this once a month or so to keep it working great...
heatman101
Aug 25, 2010 | Bunn 10 Cup Home Coffee Brewer
Very little water comes through...small drips...enough to get the grounds wet but not enough to make coffee.
heatman101
Aug 22, 2010 | Krups Small Appliances Espresso Machine
Machine does not make enough coffee
There is a dial in front panel to controle water amount. Because one time brewing coffee powder amount is measured at the same colume, if dial is at the left side machine understands as to make very strong espresso and amont is only small, is center up side is mideum amont is a half of a cup, right side end is light coffe but enough amount for a coffee cup.
May 23, 2010 | Saeco Vienna De Luxe Espresso Machine
My coffee machine is flashing
That means that you need to clean it...
heatman101
Apr 26, 2010 | Keurig B50 Coffee Maker
The brew unit is not tamping the ground coffe properly.
Give the brew unit a good wash,then lube all the moving parts with food grade grease.
If you are able dismantle the brew unit and wash in warm soapy water,this removes coffee and any old lubricant.
Feb 21, 2010 | Gaggia Titanium Espresso Machine
To much water/coffe comes into a cup it was ok before.
Have you checked the grind and or the level selector on the amount of coffee going into the chamber to make an espresso.
Mar 17, 2009 | Coffee Makers & Espresso Machines
Not getting all the water
Faulty check valve inside the tubing at the bottom of the unit. This is the tubing conveying water from the outlet of the tank into the heater coil prior to going into the coffe basket.
I have the same problem but cannot find replacement check valve.
Feb 16, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Keurig Special Edition B60
I assume your coffe maker used to produce more coffee for each use. Roughly 6 ounces per large cup, and now is only making 3 oz. cups.
If your coffee maker is sputtering and not able to "suck" enough water to fill your cups of coffee it is most likely due to cavitation caused in the little pump due to a stoppage, which is most likely lime or scale buildup somewhere in the pump line.
To fix it, don't take your coffee maker apart. Get a bottle of distilled white vinegar, and pour it straight into the empty water resevoir. Press brew with no coffee pod so you are just running the vinegar through the system. Pour the vinegar out of the cup and back into the resevoir. Add some ice to cool it off. Repeat about 10 times. This should clear out the toughest lime scale clog.
After you notice the cups are filling full of water, Replace the vinegar with fresh water. Run about 5 or 6 cups of fresh water through the system to get rid of the vinegar.
Make coffee/tea/whatever.
Jade
Oct 06, 2007 | Keurig Special Edition B60 Coffee Maker
Nespresso Le Cube Logo
285 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
