Question about Dryers
Neptune dryer MDE6700AZW over heating and blowing the thermal fuse.....air flow is good no blockage what so ever?
    New Friend:
  • 169 Answers
You will need to check the air passage on the incoming side of the fan also. Most will check the exhaust side and clear it out, but if the incoming side has obstructions it will not allow air flow either.
Posted on Jan 22, 2013
dididsaythat
  • 291 Answers
SOURCE: fuse keep blowing
I would check temp out of dryer should be 140 - 160
Is your cycling themostate good, cutting off when suppose too?  and Hi limit on burner good?
THe cycling themostate control drum temp, hi limit on heater is a back up and the hi limit fuse on burner backs up it all
Posted on Oct 17, 2007
localwonder
  • 6784 Answers
SOURCE: Heating element stays on when dryer is off.
I would advise to inspect the high limit thermostat. this device may be defective. this will cause the element to continue to operate when the unit is off as well. If the thermostat is operating correctly, replace the timer.
Posted on Aug 12, 2009
SOURCE: i have a kenmore model # 110.60622990 and i
i had the same problem, it was the recepticle blew one of the hots.The dryer was getting power to everything but the heater.buy a 5 dollar tester that is meant for 240 and check both legs on it
Posted on Sep 14, 2009
tbirdfan1
  • 3051 Answers
SOURCE: My dryer runs but has no heat. I have replaced the
Hello there :
There are severaol things that could cause this to happen
Things to check are :
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
I know that you have checked the thermal fuse so you dont have to worry about this.ok
Hope thatthis is very helpful
Best regards Michael
Posted on Dec 23, 2009
mikes112
  • 56 Answers
SOURCE: GE Dryer Model #DWSR483EB2WW Dryer tumbles,
Does it get hot when you start the dryer, and never gets hot again when its running? The solenoid wire might be opening due to heat, the solenoid is responsible for opening the gas valve, and booster valve. The wire is located in a round plastic sleeve with two electrical contacts sticking out.
Posted on Mar 23, 2010
The thermal fuse on my Whirlpool Cabrio keeps blowing. The exhaust vent is clean and clear, what should i check next after replacing the fuse again?
If you keep blowing the thermal fuse there is a air flow restriction some where disconnect the exhaust at dryer turn on you should have a good air flow exiting machine if not check the blower wheel for lint build up if good the it is in the exhaust exiting the house this is a rarity but the thermistor which cycles heat on/off could be bad hope this helps
Mar 31, 2014 | Dryers
The maytag dryer mde6700azw gets too hot and keeps on blowing the thermal fuse.....it works ok for about a week and it repeats itself?
Make sure all air flow passages are clear. On both sides of the fan, the incoming air vent and the exhaust air vent, all the way to out side of the home.
Jan 21, 2013 | Maytag Neptune MDE5500AY Electric Dryer
Neptune dryer over heating
Check all the air flow vents and make sure they are not clogged. Check on each side of the fan, the incoming and exhaust air all the way to the outside of the home.
Jan 21, 2013 | Dryers
I have replaced the thermal cutoff fuse and the high limit thermostate, along with the heating coil, and cleaned all the lint. But the thermal cutoff has failed again, what should I check now?
Sounds like you have some sort of blockage either in the dryer itself or in the exhaust vent.The thermal fuse will blow if the air is not flowing enough.Hope this helps.
Apr 13, 2011 | Kenmore 62602 Electric Dryer
My maytag neptune dryer doesn't blow any hot air
on top of the heating element on the left side there is a white 2connector part, that is the heater thermal fuse. disconnect the dryer power cord and one wire of the thermal fuse and use a meter to find out if you have continuity to it. if not replace it. also check for burn wires at heating element. also test heating element by disconnecting one wire and using an ohm meter test it at 2 therminals. it shoul measure 10-12 ohms.
Feb 14, 2011 | Maytag Neptune MDE5500AY Electric Dryer
My Kenmore HE5 dryer will not run without blowing an internal fuse. The repairman replaced the fuse, and it blew again. The dryer heats up but will not turn it's heating element off until the fuse blows....
Has any one checked the exhaust vent,other than a bad thermostat the number one cause for the thermal fuse to open is a clogged or restricted exhaust vent flow, the entire vent system needs to be checked ( not just the hose from the unit to the wall) for proper air flow. Turn the unit on TIMED ,AIR DRY (NO HEAT) and go outside to the exhaust vent and check the air flow,if there is any question as to weather the air flow is sufishent get someone out to clean the exhaust vent ,it always a good idea to clean out every few years regardless to help prevent build up of lint witch could cause a fire......Hope this Helps Good Luck
Dec 14, 2010 | Kenmore HE5 Electric Dryer
Thermal fuse repeatedly blows
The thermal fuse or high limit thermostat failure generally points to a reduction of air flow due to SOME blockage either inside the dryer or in the vent pipe leading out of the house. If you find either of these parts bad be sure to check the vents after replacing parts to ensure the same parts won't fail again.
It sounds like you have blockage in SOME area of the venting system, either interior to the dryer or in the vent pipe leading out of the house. The thermal fuse is a safety feature to warn of low air flow. Remove vent from wall and run dryer placing hand over end of hose to determine strength of flow difference after attempting to do the same thing at the exhaust outside the house. Good Luck.
Sep 04, 2009 | Kenmore Dryers
Kenmore Dryer won't heat up
thermal fuse is bad. replace fuse. clean out vent duct. thermal fuse usually blows when there is restricted air flow over heating element.
Jun 24, 2009 | Dryers
The dryer only blow out cold air.
When I turn the dryer on, only cold air blows out. There's no heat. I cleaned out the vents? What do you think is my problem> Thank you very much. K
Oct 18, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Whirlpool dryer
First make sure you have power to the unit through the plug. If power is present, then you most likely have an open Thermal Safety Fuse. The Thermal is a Safety feature that shuts off the power to the Heat Element in the event the Blower is not blowing or the Lint Vent becomes clogged not allowing air to flow over the Heat Element. NO air flow, Heat Element over heats, Thermal Safety Fuse opens, power shuts off. If the Thermal Safety Fuse is open find out why. Was the blower not working? Was the Lint Filter clogged? ( Lint Filter should be cleaned after each use to assure continued air flow.) Was Lint Vent Clogged? This is the Vent Hose that goes from the Dryer to the outside of your house. It should be checked for free air movement. The next thing-- Could be a defective Timer or Control Module.
Find where you lost power and WHY!!
Jan 27, 2008 | Dryers
Dryers Logo
55 people viewed this question
Top Dryers Experts
