Question about St. Thomas Creations Neo-Venetian II Elongated Toilet by
Tank refill sound - St. Thomas Creations Neo-Venetian II Elongated Toilet by
  • 979 Answers
The diaphragm is worn out in the valve assembly. Replace it and that should do it.
Posted on Jan 30, 2013
  • Eileen M Olmstead Feb 22, 2013
    I checked the diaphragm and it was fine except for a small bubble in the rubber. I just stuck a needle in it and popped it. Now it's working fine as the bubble kept the diaphragm from closing all the way down. Easy fix!
Richmond 40 gal water heater from 2003 gurgles loudly when refilling, is that normal
I'm not sure what you mean by "gurgles when refilling." If you mean that it is making noise when heating the water, that is usually a sign that sediment has built up in the bottom of the tank. This results in the surface of the tank bottom to overheat and the sound you hear is the water flashing to steam. This usually results in tank failure as the glass lining will crack an the tank will rust out. If it's not too late you could drain and flush the tank to try to remove the sediment but if has hardened to a solid mass it won't come out.
Sep 14, 2016 | Rheem Richmond 40 Gal Nat Gas 6 Year Power...
Water in tank continuously slowly flows out. No flapper but a central tower.
What ever functions as a flapper is defective and needs to be replaced.
Nov 10, 2014 | Home
Water Ridge dual flush toilet issue!!
Of course ALL the DIY centers (Lowes, Home Depot, Ace Hardware, Do-It-Best, etc.) sell toilet repair kits. Sounds like you need a flapper replaced in your toilet. Search online for toilet flapper replacement to get guide on DIY.
Nov 10, 2014 | Home
I have to keep refilling radaitor tank every two days
sounds like you have a coolant leak or your heads havent been done right or there maybe a crack in the head which has not been found.
Jul 06, 2010 | 2001 Chevrolet Malibu
Says "Used ink tank full". Light blinks and won't print. No idea how to empty.
It sounds like you refiled an empty ink tank. The printer will refuse to accept ink cartridges that have been used and refilled. Unfortunately there is only one easy option: Buy a new cartridge. If it is a new cartridge and has not been refilled (straight out of the box), contact the supplier (where you got the cartridge from).
Good Luck!
Jun 20, 2010 | Canon i860 InkJet Photo Printer
My dual flush toilet fills up slowly how do i fix
Lift the tank lid off, place it somewhere safe for a moment, and look at what happens: If you're talking about jiggling the handle to get the tank to start to fill with water, then it sounds like the chain or rope is out of adjustment. It can't be TOO TIGHT or the water will leak past your flapper (will cause your dripping noise, tank water level will leak down, causing constant refills), and it cant be TOO LOOSE or the toilet won't flush correctly. Since you didn't mention trouble flushing the toilet, I think that it may be a little too TIGHT. When you jiggle the flush lever-it is supposed to pull a chain or cable to open the flapper at the bottom of the tank. Flush the tank and watch what happens-all the way through to refilling the tank with water and shutting off the water refill valve-Does the flapper get stuck on the chain or something? It is supposed to fall back down to allow the tank to refill after flushing out your toilet. Does the chain look very loose? The dripping sound you described indicates that the flapper is not sealing 100%. The flapper is very easy to replace, you just have to get the adjustment set for when you flush the toilet how sensitive you need it. You amy have to play with it a little bit before you get the adjustment correct.
Hope this helps!
Nov 08, 2009 | Home
When flushed the tank refills and the float goes up.... after about 5 mintues of quiet, there is a "shhhhh" refill sound..and bubles inthe water from the main pump. how do I fix this? 6 LPT and 1.6 gpf
Adjust the water level in the tank to the water level line in the tank. If the water is spilling into the open tube in the center of the tank, that will cause the water to run.
If water is not seeping into the tube, then maybe water is leaking through the rubber stopper and into the tank. You will have to replace that rubber stopper
Oct 23, 2009 | Eljer Toilet Onepiece Canterbury ...
After flushing, water does not refill the tank.
yeah sounds as though the ball valve or water inlet valve is stuck in the closed position or jammed so when you flush the loo the water doesnt refill.
Isolate water service remove valve as required clean/replace re instate test & leave working
Dec 15, 2008 | Toto Carlyle 1-piece Elongated Bowl Toilet
Refilling ink tank
please donot use refilling system it is not for printer
it is new catridge after finishing you can refil for once dont use more times
it depends upon refilling-the quantity-before refilling you should clean with boiling water and then start refilling-if you shake the hands it ink will come out nozziles then use if not see the contacts of the catriges-if not just replace new catridge
Dec 28, 2007 | Canon PIXMA MP530 All-In-One InkJet...
St. Thomas Creations Neo-Venetian II Elongated Toilet by Logo
63 people viewed this question
Top St. Thomas Creations Home Experts
john h
Tom Chichester
Are you a St. Thomas Creations Home Expert? Answer questions, earn points and help others
