FixYa.com
Tags:
Sony Cyber-Shot DSC-S40 Digital Camera
Still have a white LCD Screen! (by 10 users)
posted by sporty2 on Jul 19, 2007
My Cyber-shot DSC-S40 LCD screen is still white. I tried looking for the Cyber shot logo that several people have recommended to try and correct the problem, but I can't see it. My camera is just over a year old. Any suggestions are much appreciated.
thanks Ed
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
9 Other Users Have The Same Problem
Comment by aponylover, posted on Apr 27, 2008
Same issue: LCD remains white - camera is just over 1 year old and has never been hooked up directly to a computer. I always remove the memory stick when the camera is "off" and put the memory stick in the computer port.
Camera will still take movies and still photos outdoors, still zooms and powers on and off just fine. The LCD just shows white.
Called Sony but they want $115 to fix it (a new non-sony camera is a cheaper option). One month out of warranty and Sony said too bad!
Comment by NAMr, posted on Mar 16, 2008
Whenever i switch on my camera or when i click a pic or a video the screen remains white ...Any solutions to this?
Comment by ninglus, posted on Mar 13, 2008
I have same problem: when I switch on, screen is blank white. Camera actually takes pictures OK, but you can't see them on the screen. I consulted the online manual at http://pdf.crse.com/manuals/2589978121.pdf pages 72, 73 and 58. It looked as if it might have been that I disconnected the camera from the computer after downloading some pics, without doing the "disconnect hardware" routine as described on p 58, so I did that, several times, and in different combinations, like removing the usb before switching off the camera and visa versa, but all to no avail. The camera is still usable, but only if viewing throughthe eyepiece.
I contacted some sonycentres, but they only do a send-away service, which costs 45 pounds sterling non-refund deposit. Any suggestions???
Comment by Neilus, posted on Mar 10, 2008
When I turn on my camera the lcd screen shows blank white and does not show any images.
Comment by Guest, posted on Jan 03, 2008
In my camera there is white display every time when i take stills, and when i switch in camera ask for setting date and time often????
Best Solution
posted on Apr 13, 2008
FixYa! (100)
ianmo
Rank:Apprentice Apprentice
Rating: 100%, 4 votes
Muccione - you are a star. Just saved me buying yet another digital camera afetr my second Sony developed this White Screen problem. Your solution worked brilliantly. Thanks. IanMo
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jul 27, 2007
FixYa! (100)
muccione
Rating: 98%, 93 votes
on the front of the camera, under the flash, two inches from the lens, hit this spot not hard just firm. Do it with the cam ON so you can see it work. Now if you want to fix it you will need to take it apart
Solution #3
FixYa! (100)
Guest
Guest
Rating: 0%, 0 votes
muccione
Bedankt voor de tip hij werkt weer na drie tikken
Solution #4
posted on Jan 05, 2008
FixYa! (100)
t00nz
Rank:Guru Guru
Rating: 90%, 1020 votes
Solution #5
FixYa! (100)
ninglus
Rating: 94%, 7 votes
Muccione, you beautiful darling person! I selected a spot about 10mm below the flash tube on the front, and tapped it on the corner of a wooden table, and caplow! my lcd screen returned!!! How did you find this out?? Cheers, ninglus
Solution #6
posted on Jul 30, 2007
FixYa! (100)
Guest
Guest
Rating: 0%, 0 votes
I didn't believe it, but simply pressing the spot "muccione" mentioned restored my screen.
Thanks again "muccione"!
You helped me see the pics of my 2yr young nephew treating in the hospital.
Solution #7
posted on Aug 08, 2007
Helpful (85)
Guest
Guest
Rating: 0%, 0 votes
Hitting that spot worked.... I was ready to toss it in the garbage and buy a new camera.... THANKS....
Solution #8
posted on Jul 20, 2007
Helpful (85)
sonyspares
Rank:Wiz Wiz
Rating: 83%, 147 votes
If you need a new LCD pl.contact me.
sonyspares
Solution #9
Thanks for Trying (70)
jackboy
Rank:Wiz Wiz
Rating: 77%, 3620 votes
Sony Technical customer support is the place to go
Is it only just over a year old.
This is a hardware failure- connector loose or a firmware failure on the main board.
There will not be a repair by a third party firm available to you.
Sony- be nice to them - fib a little is it only just over a year
you will possibly get a total replacement or a 'swap out' for a small fee.
Solution #10
posted on Jul 27, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
It works for me to...thanks Muccione...it's unbelieveble...
Solution #11
posted on Jul 20, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
It works yipee
Solution #12
posted on Jul 13, 2008
Not Rated (0)
gruckhaber
Rating: 0%, 0 votes
Worked for me too, thanks!
Solution #13
posted on Jul 11, 2008
Not Rated (0)
lakebound247
Rating: 0%, 0 votes
I was on here to ask for help with my "white screen problem" as well, but thanks to Miccionne!! My problem is fixed! You're awesome!
Solution #14
posted on Jul 05, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
That Sony should front up and realise how many of their cameras are obviously doing this and have a recall of them. You only have to google "Sony Cyber-shot screen goes white" to see how many are doing it!!!!
Solution #15
posted on Jun 28, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
The sweet spot tap works! Pure genius, simple and effective.
Now can you tell me where to hit so I can lower my high cholesterol....
Solution #16
posted on Jun 09, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
thank you so much muccione, it works.
God Bless You
Solution #17
posted on May 12, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
your a bloody genius mate nice one!!!!
Solution #18
posted on May 05, 2008
Not Rated (0)
lavender12
Rating: 0%, 0 votes
thanks, Y'all. I tapped it and it worked. THANKS!!!!
Solution #19
posted on Apr 30, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
worked a treat thanks
Solution #20
posted on Apr 28, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
Muccione! Thanks, it worked!!
Solution #21
Not Rated (0)
aponylover
Rating: 0%, 0 votes
Miccionne,
Thanks for the info regarding the "sweet spot".
It worked like magic!
Just wish I were brave enough to open the camera for the permanent repair.....
THANKS for saving me from purchasing another camera!
Can you Help with these Digital Cameras problems?
digital camara
can you switch pictures that... Answer This...
my sony cyber-shot will not let...
every time i turn it on it only... Answer This...
LCD is just pure white
Lcd is pure white, cant see... Answer This...
Display problem
in my camera, display is not... Answer This...
lense
When I shut off the camera the... Answer This...
9 Other Users Have The Same Problem - Continued
When I on my camera a question arise to set the time and date every time. And when I take stills itz seems to be white and lines all over the screen.
Comment by Haile, posted on Jan 01, 2008
My DSC-S40 is still white after many trials.
Can't take photos.
Power is on. But scree is white.
Regards
Comment by MartyAz, posted on Jan 01, 2008
Sony DSC-S40 Permanet Fix (White LCD Screen) - How can I safely open the camera's cabinet?
Comment by Cfeierabend, posted on Dec 30, 2007
Amazing! My screen just all of a sudden went white. So I got out trusty google, found this site and tried hitting my camera in the 'sweet spot' and BAM like magic it works again! Thanks alot guys you are awesome!
Repair Service
Find Digital Camera Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
