Question about Ovens
New world gas oven. need a replacement oven thermostat. A copreci 15700R/50. is this part or a suitable replacement available.
Oven model CKG 21504 oven 22 yrs old. Thermostat oriiginal G.C. no. 383 709 and part No. 930751900
SOURCE: zanussi zbf 760 (9 yrs old now)
make sure the thermostat probe is fully into the oven
Posted on Nov 19, 2007
  • 1314 Answers
SOURCE: Jenn-air oven model #88370
its just not that often the probe fails without setting a code
Posted on Feb 16, 2008
Sea Breeze
  • 4654 Answers
SOURCE: New replacement thermostat needs calibrating on my Kenmore oven
There is no real way to calibrate the thermostat. Most ovens have the same problem. By lowering the setting slightly will help get a closer temperature. Sometimes similar thermostats are substituted and may not be exactly the same as the original that came with your oven. Hope my trying to answer your question was helpful, Thanks, Sea breeze
Posted on Mar 27, 2009
SOURCE: HOW TO ADJUST THE OVEN THERMOSTAT ON A WHIRLPOOL
Press and hold BAKE pad for five (5) seconds. Current offset, if any is shown in 3-digit display. CAL is shown in 4-digit display (3 digits on right).
Pressing the UP pad adjust the temperature in 10 degree F increments in fthe following sequence: 0, 10,20,30,-30,-20,-10, 0 and so on.
Press START/ENTER pad to activate the desire tempature adjustment. If the START/ENTER pad is not pressed within 5 minutes, adjustment is ignored.
Posted on May 27, 2009
  • 8 Answers
SOURCE: Hello chaps my new world e60cm oven is only
Hi Andy. I have the same problem with mine, just had a repair man come out and the bottom heating element had gone. Don't know if this is a common fault, but maybe the first place to look.
Posted on Nov 26, 2009
The ignition continues after gas lights on new world elegance/cooker and grill
The igniter will glow orange while the oven is on. This is NORMAL. If it went out the burner would not come back on when the thermostat calls for heat .
Aug 18, 2014 | New World G90m Gas Double Oven
Finding the model number
IF YOU STILL HAVE OWNER'S MANUAL IT WILL HAVE MODEL NUMBER ON IT
Nov 29, 2013 | New World G90m Gas Double Oven
Where can I download a manual for a G90m oven
try to search them Google search engine...it will direct you a suitable site which contain your need.
Sep 02, 2012 | New World G90m Gas Double Oven
New world oven overheating
Presumably it is a gas oven?
It should light on a low flame then as the ffd warms it will come onto full rate, when it reaches temperature it should go down to a low flame, to test it set the thermostat to mk 6 and leave it on for 10-15 mins, if you have a glass door look and see if the burner is on low- if it is not then your oven thermostat is faulty, if it is over ten years old it is probably not repairable as parts are not usually available, If you still have the users//service manual there will be a 'shorts' 'parts list in the back listing the thermostat which will give you a part number , if you google that you should get an idea on price and availability.
May 11, 2012 | General Ovens
My gas oven isn't heating up properly, is there
We were able to trouble-shoot our gas oven before calling the repair man. Our oven reached temperature but did not reheat when it cooled down. Our troubleshooting included taking out the storage drawer and looking at the underside of the oven near the valve.
First check if you can see the flame when the oven is on.
Use an oven thermometer in the oven to test if the oven gets to the desired temperature first. Does it get close to the desired temperature and stay near there for your entire bake time? If it does, you may need to adjust the thermostat setting. (This should be in your manual. Many Frigidaire manuals are available from their support site: http://www.frigidaire.com/Customer-Support/Videos--Manuals/ . )
Since our oven was reaching the set temperature and then not reheating, we had one person crawl under the oven and tap on the regulator when the oven needed to reheat. (We could see the ignitor spark.)
If the oven isn't heating at all, then the thermostat, the gas valve, controller or ignitor are suspects. Can you see the spark of the ignitor? Then it's probably not the issue. Similarly if you see the flame coming on several times during the bake cycle, it's not likely to be the valve. If you have a multimeter, you may be able to check the thermostat and controller for any breaks in the wire.
In our case, since the valve was failing, we ended up replacing the 10-year old range. (We looked at the price of a new range versus part and labor cost for the replacement. The part and labor was more than 50% of a new range.)
I hope this helps.
Apr 04, 2012 | Frigidaire Ovens
The power keeps going off to the clock and the oven turns itself off
That is an ongoing problem with that model oven. It is the circuit board that is to blame. If the unit is still under warranty, call New World for the repair. If it's not, you will need to replace the board yourself.
Oct 17, 2011 | New World G70m Gas Double Oven
How to dismantle a ckg 21504 built in cooker and grill unit and turning gas and electricity off
I have the installation and servicing documents for this item.
I would be interested in the f.s.d./solenoid assembly if you are getting rid of it.
I am not an engineer but if I can assist you with photocopies of the book I will, but I don't think this will help much.
And if anybody else reading this can help me obtain a FFD part no. C00154538 I would be very grateful.
Feb 14, 2011 | New World Ovens
Oven keeps going out
The problem is usually the ignitor not reaching the correct amp draw .When the ignitor does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The ignitors are inexpensive and easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available.
Apr 07, 2010 | New World G60m Gas Single Oven
Temp 50 degree too cold need to adjust thermostat on JGRS14
ive installed 100 new thermostats over the years and they are set from the factory.no adjusting.now some knobs have an adjustment on them.and some times customers got knobs mixed up and got the wrong one one there.
Jan 01, 2009 | GE JGRS14 Gas Single Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
