Looking for a centre roller on Hardin HPG 331 pipe polisher
Error message sc.440 on ricoh mp4000 copier
It happen when there is a slight load tansfer belt. What l did was..clean all the rollers & bushings underneath the transfer belt. Threre are 3 rollers..4 bearings & 2 bushings. Remove all stains.. And also you could polish the surface of the transfer belt by using car polish liquid to smoothen the belt rotation
Jun 28, 2013 | Ricoh Aficio Mp5000 Lanier Ld050
Paper will not feed
HELLO OK IF PAPER KEEPS GETTING STUCK ON THE PICK UP ROLLERTHAN U NEED TO CLEAN THE ROLLER TRY CLEANING THE ROLLER WITH A POLISH NAIL REMOVER..
WHAT THIS DOES IT FRESHES THE RUBBER SO CAN PICK UP THE PAPER...
1)OPEN TRAY OUT
2)GET A CLOTHING WITH POLISH REMOVER ON TIP
#RUBB THE CLOTH TO THEPICK UP ROLLER
3) STICK YOUR HAND INSIDE BOTTOM ALL DA WAY TO THE BACK WHERE U SEE THE ROLLER AND RUB AGAINST IT
4) TRY PRINTING
IF THIS SOLUTION HELPED RATE ME THANK YOU
Mar 26, 2013 | Dell 725 InkJet Printer
Wont take paper from paper tray
This could be a couple things. Too much paper, the wrong type of paper (too polished or stiff) or polished or hardened takeup rollers. The easiest fix, other than the paper is to clean the rollers with alcohol and LIGHTLY scrape them until the polish is removed from them.
Sep 25, 2011 | Dell 1710n Laser Printer
F5 Newtonian Dobsonian 10" I need
Hardin Optical is out of business-- however a well stocked hardware store should carry some springs that will work just fine.
Jul 04, 2011 | Hardin Optical Deep Space Hunter 10...
I have a hardin deep space hunter 6 newtonian telescope with a dobsonian mount about 6 years old, the finderscope glass is broken, would like to repair it or replace it .Any ideas ? thanks Ray
You can buy a new finder scope. There are many retailers on-line--
Here is one:
http://www.telescope.com/Accessories/Telescope-Finder-Scopes/pc/3/49.uts
May 22, 2011 | Hardin Optical Deep Space Hunter 6 (240 x...
Need diagram of under the hood of a 98 XK8 Jag...looking for the throttle body
hello
if you locate the airbox fitted to the Right hand inner wing you will see a large black intake pipe leading to the centre rear end of the engine bay that is where the throttle body is located if you remove this pipe by removing the hose clip securing the intake pipe of the air mass meter and then follow the pipe back to the centre rear of the engine bay and the pipe is attached to the throttle boy with 2 10mm hex bolt once these bolts are removedand the intake pipe is removed the throttle body is evident
Regards
Jan 08, 2011 | Jaguar XK8 Cars & Trucks
Also looking for a refractor 150mm apo of the brand Hardin of course
Hardin is now out of business. You never said exactly what your problem is?????
Oct 12, 2010 | Hardin Optical STAR HOC 90mm (200 x 90mm)...
Looking for a reducer/flattener, hope you can find one for me??
You can buy focal reducers from many on-line retailers here are two--
http://agenaastro.com/optical-accessories.html?SID=s3au8hupdmtagk3u0mebnvoqq6&cat=27
http://www.optcorp.com/category.aspx?uid=105-172
Oct 12, 2010 | Hardin Optical STAR HOC 80mm Telescope
How to remove rust looking stains on outer doors
Use DeBruce Polish, we use DeBruce Polish on all of our stainless steel. DeBruce Polish also works on glass cook tops. We get DeBruce Polish at debrucepolish.com.
Apr 28, 2010 | KitchenAid Superba Architect KSCS25IN Side...
Orange roller
hi im jules_09,is it all the fuser area?to be safe try cleaning it first with alcohol,if the that doesnot work try metal polish,just be sure its not the opc drum that make the copies ok,get a fine and soft cloth so you would not damage the roller,urb a right amount of metal polish to it then then rub it with cloth gently in one direction the best directio is circular.be carefull not to scracth it or the drum
Nov 08, 2007 | Kodak Ektaprint 95 Copier
27 people viewed this question
jasbo
jasbo
