Question about Philips Magnavox 26MD357B-37 26 in. LCD TV/DVD Combo
Will not power on
Seems to overheat. power light shuts off. Then some time later turns back on.
    Genius:
  • 1,003 Answers
Replace the power supply board Available at Shopjimmy.com.
Posted on Jan 21, 2013
Auto shut off hot
A faulty transistor or IC that has failed, it probably overheats before any other device. You should shut the amp down when it happens, then feel carefully around for the hottest part. I would replace that. Or you can power the amp back up wait till it acts up, then spray that hot part with Servisol Freezer spray. If it comes back on, then you know it's faulty. If not try another part, with the spray, only one at a time.
Nov 18, 2013 | Peavey Audio Players & Recorders
Monitor goes blank less than a second after turning on.
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
I have a Infocus in1503. It shuts down after 10 to 30 minutes. When it does shut down there is no lights. In fact the power light goes off as well.
I seemed to have had the exact same problem... I had placed the projector on top of a small book (to raise the unit), however, did not rest the feet of the projection unit on the book and it overheated and turned off, as a result. (The bottom of the unit was making direct contact with the book which caused it to overheat since not any air was passing through between the two)
After letting it cool for a while and powering it up -- it would usually power off completely for about 15 minutes. After a little thinking, I thought it may be the lamp/bulb and waited a couple of years and bought one online that arrived yesterday.
I installed the new lamp/bulb this morning and it did the same thing. It powered down about a half hour later. Bummer.
I reset the machine to factory defaults and checked to see if it had the 1.03 firmware... It did
Then went through the settings in the setup area and turned off the 'prevent pic screen saver'... Reset the 'lamp hours'
I doubled checked the lamp/bulb installation... Turned it back on -- same thing -- it shut off after about 15 minutes or so... Then unplugged the unit and turned it over and took out the 4 or 5 chassis screws and loosened and took off the side panels and blew onto the fans and circuit board areas and gently pounded the sides to shake anything that shouldn't be there loose and put it back together.
i powered it back on and now it's been working for about 2 hours and 16 minutes!
good luck!
Nov 12, 2013 | InFocus IN1503 DLP Projector
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Turn on the power, green light turns on, then it shuts back off
I have the same problem but I do have a remote and it doesn't seem to make a difference. Has your problem been fixed, and how?
Jul 29, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
Hitachi 50UX22B projection ultravision. shutting off on its own.
Since the set seems to recover somewhat, Id look for poor sonnections first rather than defective components. If you can solder and arecomfortable working inside the set, you may be able to fix this yourself. Are there any other symptoms other than just shutting down? For example, blinking standby lights?
Dan
Jan 12, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Our Samsung HL-P4663W DLP is makes noise and shuts off
It is the color wheel, inside the light engine. The bearings get dirty and makes it harder for the wheel to spin causing that whin.
Jan 06, 2009 | Samsung DLP HL-P5663W 56" TV
Laptop
Fist, It doesnt overheat when the battery gets low, it just powers off or goes into standby.
Why do you think it over heated?
Try this first. Remove the battery and unplug it for about 2 minutes, re-insert them amnd try to power it on.
What does it do? Any beeps or flashing lights? What color are they?
Dec 12, 2008 | Dell Inspiron B130 Notebook
Viewsonic N3000w LCD TV randomly shuts off...
It seems that the power fails quite often with this one burning the Inverter boards transformers. OZ960G chip may not be broken, so try getting a new power from somewhere. Measure the transformers. suppose to be somewhat 5 ohms. tolerance is +-1.5 ohm. of more, replace.
Nov 21, 2007 | ViewSonic N3000W 30 in. HD-Ready LCD...
Philips Magnavox 26MD357B-37 26 in. LCD TV/DVD Combo Logo
43 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
