I changed the settings on my computer for the printer to print 4X6 from the photo tray, but when I send the job to the printer, the printer wants to print from the main tray on full-sized paper. This is driving me crazy!
-   have been working on this for days. Printer always says printer out of paper. It will not go to 4x6 tray. -   Guest
Feb 28, 2009
-   I have the same problem, this printer worked fine with Photoshop on my Windows XP, but now that I'm using a Mac it will only print on regular paper and I've lost the HP printing dialog box. On paper size it sometimes only lists letter and envelope sizes not 4x6. Also, I can't find anything listing photo tray, or defining the type of paper. Does anyone know what's wrong?
-   Freddif
If you using a mac:
After choosing the Photosmart C7200 to print your file on the print preview, change PAPER SIZE to 4x6, then lower down, change from PREVIEW to PAPER TYPE/QUALITY, more options will open underneath, on SOURCE, change from MAIN TRAY to PHOTO TRAY. You should also change the PAPER TYPE to some kind of PHOTO PAPER (whichever one your using, but the standard seems to be HP ADVANCED PHOTO PAPER)
Photo smart D7560 printer. Message says photo tray problem. re insert or lower photo tray. I think I...
(More)
Photo smart D7560 printer. Message says photo tray problem. re insert or lower photo tray. I think I have done this several times. Isn't the photo tray what holds paper? what do I need to do?
When I try to print photos from a memory stick it fails to print and tells me to load paper glossy...
(More)
When I try to print photos from a memory stick it fails to print and tells me to load paper glossy side down even though there is enough paper properly loaded. When I take out the paper the top sheet has a small indentation which seems to line up with th paper stop at the back of the feed tray
my hp c7200 won't print AGAIN. I'm starting to think this printer is not worth the $$ I paid for it....
(More)
my hp c7200 won't print AGAIN. I'm starting to think this printer is not worth the $$ I paid for it. The computer used to recognize it now it doesn't.
photo tray problem !! lift output tray up , verify the photo tray is pushed un untill it stops lower...
(More)
photo tray problem !! lift output tray up , verify the photo tray is pushed un untill it stops lower output tray this is what they are telling me !!! what should i do !!
I have a mac computer now, it worked before on my windows computer.
The photo tray will not work...
(More)
The photo tray will not work from this computer
