Question about Saws
My ryobi BTS10 won't start.
I was just given a Ryobi BTS10 10 inch table saw. I got it home and plugged it in and no go. No sounds from the motor, nothing. Anyone know if there is a fuse, or an easy fix to this problem?
  • 885 Answers
The Ryobi does have an overload protector (PN 452110003) inside the switch box. It should be resettable from a small hole to the right of the switch on the front of the cabinet. If not, you may have to go into the switch box to check it out/reset it. If the overload protector is OK, I'd check the condition of brushes and brush springs next.
Posted on Jan 21, 2013
  • 86 Answers
SOURCE: ryobi bt 3000 table saw belt installation diagram
The BT3000 actually has TWO v-belts! Here's a link at the end of this solution to an exploded diagram. Basically you have a major disassembly, but it really isnt that complicated.
More great info on the BT3000 is available from the web site http://bt3000.com/
I have a BT3100 saw, and it is a good tool, but does require attention in maintenance procedures, but Ryobi did outline the necessary steps in their manuals. The above website also has the owner manual if you need one.
  1. Unplug saw
  2. Remove the blade
  3. Lower mechanism all the way to the bottom
  4. Flip over saw and lay on it's top
  5. Remove the blade guard panel opposite the motor
  6. Unbolt the motor assembly and remove the belt cover
  7. Replace the broken belts
  8. Re-assemble (be careful not to cross-thread the bolts in the aluminum housings!)
http://bt3000.com/Manuals/BT3000-Parts-Manual.pdf
Posted on Mar 22, 2009
SOURCE: table saw starts slow and the stops
Sounds like the run capacitor has given up. Or, maybe the worst is it overheated and burned the motor winding. You'll probably have to take it apart. If there is a smoked capacitor, that's probably the one you should replace. If the winding is scorched, might as well get a new motor. If both are the case, then replace the capacitor before you give up on the winding.
Posted on Apr 21, 2009
SOURCE: How do I change the blade on my Ryobi 10" table saw?
The manual is posted on line. Changing the blade does not require turning the saw over, blocks of wood or vice grips. The advice listed above is potentially damaging to your equipment.
http://www.raygirling.com/ryobi/ryobi.htm#settadj
Posted on Sep 24, 2009
  • 8404 Answers
SOURCE: Ryobi 10 in Portable Table Saw modl #BTS12S won't turn on
Look for a trip switch on the saw motor
Posted on Nov 02, 2009
SOURCE: i am replacing power switch on ryobi table saw BTS20R
Hi, I have got a Ryobi ETS-1525SC Table Saw. Suddently it stop and as far as I can see the machine is ok but the blad is not moving. Could some one help please
Posted on Dec 16, 2009
How do you replace a broken bevel locking lever on a Ryobi RTS10 table saw?
buy the part and fit it or take it for repair.
parts
Ryobi RTS10 10 Table Saw Parts
parts, better schematic
Ryobi RTS10
your saw
RYOBI Tools
service centres
RYOBI Tools
Jun 04, 2017 | Ryobi Saws
My Ryobi table saw won't start, any ideas?
There is an overload protection breaker on the bottom left. Check it and the power switch with a meter to make sure they work.
Sep 29, 2015 | Ryobi Bts10 Table Saws
Ryobi 10 inch table saw trips breaker when he turns onRyobi 10 inch table saw trips breaker when you can it on
First of all the saw needs to be plugged in directly to a outlet . NO Extension CORD !!! If it is Right , then Check on the motor label and see how many AMPS the motor is ? You need to then check the Breaker box and make sure the breaker is big enough to handle the load of the motor on the saw . You may have to make sure that the saw is the only thing on that breaker . NO Refrigerator , A/C , ECT.
Also make sure that the motor is clean and not packed full of saw dust . This can over heat the motor and kick off circuit breaker fast .
Good Luck , Hope This Helps !!!!!!!!!!!!!!
Aug 22, 2014 | Saws
Replacing the brushes in the RTS10 10 inch Ryobi table saw
Take right side panel off (right as looking at front of table saw). Side panel will be held in place with 8 small Phillips screws. Take flat screwdriver and unscrew round brush holder on either side of
motor. Brushes are held in place with springs and fastener. Flick small fastener with fingernail and fastener and spring should pop out. Pull out fastener/spring/brushes(all one piece). Replace with new brushes (about $8/piece on ebay).
Mar 18, 2014 | Ryobi 10 in. 15 Amp Table Saw RTS10
The motor run for only 5 seconds
Maybe you have a worn out brass, take out the motor and check it
Mar 16, 2013 | Ryobi Bts10 Table Saws
Nov 02, 2009 | Saws
Table saw starts slow and the stops
Apr 21, 2009 | Saws
Saws Logo
640 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
