Question about Inverter 50a Amp Plasma Cutter, Air , Cut50d 110/220vac
I heard a pop like a large electrical component blowing. Now the fan won't come on and the unit shuts down after a few seconds. The consumables were still pretty good but replaces them after the p
I pulled the cover and can't see any obvious burnt parts. I didn't smell or see any smoke. I was cutting on an auto ruoftop to lighten it for racing. The unit worked well doing the same on another top early last year. I don't use the unit much but when I did, I never noticed any problems. I am not an electronic whiz but it has air, it is set up for 220 and I keep it in a dry workshop. I need this to work but pay the price for not having a local place to have it worked or or diagnosed. HELP!
  • 3,904 Answers
Very first thing I would check is for fuses. From there I would put a meter at different points for find out where the power stops. The will identify the component or the area that needs to be repaired. Main power supply is my guess for replacement.
Posted on Jan 21, 2013
I have a emachine that powers ou, power pack fan, cpu fan but not the hardrive. It shut down and now won't start up. No beeps
Unplug from AC, open the case, clean if necessary, reseat the memory mods, use Electronic Contact Cleaner spray on contacts, plug in, push the on/off button. Does it begin to start, and in a few seconds completly shuts down? No LED's , no fans, nothing? Sounds like a PSU failure. Mine went out in 6 years.
Jan 09, 2013 | Computers & Internet
2002 Nissan Pathfinder _ Electrical Problems
Unusual the dealer can't or won't find the problem.
A mechanic would check everything in that circuit for shorts to ground.
Was the fuse blowing before the alternator and battery were replaced ?
Based on the wiring diagrams I would vote for a defective alternator.
The 10 amp fuse number 8 powers the cluster which also goes to the alternator. If the alternator shorts out internally it would blow that number 8 fuse and take the cluster with it.
The other circuits you mentioned are controlled by the key switch but are fused after the switch. So if the switch was causing the problem it should be blowing a 40amp fuse.
I would probably take the alternator off and have someone else test it.
Jul 09, 2012 | 2002 Nissan Pathfinder
My bathroom heater shuts off after it's on for less than a minute. After a 10 minute wait, a click can be heard and it can be restarted. But only for another 45 seconds
The click sound is the thermostat. It closed and the allows power to the fan heater. The thermostat is faulty and won't allow you to select a higher heat setting.
Jan 19, 2012 | Broan-NuTone Dryers
I have a whirlpool central air conditioning and the condenser stoped working. what could I expect it to be?
When you say the 'condenser' stopped running - I'm 'assuming' you are talking about the outside unit, and I'm also 'assuming' that when you say it stopped running you mean 'nothing' runs on the outside unit - fan motor OR compressor. The fan motor will drown out the compressor running noise which is a 'low rumbling' sound - often not heard by the layman because of the noise the fan motor puts out.
Assuming you are talking about the outside unit and 'nothing' is running either fan motor or compressor then you might be 'in luck.' Because the most likely reason for the outside unit to be totally off will be a 'blown fuse' or a 'tripped breaker.' The good news is that in 'hot weather,' especially the kind of hot weather that has been present this summer (especially in the south) - blowing a fuse or tripping a breaker is not necessarily an expensive repair.
Indeed, it's not uncommon for a AC unit to blow a fuse (or trip a breaker) on occasion, although it must be noted that doing so is also is sign on something seriously wrong with your AC, i.e. a fan motor breaking down electrically or even a Compressor, both being expensive items to replace.
But, as I said, it's not uncommon for a fuse to blow once in awhile.
I would check my fuses (and breaker) and see if this is what has happened.
If you have fuses (usually located outside close to the condenser) and have no way to check them (you check them with a ohm meter looking for continuity) - then just 'replace' them with new ones. Note: always put 'time delay/dual element' fuses back in - even if the ones that are in there now are 'one time' fuses. 'Time delay' fuses do just what they say they will do - (they hold for just a second or two during that initial start up (of the compressor) without blowing).
If a blown fuse/tripped breaker is your problem then "most" of the time the AC will run ok and you will not have any more problems.
However, if after replacing the fuses and turning the AC back on - the fuse(s) blows instantly, or a short period thereafter (say a few minutes or an hour) then you probably have a problem that is causing it - i.e. the fan motor or compressor is going bad.
Note: one thing that you can fix that might be causing the fuse to blow is a dirty condenser. So, check the condenser coil (think of it like a car's radiator). It 'must' be clean to run properly and when it gets 'really dirty and clogged with dirt it will cause high head pressure and can cause the unit to blow fuses and trip breakers.
Good Luck!
Aug 10, 2011 | Whirlpool Heating & Cooling
I have a Trane unit 2 Ton that was washed down with the unit running. Was told unit compressor changed tunes while doing so. i suspect the compressor is shorted since it will not come back on , fan is...
A 'short' would be indicated by a breaker tripping or a fuse blowing at the time you turn on the unit, so I don't think you are dealing with a short. Since the compressor is a 'sealed unit' it's doubtful if you harmed it. However, washing down an AC with it running is not advisable and in fact is very dangerous. Electricity and water do not mix and a person can easily electrocute himself/herself doing this. That being said I would make sure the entire unit has dried out and with all power off - then 'inspect' all the electrical components - i.e. wire connections and 'starter relay' to make sure everything is in good condition. The fact that the fan is running indicates the 'starter relay' is ok - again - I would check all the electrical components, especially where the wires connect to the compressor. My guess is you have a wire burnt off of the compressor which probably happened while the unit was being washed.
Jun 06, 2011 | Heating & Cooling
Dayton 30' pedestal fan will run for an hour or so, seems to run hot.. there is slight burning smell. then fan makes little noise and shuts down.
Whats happening is that your fan is overheating (usually due to a loss of lubrication in the bearings), and the motor's thermal cutoff is kicking in (due to overtemperature), and shutting down the motor.
This thermal cutoff circuit is installed in consumer motors to prevent fires.
You have two solutions:
(1) disassemble your nice 30" pedestal fan (I've done this a few times - any handy guy/gal can do it),
and lubricate (with automotive bearing grease ($3 at any auto parts store), or 3-in-1 oil for those spots that won't take bearing grease) the bearings, and
reassemble. Re-lubricate on a regular schedule to prevent recurrence.
(2) buy a new one. Give your old fan to the kid on the block who thinks he/she can fix anything &
tell him/her it just needs to be lubricated.
May 13, 2011 | Dayton (2C373) Fan
My SM11 model Steamist was installed above our shower/steam room. It is 2 years old. While in use recently, it made a loud sound like a low-pitch popping sound or low boom. Imagine somebody inside a...
The heating elements had burned up in the unit therefor creating a dead short on that circuit. Main breakers on homes and buildings are VERY sensitive and will sometimes trip before the smaller branch cicuit breakers will . So the popping you heard was the heating elements breaking down inside the unit it can be some what noisy.
Nov 03, 2010 | Steamist 1100 Sm11 Large Capacity Steam...
Not working plmv169dc
HI, the sound you herd was the noise filter and running diode. these important components have failed at this point. you will need to replace these components asap, if possible. this will fix your issue.
The Magnetron Cut-off fuse will need to be replace as well. this will blow if there is a malfunction within the unit.
Jul 22, 2009 | Frigidaire PLMV169DC Microwave Oven
Inverter 50a Amp Plasma Cutter, Air , Cut50d 110/220vac Logo
Top Inverter Electronics - Others Experts
mntech1
ray gallant
Tom Chichester
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
