Question about LG DLEX7177 Dryer
No steam in LG DLEX7177WM
The orange steam valve in my electric LG DLEX7177WM dribbles water, with no steam being produced. Can this be cleaned or replaced? It appears that water is dribbling from the lower aspect (7 o'clock position) of the valve with no steam actually emanating from the spout.
  • Allan C Jan 23, 2013
    Make/Model: LG DLEX7177WM Steam Dryer, Ultra Capacity, Stainless Steel Drum, Quiet Operation. I'm fairly handy: is the Thermal Fuse generally easy to replace/access? Is there any online repair schema or manual that shows a visual of the area/part?
  • Allan C Jan 24, 2013
    I was reviewing the Service Manual for this issue; there is a part K-410 for the Drum Assembly that shows the steam valve in question. How is this accessed to evaluate the parts for functionality? I don't think the Thermal fuse is the problem. It feels like something is obstructing steam/water flow through the steam valve.
5 Suggested Answers
KevinWhite
  • 1902 Answers
SOURCE: Electric LG DLEX2801W (steam dryer) not heating.
Hello & Welcome to FixYa
If you have already cleaned the vent then the problem is with the Thermal fuse. When the thermal fuse goes bad it cannot be reset and replacing it is recommended repair. It is located on the blower wheel housing inside the rear panel to the exhaust duct. You can test it for continuity before replacing. Please get back to me if you have any other questions.
Kevin
Posted on Dec 12, 2011
  • 615 Answers
SOURCE: My LG front loading dryer doesn't dry well
Check the exhaust vent when running and be sure there is a good flow of air. You may have to clean the exhaust pipes all the way through. Dryers require a good flow of air for proper operation.
Posted on Jan 10, 2012
richroth
  • 9472 Answers
SOURCE: Lg true steam heats up but won't steam
What is the make and model number of your unit?
Posted on Nov 06, 2012
Water is running out of the vent hose in back of the unit.
If I have to guess it may have been some time since this unit has been serviced and cleaned out. I have a feaing there is lent stuck in the vent which is getting wet from the exchust, then draining.
Dec 03, 2015 | LG DLEX7177WM SteamDryer Front Load...
Delonghi stiromeglio master steamer iron , why no steam to the iron?
If you have been using tap water it may be plugged up with minerals.
Sep 13, 2014 | Coffee Makers & Espresso Machines
How do you change the thermostat
https://www.youtube.com/watch?v=nYua4dRsdeI
Jul 30, 2014 | LG DLEX7177WM SteamDryer Front Load...
Drum doesn spin
If this product is new, you will need to take out the carriage bolts located in the back of the machine.
Carriage bolts are meant for the shipping process to prevent the drum from moving while in transit. Most manufacturers use between 2-4.
Check your product manual for details on the removal of the carriage bolts
Jan 23, 2014 | LG DLEX7177WM SteamDryer Front Load...
Lg steam washer 2yo 3 yrs old . Refresh cycle produces bribble of water rather than steam and leaves clothes wet
The steamer unit may be overfilling. Check the water valve and see if it leaking. If it's ok, you will need to replace the steamer unit. Good luck
Jun 17, 2011 | LG F1402FDS6 Front Load Washer
Water is leaking into the drip tray.
Clean the chamber below the white plastic valve, there is also a small discharge that leads from there into the drain tray clean that hole also.
Second the thermostat that controls the steam may be damaged or the cpu board, the contact the controls the steam may be damaged, i have seen both of those happen on some units.
Oct 10, 2009 | Saeco Vienna SuperAutomatica Coffee...
Steam gauge is broken and iron will not produce steam
http://www.fixitclub.com/Parts_Components/Appliance_Controls.shtml click the link  Maintenance and repair tools you'll need to fix an electric iron include these:
  • Screwdrivers
  • Toothpicks or pipe cleaners
  • Sewing needle
  • Commercial electric iron cleaning solution or vinegar and water
  • Commercial soleplate cleaner or baking soda and water
  • Steel wool
  • Emery cloth
  • Metal cooking pot
you will need a speacial tool screw driver  also called as g5 screw driver to open it.available at local repair store. If the iron doesn't heat, make sure power is on to the outlet, check the electrical cord, and check the thermostat (see the Appliance Controls Fix-It Guide) and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat (see the Appliance Controls Fix-It Guide).
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Mar 26, 2009 | Rowenta Irons
LG DLEX7177 Dryer Logo
114 people viewed this question
Top LG Dryers Experts
Tim Whalen
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
