Question about Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100, Doesn't Boot Up, Display Lights Up "!, 2 3"
OK, here's my sob story. Last week my Dell Dimension 5100 started running hot, so I popped the cover off and cleaned out the dust - looked like hair it was so thick.
Anyway, after putting the cooling fan & shroud and the heat sink assembly back on, I fired it up and....nothing. I got a little green '2' and '3' on the display. I went back in and looked close, and there were splotches of reddish brown, dried goo on the board, the video card, the ribbon cables - it seemed to be everywhere.
Well I know I didn't pour Ragu Sauce in my computer, so I did some research and discovered Dell had a big problem with capacitors popping. I looked close, but saw no blown out tops, although it did look as if one short, stubby black and gold cap had been leaking.
Instead of trying to piece meal a fix, I bought a new motherboard off the 'Net - I got it in today.
I put it in, as per Dell instructions from their 5100 manual, and all I got was a steady amber light where the power button was.
Frustrated, I took it out and tried to clean off all the rest of the red/brown gunk. It was even up as high as the ribbon cables going into the back of the DVD and CD drives.
I then decided to test it with as few peripherals as possible, so I hooked it up with JUST the power cable from the power supply to the mobo, the hard drive cables to the mobo (the fatter 4 wired one that ends in a white square plug and the flat blue thin one).
That was it. No modem card plugged in, no flash drive ports plugged in, no CD or DVD drives plugged in.
And lo and behold I am NOW getting three green lights on the display. A 1,2 and 3 and what looks like a symbol for a hard drive (little drum or can looking dude).
Now this is with the NEW motherboard. For giggles I put the old one back in with the same minimal setup and pretty close to the same thing happened.
Maybe I am wrong, but there is only two things I can think of that could be bad.
Either the processor is gone to ****, or the power supply is screwing iwth the board and chip.
Has ANYONE had this problem before? I'd like some input before I replace every component on the damn thing or shoot it - which ever comes first.
Help!!
  • Roy Lonsinger
    Roy Lonsinger May 11, 2010
    I had the same problem with my Dell 510, interchangeable parts. After 3 motherboards, 2 power supplies, 2 video cards, & new RAM dell still didn't know what was wrong. They refused an exchange as my system was 2 days past warranty so what I did was buy a barebones kit with the same chipset motherboard. Scavanged my RAM, optical & hdd's, cpu, video card, & power supply & installed them in the barebones. Cost for the kit was $179 which included case & mb. Also had to buy the full version of Windows Vista as the Dell windows disc is coded to their system only. Not saying you have to do this but it might be something to think about if your Dell is past warranty.
    Novelist:
    Scholar:
  • 72 Answers
2 green lights usually indicate a memory problem, however, when you get 3 lights, RAM is good, but the BIOS is unable to hand off to the operating system.
To test this, disconnect your hard drive (both ribbon and power) and connect the monitor. See if you get a display. If you get a display, try carefully reseating the cables to the hard drive and also to the motherboard.
If you lose the display again, disconnect the hard drive and connect your DVD/CD and put in a Windows or diagnostic CD to see if it will boot.
If it does, you have a bad hard drive.
Let me know if this helps or you have other questions.
Honest1abe
Posted on Jan 27, 2009
Windows XP freezes half way through Restore program?
Select an earler restore point. If it still doesn't work step back earlier. Somewhere in the restore date history there has to have been a date where the system worked. Remember that the restore process can take some time if a lot of material has to be restored
Oct 26, 2012 | Dell Dimension 5100 (D51L1) PC Desktop
Hi, I have a dell dimension 5100. I inserted a 1gb ram but it was the wrong one. I took it out and replaced it with the old ones. Now the computer doesn't boot properly - turns on but doesn't load...
Remove all the memories and insert them again, make sure you insert them in the proper way as the slot is keyed.
Memory issues can be identified by the beep sounds.
If you have more than one memory, remove one and insert only one of them and try to boot.
Hope this will help.
Aug 19, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
Can't boot up Dell 5100 Dimension, amber light flashes
When you mean the amber light, is that the blinking hard drive access light or the power light? Different cases have different colors on it. Mine has blue and green lights.
If you see the boot screen (bios) and then after it goes to boot, does it blink and hang?
This could be a simple operating system issue, hard drive or hardware/motherboard issue. If you could provide more information, that would help.
Jun 28, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Desktop Dimension 5100 is not booting up
please check first your bios settings.. its could be on the boot up settings. you must configure it out correctly..
May 11, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 9200 keeps shutting down and won't start up
the key issue on the uncommanded shutdown is the POWER LED. If upon shutdown, the power LED Flashes AMBER, then the power supply is suspect.
If no flashing amber indication, then the next think I check is the heatsink (Processor overheating) remove, clean and apply arctic Silver heat transfer paste, see if the issuje goes away
Last but not least if the system is failing to boot, and displays a 3 4 diag LED code, then you may have a RAM module that is bad or may just need reseating. Running diags off of the Rersoujrce CD is something to look at too
Mar 28, 2009 | Dell Dimension 9200 PC Desktop
Change bios to read from cdrom instead of h/drive
Ok, to get into the bios you need to hit F2 when the computer first starts up, when in the bios change boot order to CD drive, save settings and exit, the computer will reboot and you should be able to boot from CD. Any probz post back
kind regards and please don't forget to rate us
Dec 09, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 won't start with new FireMV 2400 PCI Express video card
Did you check to make sure the video card is installed in the right spot? Has the onboard video card been disabled in Windows - and when you say it will not boot, do you mean physically no POST. Do you get any error codes? If you can get into the CMOS (Bios) Setup screen - change the primary display adapter from the onboard to AGP, PCI, or PCI-E depending on which card that is. Use this information at your own risk - hope it helps.
Aug 05, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
5100 problem
Hi
To help you troubleshoot a problem, your computer has four diagnostic lights labeled "1," "2," "3," and "4" on the front panel. When the computer starts normally, the lights flash. After the computer starts, all four lights display solid green. If the computer malfunctions, the color and sequence of the lights identify the problem.
Reply with the Power Button light and the Diagnostic lights color and sequence for further assistance.
Advanced Troubleshooting and Owner's Manual
Mike
May 30, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 Won't start up
Hi
First disconnecting the power cord and re-seat all connections (Keyboard, Mouse espercially). Connect up the power cord and try powering the PC.
To help you troubleshoot a problem, Dell Dimension 5100 has four diagnostic lights labeled "1," "2," "3," and "4" on the front panel. When the computer starts normally, the lights flash. After the computer starts, all four lights display solid green. If the computer malfunctions, the color and sequence of the lights identify the problem.
If the computer failed to start up check the diagnostic lights color and sequence and Check the link below for more info (Assuming you have another system that can access internet)
http://support.dell.com/support/edocs/systems/dim5100/en/sm/tshoot1.htm#wp1120147
Alternatively, contact Dell Support with the diagnostic lights color and sequence to raise a service call if the system if under warranty.
Mike
Mar 31, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 (D51L1) PC Desktop Logo
556 people viewed this question
Alun Cox
