Question about Kodak ESP Office Equipment & Supplies
How do I remove the ink cartridge
I have a new Kodak ESP12 printer , I have set it up but it tells me that all is finished but when I try to print it says there is no printer installed , also how do I remove the ink cartridge
Go to start menu, right-click computer, click manage, on the left double click device manager, when the menu is populated look for other devices, you should see your printer. double-click it. a menu will pop up, click the tab labelled driver, then click update driver, click the option that lets windows search for solutions/drivers online. this will find and install the drivers automatically the way windows knows best, this should fix the printer not detected issue and the printer should be ready for use. that is given that you have the latest kodak software installed on your computer. for some reason there is a compatability issue with windows 7. its the kodak software not windows 7. im looking for a way to report the issue to kodak now, hopefully they can resolve this issue to eliminate all this trouble. took me all night to troubleshoot my printer only to find that kodak hadnt corrected the issue on their end. I LOVE WINDOWS 7 :) hope i helped
Posted on Jan 21, 2013
SOURCE: Printer not printing black ink
The problem you are all having is with the print head (The black tray that your ink cartridges sit in).
Most of the time a simple cleaning of this will correct the problem, if it does not then you will have to call Kodak support and they will send you out another print head.
But lets try and see if we can get your troubled one to work again by following these steps...
1 - turn printer on and open the lid as if you were going to change the printer ink cartridges.
2- when the ink tray moves into the center and stops, remove both the black and color cartrdiges from the print head.
3- To remove the print head simply place your left thumb inside the head all the way to the left facing up and pinch the upper left lip of the print head to release it, then pull the entire tray out with your other hand ( there is a release inside the tray above the sticker of a finger and bullseye to the far left in the upper left corner inside the tray)
4- With the tray now removed be sure to look at the bottom and you most likely will find a build-up of black ink... clean this off using DRY paper towel as much as you can.
I used rubbing alcohol but if you do this make SURE it is completely dry before reinstalling.
5- Once you have cleaned the print head reinstall it in reverse fashion than you removed it, if you installed it right you will hear a solid CLICK noise.
6- replace the ink cartridges you removed if they still have ink in them and then close the printer lid.
7- You may get a notice that there is a new printer head and or cartridges and it will want to align and or calibrate the printer...be sure to do this!
8- Once the printer is recalibrated hit the menu tab on the printer and choose " clean ink head"... Do a deep cleaning 2 times!
9- Now try to print something that contains something black like a text document. If it works you are all set, if it did not then you will need a new print head from kodak. simply explain that you did the above steps and it did not work so that you can avoid support trying to run you through all this. They will send you a new one in 2 days.
Hope this helps and good luck!
Posted on Sep 04, 2008
SOURCE: CanonPIXMA iP90 Color Ink Tank installation problem
can anyone tell me what to do
Posted on Sep 24, 2008
  • 76 Answers
yeah it sounds like a cartridge sensors are stuck or broken. i would say to replace the whole print unit. It will need a service support dealer to fit this part unless you can buy it and fir it yourself.
part number: QM2-2020-020
hope this helps
Posted on Oct 24, 2008
  • 326 Answers
SOURCE: new ink cartridge but not printing green on esp 5 kodak all inone
you need to use the head cleaning tool in the printer properties, youll need to keep running it untill it runs clear and it uses alot of your ink while it does it.
youll find the cleaning option if you go to your
start/settings/printers and faxes, right click on your printer and go to printer preferences then maintinence
Posted on May 08, 2009
  • 20 Answers
SOURCE: New cartridge installed printer gives message that
Check both cartridges, one might still have plastic film that needs removal.
Posted on Dec 17, 2009
Can i print using black ink when im out of color ink it wont let me even though ive changed the settings to print colors as black and white
That's the way Kodak works
It won't allow yu to do anything if any of the lights are flashing or there is a error message
NO RESOLUTION
Get your color ink cartridge replaced by Kodak.
Just say its a new color ink cartridge and printer is saying its empty!!
Hurraay you'll get a free color ink cartridge
Jan 25, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Not printing in color and black/white copy not clear, light in some places
Dear sir
good day
to fix up such problem
Clean the printhead, then print and
  1. Verify that inkjet paper is loaded in the paper trays.
  2. On your desktop, start the KODAK All-in-One Home Center, then select the Help [?] icon.
  3. From the Help menu, select Maintenance, then select Printhead Cleaning. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows a steady green, press Photo + Copy simultaneously to print a demo sheet
and you have to Replace ink cartridges.
IMPORTANT: Make sure you are using KODAK Ink Cartridges. Your KODAK All-in-One Printer is designed to work with KODAK Ink Cartridges. Kodak is not responsible for the compatibility or performance of either non-Kodak brand ink cartridges or refilled ink cartridges. To purchase KODAK Ink Cartridges, go to KODAK Ink Cartridges & Photo Value Packs.
  1. Lift the printer access door, then remove the ink cartridges from the printhead.
  2. Insert new KODAK ink cartridges into the printhead, then press down firmly until you hear the cartridges click into position.
  3. Close the printer access door, then make the same print.
and you can point to the website below for further information
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=5224/6198
thanks
Dec 18, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
I just installed a new color cartridge in my 8650 Lexmark printer. The ink cartridge acts as if it is empty. Printer keeps telling me to align cargridge. Worked perfectly before the new ink installed. Not...
  1. On your computer, go to "Start," "Programs," "Lexmark Series." Click "Lexmark Control Program."
  2. Step 2 Select the "Cartridges" tab. Click "Change Cartridges." The Change Cartridges screen appears, displaying the animated instructions for installing or changing cartridges. When you have finished viewing the animation, click the "Finished" button.
  3. Step 3 Remove the tape covering the print head of the new print cartridge. Insert the new print cartridge as shown in the animation.
  4. Step 4 When the "Choose Cartridges" screen appears, select the cartridge(s) you installed in your printer from the list boxes. Click the appropriate box to reset the ink levels to full. Click "OK."
  5. Step 5 The Automatic Alignment screen appears. Click "Align" to align the print cartridges for best print quality. The printer prints a page with a bi-directional alignment pattern. On the printed test page, locate the number that comes closest to forming a straight line under the bi-directional alignment pattern. Enter that number as the bi-directional alignment setting in the Alignment Cartridge dialog box. Click "OK."
Nov 25, 2009 | Lexmark All-in-One Printer with PictBridge
Not recognizing brand-new ink cartridges
Check if:
* There was a ink leak from previous cartridges? If so, use a cotton cloth and alcohol to clean the cartridge connectors in the printer itself, not the cartridge. It will be a dirty job, don't touch your face or clothes while doing this because someone will think you a re playing "commando". [water may work but can damage it]
* Did you update the drivers for the printer? Check for new device drivers at the kodak website.
* Also, check the plastic seal of the cartridge as completely removed.
I didn't want to mention this, but you are experiencing a common failure of this kind of printers. If nothing of above works, that means the flat cable connected to the cartridges inside the printer may be broken. A technician may need to look at it, but it will be kinda expensive. Sorry pdxredhead.
Aug 29, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak 5100 black will not print
In the UK call 0870 2430270
Tell them, because they will ask you to:
You have removed and reseated Black Cartridge
Carried Out Printhead Cleaning
Carried Out Calibration Test, and Black is missing
Did a Test Print (Press Photo & Copy together) and NO BLACK
and they will send a New Print Cradle overnight.
I also complained about wasting ink on multiple tests and got a new pack of ink as well.
Dec 07, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Jun 25, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
5100 ink error
Both printer ligh flash red yet both cartridges are new and full.
I have removed printer head and swiched of printer for 15min as suggested by Kodak but the red light still flash.
Please can you help.
Kind Regards - Patrick
Mar 03, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak 5300 color ink error
OK so i found some new information that should solve the problem. The version of firmware you originally had on the printer when you changed the ink cartridge was bad. There is a known issue that when you put in a new ink cartridge when the printer is in the error state "COLOR INK CARTRIDGE2.gif EMPTY. REPLACE COLOR INK CARTRIDGE" the unit writes that value to the new ink cartridge so you will continue to have that error. So to fix your problem First Remove the ink cartridges and download and install the new Firmware. Then sadly you have to go get another new ink tank and install it.
If you can get through to kodak you should request reimburstment of some sort like a free set of ink tanks.
Jan 10, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
23 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
