Question about Samsung Televison & Video
Video disabled on one channel
Video disabled shows on one channel
  • Glenroy Smith Jan 23, 2013
    Thanks for the answer but the channel started working again, will keep that in mind if it acts up again.
    Genius:
  • 1,003 Answers
Replace the mainboard!
Posted on Jan 21, 2013
On CBS channel in HD when a show says available in SAP it only broadcast in that. How can I turn that off?
The second audio program (SAP) is enabled/disabled as part of initial set up. Return to that procedure and disable SAP.
Jan 15, 2017 | Televison & Video
Tip
Adding channels to your box t eurovox or digivox
ok so hopefully you have everything up and running but you dont seem to have all the channels that you should have so you step1 press menu then press installalation then manuall installalation scrool down to input code step 2 input the no. that you are receiving a signal from this will be highlighted with the two bars at the bottom saying signal strength and quality step3 the no.that are highlighted ie.330.00 you add 300 to each of the ones that are highlighted ie.330.300 then scroll down to where it says scan this will more than likely say disabled press >on your remote to set to enable then press scan step 4 you should repeat this with all the channels that are showing signal input each no. then add 300 with your remote and any channels you are missing will come in if not even get you more channels than you allready have after you have done all the frequencys you should have added a few more channels when finished exit exit back to main screen and enjoy
on Apr 28, 2010 | Audio Players & Recorders
How do I remove the decoder off from the tuner? I can not get audio.
Hi, Not sure what exactly you mean.
Try turning input knob on Receiver or press equipment button like Sat/cable or DVD on remote.
If still no sound look for a button "Input mode" or "6 Channel" eg on receiver and select analogue, digital etc or disable 6 channel mode.
Make sure speaker wires are connected and not short circuit. Also look for speaker button, On some receivers you can disable speakers.or select A & B
If sound was working before you probably just press or disable sound settings on receiver.
Sep 24, 2014 | Yamaha RXV367 5.1-Channel Black Digital...
Panasonic viera cc
Try identifying which caption is from the TV and which is from the cable box by turning the TV Closed Caption on and off while you have to sets of captioning. This will show you which closed caption never turns off.
Aug 08, 2013 | Televison & Video
Certain cameras are showing the same video.
First you need to isolate the problem. Step one - make sure the video from the cameras is correct - use a monitor and check each input separate. If the video is correct, use one camera and start from input one on the DVR and check all inputs - in other words plug your camera in input 1, check for video to make sure is correct and shows up in the right place, than go to input 2. This way you check your DVR cards. If the video shows up, but in the wrong place - check the settings on the DVR - you might be able to change the physical input in the viewer.Or you might have a bad DVR.......do a search for DVR Doctors in Google - in case you need repair.
Jan 27, 2012 | Avermedia AVerDiGi SA6832E RACK 32-Channel...
When I turn the tv on there is only 4 channels that show up. And I do have the cable pluged in
Run a full channel scan through the menu and the rest should show up as well.
Some TVs also have ability to manually turn off channels, which makes it easier to navigate when using UP and DOWN channel buttons. Instead of going to every single channel available you skip the ones that have been marked for skipping. It's a useful feature, but can get you in trouble.
Once a local hotel called us to repair 5 of their TVs and what turned out was that someone has played a joke on them and disabled all channels from the menu.
http://www.coppelltvrepair.com
Dec 09, 2010 | Westinghouse SK-26H240S Television
How to disable integrated video in BIOS?
The BIOS manual for the board is available here. It doesn't show any settings for enabling/disabling the integrated video. Most motherboards automatically detect a plug-in card and use that when one is plugged in anyway, so you shouldn't need to worry about disabling the integrated video yourself.
Mar 01, 2010 | Biostar P4M80-M7 Motherboard
Stuck on a video mode
Some TV's disable inputs if there is no signal. I suggest confirming cables are connected properly, and accessing the system menu, and perform an autoscan for channels
Apr 27, 2009 | Initial HDTV-320 32 in. LCD TV
Televison & Video Logo
12 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
