Question about Tilia V2240 FOODSAVER VAC
SOURCE: Foodsaver 1050 - the metal strip under the tape is
Try elementsandteflon.com. or Hualian Packaging Machineries, Inc. You may find it there.
Posted on Jul 13, 2010
SOURCE: Foodsaver Food Sealer Vacuum V2240 T: Foodsaver Professional II Turbo. Vacuum pump work...
This is likely happening because the unit cannot detect that a vacuum has formed, and as a result, the unit never "turns on" the heating element to seal the bag, with the gaskets around the vacuum channel being the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Buy some food-grade silicone grease and apply it to both the upper and lower gaskets. I remove the gaskets and coat both sides with a thin layer of grease before replacing them in their respective channels. And since this grease will be absorbed and/or dry out with time, you will have to do this occasionally, so I also flip the gaskets (i.e. turn them over) whenever I apply the grease.
You can buy a 2 oz container of silicone grease at any dive store, or you can buy it over the Internet by searching for "Trident silicone grease".
This is a link where you can buy it for around $7.00:
Dolphin Dive Center
I do not work at this dive center, but I am a scuba diver and already had some grease that I use for the numerous rubber gaskets in my gear. The 2 oz. jar will last you several years, and you will find many other uses for it around the house since the grease will last longer than a spray.
Posted on Aug 02, 2010
SOURCE: Can you purchase a replacement seal/gasket for the
I posted this solution for other problems - it might help you, too:
Dolphin Dive Center
SOURCE: foodsaver vac800 not sealing bags any way to fix
No, the heating strip is actually a wire that get s warm the do the sealing...when the wire breaks there is no more heating and there is no way to repair that wire...
heatman101
Posted on Sep 16, 2010
Testimonial: "20 mins. got my answer fast thanks"
SOURCE: Foodsaver V2440 won't vacuum air out
You need new replacement gasket, to get one, visit amazon FoodSaver Vacuum Sealer Upper Gasket Assembly T910 00075. I hope this was helpful. cheers
Posted on Nov 25, 2014
Jul 12, 2014 | FoodSaver V2440 Advanced Design Vacuum...
Jan 05, 2014 | Kitchen Appliances - Others
Dec 27, 2012 | Kitchen Appliances - Others
Feb 08, 2011 | Tilia FoodSaver V2240
Dec 14, 2010 | Tilia Foodsaver V835 Vacuum Sealer
Sep 16, 2010 | Tilia Foodsaver V835 Vacuum Sealer
Jun 17, 2010 | Tilia FoodSaver V2240
Jan 07, 2009 | Tilia FoodSaver V2240
Nov 14, 2008 | Heating & Cooling
74 people viewed this question
