Question about Maytag Neptune MDE5500AY Electric Dryer
The maytag dryer mde6700azw gets too hot and keeps on blowing the thermal fuse.....it works ok for about a week and it repeats itself?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 169 Answers
Make sure all air flow passages are clear. On both sides of the fan, the incoming air vent and the exhaust air vent, all the way to out side of the home.
Posted on Jan 22, 2013
SOURCE: Dryer does not start - Thermal Fuse is ok.
My Maytag Electric Dryer stopped working mid cycle and wont turn on at all now. Any ideas?
Posted on Jan 06, 2009
  • 686 Answers
SOURCE: Thermal fuse in Maytag PYE2300AYW not plugged in
NO. YOU ARE OK YOUR DRYER SHOULD ONLY HAVE A HIGH-LIMIT AND A CYCLING THERMOSTAT. YOU CAN LOOK AT YOUR DRYER PARTS AT www.repairclinic.com ENTER MODEL NUMBER SCROLL DOWN ALL THE WAY CLICK THE RED 100 AND SEE ALL.
Posted on Apr 13, 2009
  • 492 Answers
SOURCE: where is the thermal fuse located?
In the back of the dryer. Look for the coiled heaters and follow the lead wires back to the fuse.
Posted on Apr 30, 2009
  • 2180 Answers
SOURCE: Maytag performa Keeps blowing Thermal Fuse. Vents
something is still plugged with lint,if the vent line is long blow it out with a leaf blower to clean it out,you have to clean out the duct that the lint filter slides into,if the filter is on top remove the vent line,remove the back panel,remove the lint filter and the two screws in front of it and remove the four screws and clean out the duct,if the filter is in front take off the bottom panel,remove the filter and clean the duct,also vac out the inside of dryer where the motor is,when the dryer gets to hot the thermal fuse pops as a safety so you still have a block somewhere
Posted on Mar 19, 2010
SOURCE: Maytag electric dryer Model-Pye2300AZW did
The air flow past the thermal fuse is too hot. The air flow cools the heater coil area. Check the air passages from the lint filter to the heator coil housing for lint balls blocking the flow and letting the area around the fuse get too hot.
Posted on Dec 01, 2010
My gas clothes dryer is working,but it is not blowing hot air
The thermostat or thermal fuse could be blown. Usually happens when lint buildup blocks the exhaust exit & the heat stays inside the machine. So to prevent a fire, the thermal fuse or thermostat blows. You would have to enter your model # on google to find links to parts breakdown.
Sep 13, 2014 | Maytag Dryers
Maytag Bravos XL Dryer not heating- blowing thermal fuse
The thermostat is controlling the temperature, however the Heating Coil may be defective. Check the COIL.
Feb 27, 2014 | Maytag MEDB950YW Electric Dryers
Neptune dryer MDE6700AZW over heating and blowing the thermal fuse.....air flow is good no blockage what so ever?
You will need to check the air passage on the incoming side of the fan also. Most will check the exhaust side and clear it out, but if the incoming side has obstructions it will not allow air flow either.
Jan 21, 2013 | Dryers
My dryer keeps blowing the thermal fuse help
Check your lint filter, exhaust duct, and check if duct flapper is opening fully or not. Allow some time between loads and don't stuff too many clothes.
May 12, 2012 | Maytag MDE9700AYW Neptune 174 Electric...
Maytag prestige dryer quit mid cycle no power
Your unit has a thermal fuse on it, that blows when it gets to hot. BUT that is an indication that something else is wrong. A blown thermal fuse would cause your symptoms.
Jan 23, 2012 | Dryers
Dryer won't run
thermal fused are one time fuses / maytag want's you to correct the problem that causes this . so dryer is safe. hi heat caused it to fail . so either the fan is not going or there is a restriction causing no air flow . try running the dryer off the vent if it works ok then clean the vent ,, hope this helped . pls leav feed back mm
Dec 14, 2009 | Maytag PYE2300AY Electric Dryer
Dryer runs but will not heat. Replaced fuse and
your cycling thermostat needs changed too. the thermal fuse is your last safety measure that goes, which means your cycling thermostat is not shutting down the heat element once it detects the right temp hot air in the blower housing so it let the heat element glow until either the high-limit sensor shuts the heat down or the thermal fuse blows. Change the cycling thermostat and good luck
Mar 06, 2009 | Whirlpool LER4634J Electric Dryer
My dryer smells hot and shuts off it is a Maytag model LDE8406ACE
This happens when the dryer gets too hot and a thermal breaker (or thermal fuse) kicks in. The most likely problem is that the exhaust vent for the dryer is plugged up with lint either within the dryer itself or in the part that is in your wall and exits someplace outside (could be as far as the roof). When the hot air can't escape the dryer overheats and shuts itself off to prevent a fire.
Sep 22, 2008 | Maytag Dryers
Dryer Thermal Fuse
air flow could be the issue or if your heater itself is grounded against the cabinet i think your unit is getting to hot check all your vent lines if you have good air flow check the heater try taking the vent totally off for a few cycles and see if the fuse blows agian
Mar 15, 2008 | Kenmore 64902 Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
118 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
