Question about Fisher Paykel WA42T26GW1 Laundry : Top Load Washers
Need to reset machine size per service manual instructions. Replaced burnt motor control module. Now getting error code?
Fisher seems to have the service manual under lock and key. Power utility spike burned out components on control module. Replaced module now seems to work fine until pressing the start button. Then starts continuous series of beeps and lights the wash progressLEDs for error code 9. Entering diagnostic mode results in no progress LEDs lit.
  • Greg Stephen
    Greg Stephen Feb 08, 2013
    I have uploaded a picture for re-sizing your machine
  • Fisher Paykel Expert
  • 554 Answers
To re- your machine,
Posted on Feb 07, 2013
Testimonial: "This is the correct answer. I did finally get the full service manual from Fisher & Paykel, and this matches. My machine is the 7 or 7.5Kg version."
Fisher Paykel GWL11- US Washer
- Motor control module fault:
Fisher and Paykel washing machine error 1:
Primary Source: Motor control module.
Action: Replace motor control module.
3 - Motor control module fault:
Fisher and Paykel washing machine error 3:
9 - Size setting fault:
Fisher and Paykel washing machine error 9:
Action: Reset machine size as per service manual instructions. If fault repeats replace Motor control module.
10 - Temperature Sensor (Thermistor) Error:
Fisher and Paykel washing machine error 10:
Primary Source: Thermistor.
Action: Replace Thermistor.
11 - Pressure Sensor Fault:
Fisher and Paykel washing machine error 11:
Primary Source: Pressure Tube.
Action: 1 - Empty all water from the machine. Remove pressure tube from pressure sensor, clear pressure tube of any water and reconnect tube (blow down the tube is necessary). 2 - If fault repeats, replace Motor Control Module.
12 - Flood Protection Error:
Fisher and Paykel washing machine error 12:
Primary Source: Water Valves.
Action: If the water valves are on continuously, check that the water valves turn off mechanically by disconnecting power to the machine.
Secondary Source: Pump System.
Action: Check pump for blockage and drain hose for correct height(end not immersed in water) or kinked.
Tertiary Source: motor control module.
Action: If water valves are been driven on electrically, replace motor control module.
36 - Water Leak Fault:
Fisher and Paykel washing machine error 36:
Motor control module has needed to top up the water level more than 4 times during wash/rinse cycle. Most likely cause is waster siphoning out or the machine has developed a leak.
Primary Source: Drainage system.
Action: Check that the hose is not less than 850mm from the ground
Secondary Source: Pressure tube.
Action: Make sure the pressure tube is fitted correctly and doesnt have any holes.
37 - Blocked pump:
Fisher and Paykel washing machine error 37:
Primary Source: Drain System.
Action:
1. Check that the drain hose has not been kinked.
2. Check the length of the hose. 1m is maximum extension.
3. Check drain pump winding for open circuit.(Note: Pumps are fitted with a thermal cut out and will reset after cooling)
4. Check for physical blockage to pump and hoses.
38 - Pressure Sensor Fault(empty reading during wash cycle):
Fisher and Paykel washing machine error 38:
Primary Source: Pressure tube.
Action: Check if tube is fitted correctly, check for blockages or holes in the pressure tube.
Secondary Source: Motor Control Module
Action: Replace the module.
39 - Pressure Tube Fault:
Fisher and Paykel washing machine error 39:
Same as fault 38.
40 - Bowl Dis-engage Fault:
Fisher and Paykel washing machine error 40:
Primary Source: Mechanical.
Action:
1. Check that there are no clothes or other foreign objects preventing the clutch from re-engaging. Excessive suds can also stop the bowl rotating.
2. Check the clutch splines for physical damage.
3. Check that the pressure tube has not come off, kinked or blocked(blow down the tube.
Secondary Source: Motor Control Board.
Action: Change Board.
43 - Out Of Balance Switch Fault:
Fisher and Paykel washing machine error 43:
Motor control module has found that signal returning from the out of balance switch indicates that the switch is permanently on or the harness to it is disconnected.
Action:
1. Check the level of the machine.
2. Check wiring to the switch.
3. Check switch for continuity and corrosion.
44 - Water in Bowl During Spin:
Fisher and Paykel washing machine error 44:
Primary Source: Drain system.
Action: Check for blockages/kinks in drain hose and function of the drain pump.
48 - Hot and Cold Inlet Valve Incorrect Signal:
Fisher and Paykel washing machine error 48:
Primary Source: Wiring.
Action: Check the wiring.
Secondary Source: Inlet Valves.
Action: Check the resistance of the coils.
Tertiary Source: Motor Control Module.
Action: Change Module.
49 - Cold Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 49:
Action: See fault 48.
50 - Hot Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 50:
51 - Diverter Valve Fault:
Fisher and Paykel washing machine error 51:
Primary Source: Blocked diverter valve.
Action: Check for foreign objects in the valve.
Secondary Source: Motor Control Module & Diverter Valve
Action: Plug the machine into the power point but off at the control panel. Check voltage on the plugs at the diverter valve. If voltage around 230V, change diverter valve and motor control module
Oct 07, 2016 | Fisher and Paykel Washing Machines
Hi my fisher and paykel washing machine is stuck up. When i turn it on it will stay on this mode-hold and the buttons won't work and won't even start. Can you help me solve this problem? Thanks
This is an old post I know
The wash progress lights are giving an error code. With zero meaning OFF and 1 meaning ON your picture shows an error code of 01000000
Switch machine off at the wall for a good 5 minutes. Turn on again and see if the same error again I am afraid this is what the service manual says::
64. (01000000) - Pressure Transducer Error - Frequency < 66 kHz
The Motor Control Module has received signals from the water level
sensor (Ptx) below normal frequency values.
Cause: Faulty Motor Control Module.
Action: Replace Motor Control Module.
The motor control module is found under the buttons panel. Undo the 2 screws at the back behind the buttons and the controller is underneath. You may have to pull the main lid off first to get the buttons panel off. Motor Controllers are not cheap sorry. They can be found on Ebay
MAKE SURE YOU GET THE RIGHT MOTOR CONTROLLER PART NUMBER ON THE STICKER. They may look the same but they are all different.
Unplugging the controller may seem daunting but count how many things you unplug and then you know how many to put back on. The plugs can only fit in their own sockets so you can not mix them up.
Hope this is of some help
Good luck
Jun 30, 2015 | Fisher and Paykel Washing Machines
Displays code 107
Error code 107.
(01101011) Motor Control Module Reset Error
The Display Module has detected that the Motor Control Module has reset when it should not have. This can be due to a Motor Control Module supply disturbance or microprocessor failure.
Primary Source: Motor Control Module.
Mar 15, 2013 | Fisher and Paykel GWL11 Top Load Washer
Lights 2 and 7 and constant beeping
Error code 66 is water pressure sensor.
66. (01000001) Pressure Transducer Error [Ptx Frequency > 90 kHz]
Note: this supersedes Fault code 65 from V41 Motor controller code onwards.
The Motor Control module has received signals from the water level sensor (Ptx)
above normal frequency values.
Primary Source: Motor Control module
Action: Replace Motor Control module
Dec 06, 2012 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel error code 107
107. (01101011) Motor Control Module Reset Error
failure.
Aug 23, 2012 | Fisher and Paykel (IWL12)
Fault code 107
failure.
Aug 23, 2012 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel Smartdrive MW058K error code 106
106. (01101010) Display Module to Motor Control Module Communications Error
These faults are reported when the Display Module detects an error in the communications
between the Display Module and the Motor Control Module.
Primary Source: Display Module.
Action: Replace Display Module.
Secondary Source: Motor Control Module.
Jul 23, 2012 | Fisher and Paykel Fisher & Paykel Washer
Machine says "I need service"
I took this from the service repair manual. Hope it helps.
HI error code 66 means you have a pressure transducer out of range error.This means that the control module is faulty and needs replacing.please confirm that the error code is numbered 66. On some machines the pressure switch is seperated and sometimes the plastic tub for the switch gets clogged up and blowing through it will sometims clear this fault. Not sure about this particular machine, but you can try adjusting water level to see if it will work at a different level of water.
Mar 24, 2011 | Fisher and Paykel (IWL12)
I have a fisher & paykel aqua smart WL26CW1. I just replaced the module. I am now getting an error code of 9. What does that mean?
Hi dear.That's related to size error.When you replace the motor control module you need to set the machine wash capacity like:5Kg or 7.5Kg.To do that please follow the steps: Phase 1 to 6 Size Switch Error
The Display size switch setting does not match that stored in the memory.IW machines, Phase 5 and 6
To access Size Setting Mode. Push and hold the Fabric care button and then press the Power button to enter Size Setting mode. Select the correct size on the display by pushing the White button next to the correct size (phase 5) or using the Adjust button to highlight the right size (phase 6). Size setting is then achieved by pressing the Power button. Powering off will set the size into the memory. Check the size is set before starting a cycle.
I hope that helps.Thanks.
Sep 03, 2010 | Fisher and Paykel WL26CW1 Top Load Washer
Error code 131
Call the guy who replaced the motor/ module. Error 131 is serious. Not for home repair.
Sep 06, 2006 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher Paykel WA42T26GW1 Laundry : Top Load Washers Logo
Top Fisher Paykel Washing Machines Experts
marlin siecinski
Greg Stephen
Greg Stephen
Paul P
Are you a Fisher Paykel Washing Machine Expert? Answer questions, earn points and help others
