Question about Apple QuickTime
Quicktime .MOV file error 2048 when opening
'"QuickTime does not understand the file"
I have raw .MOV file which I cant open in Win Vista.
Any reccomendations?
Jay
  • 10 more comments
  • Jaymie Knight Jan 29, 2009
    n/a
  • Jaymie Knight Jan 30, 2009
    Hey Ekse,
    I did what you did, ie. Install latest Quicktime and then the codec mentioned then double clicked the file and no luck. What is your email please?
    Hey Ekse,
    jaranya8
    Installed the QTLite and then uninstalled Quicktime (latest version) then I double clicked the file and no luck....just reinstalled Quicktime, same error.
    praky16
    Dowloaded the latest version of Quicktime already and still the file does not open.
  • Jaymie Knight Feb 06, 2009
    mikemilw
    VLC Media does not play the file at all. It simply opens the file and the bar quickly goes along to the right, no sound or footage. GSpot does not give me any info, it displays only: File Type: Unknown and Mime Type: Unknown.
    MrScary66613
    The file was created last week. Please keep on trying.
    Ekse
    VLC player does not play the file. The file in GSpot brings up unkown conent and unknow mime etc.. The player simply has the small bar move across to the right very quickly wiht no footage or sound.
    No luck! thanks for trying, I followed it very carefully. The file is available on:http://www.geocities.com/knightsleep/ope...
    Jaymie
  • Jaymie Knight Feb 08, 2009
    machadojr_fe
    Done this, it does not pick up the file format of my file. Thanks for trying
    godspeed808
    Does not work! check out:http://www.geocities.com/knightsleep/ope...
    godspeed808
  • 217 Answers
If you have tried all the above steps and still no go consider converting the file into a different format using a converter software and then try to play.The one I would recomend is super converter and can be downloaded from the follwoing link:
http://www.erightsoft.com/SUPER.html
Posted on Feb 08, 2009
    Scholar:
  • 125 Answers
This is a simple case of the wrong viewing software download free viewer at this address for raw files:Picasa software free download
http://picasa.google.com/#utm_campaign=en&utm_source=en-ha-na-us-synsearch&utm_medium=ha&utm_term=raw%20file
Posted on Feb 06, 2009
  • 916 Answers
Please go to this site and download the and install the codec pack: Click Here
Once you have done that please open the file with media player classic which is included in the pack
    President:
  • 1,902 Answers
This fix was posted by Janek in this topic:
ANSWER:
Having being frustrated and looking everywhere for almost 10 hours straight I had accumulated enough imformation on all 2048 error occurances I could write a book. So since it seems no one has written an affermative answer. I’ll post what worked after my research.
1st: I must thank all internet users out there because It wouldn’t have worked if not for them. They gave me hope!
To start:
Rename all your files that quicktime can’t read, to .wmv all occurances of the -2048 error come from codec misuse by the mis-naming of the 'quicktime' files.
Then download any transcodal translator. I used VLC Player, which can do pretty much anything.
VLC Site: — > http://www.videolan.org/
Once downloaded you’ll find it can play your 'broken files'.
Proceed to click on File — >Streaming/Exporting WIzard...
Go through: 'Transcode/Save to file'
Then: Select either select streaming file from location:
Or:
Select File from existing playlist. (Open(ed) files)
Last: Select how you want it TRUELY encoded as anything from mpeg4 video and audio to DivX to H. 264 to Theora REMEMBER: select the transcode buttons.
(Don’t forget bitrate has an extreme importance the more bits the higher quality but it comes at a price as the video becomes larger. It won’t be 100% quality, maybe 95% max; usually around 85 - 90% normal quality.)
Next: select your encapsulation method you want this to match your codec so please match them, it causes less problems.
Almost Done: Select a save location and wammo your done!
    President:
  • 1,990 Answers
Welcome to Fixya! It sounds like this File was Created Quite a While Back. If so, It may not be Playable if it is Too old and was done with Obsolete Codecs. Please Rate My Response! Thanks!
  • 10,515 Answers
  Error code 2048 refers to Bad Encoding.
There are certain coding that Initial or default download do not have.You need to download coding for Quicktime from websites like :-
http://www.download.com
 Or
 You can directly uninstall the previous/installed version and download the latest version that have all the codes you require to play .mov files.
 The link for the UPDATED Quicktime is :-
http://www.apple.com/quicktime/download/
Copy the above link, paste it into the browser ,Enter.
Install and it would fix your issue.
Thanks and Regards, Taran. ( 24 by 7 Support )
Posted on Jan 30, 2009
    Master:
  • 416 Answers
Check this link. You can compare all of these palyers and chose which is right for you
http://www.techsupportalert.com/best-free-windows-media-player-replacement.htm
But for MOV files I would recommend Media Player Classic
You can dowload it here
http://www.download.com/Media-Player-Classic/3000-2139_4-10518778.html
Good Luck
  • 537 Answers
Use a program like GSpot to see which video codec was used to create the file. Once you find that, install that codec on your PC.
Another suggestion I found was to play it using VideoLan:
  • Mike McWhinney Feb 06, 2009
    May I suggest the possibility that your MOV file is corrupted. I would look at a utility to recover or repair the video from the file you are dealing with.
    Here are some links:
    http://video.software.informer.com/downl...
    I don't know if VirtualDUB can open MOV files (I think it is primarily AVI files), but you could try that too to see if that may work
  • 744 Answers
Hi.. u can find the vide codec in this website www.filehippo.com.. u can download the codec in this website and then try to play the .MOV format file.
  • 238 Answers
Try QuickTime Alternative 2.8.0:
http://www.free-codecs.com/download/QuickTime_Alternative.htm
    Brigadier General:
  • 5,158 Answers
If you are using a mac... download this program
http://www.mplayerhq.hu/design7/dload.html
Robert
  • 101 Answers
You have to get the download extensions from quicktime site itsself
  • Apple Master
  • 13,433 Answers
  1. Get the latest quicktime available http://www.apple.com/quicktime/download/
  2. Install FFDSHOW http://www.free-codecs.com/download/FFDshow.htm
  3. Verify the file is undamaged and working.
You could email me the file and I could look into if its not too big.
  • 2 more comments
  • Ekse Jan 30, 2009
    You should have my email address already jaymie its nikoht@gmail.com
  • Ekse Jan 30, 2009
    Lee is right, it should play with VLC media player.
  • Ekse Feb 06, 2009
    Hi again,
    as we have discussed about this over email.
    The Mov file is a empty container, there is noting inside the file.
    it is filled with 00 00 00 00 00 00 00 00 00 - 60 MB of 00 00 00.
    There is no video, no data, no noting to read on the file. you need to contact the person and get a new copy of the file.
  • Ekse Feb 09, 2009
    hi again jaymie, I downloaded the mov file again. and it still is full of zero zero zero
    and to compair the internal contents of the mov file to another one that is working.
    this is a small picture due to fixya but, if you look closely its full of 00000000000000000000000000000000000
    and below it is another fully working movie file which is anything else but 00
  • 4,472 Answers
Try downloading VLC player and see if that helps at all. If you need further assistance let me know. Also please take a moment to accept and rate my solution accordingly.
Thanks,
Lee
2 Suggested Answers
Fardinfard
  • 392 Answers
SOURCE: Quicktime .MOV file error 2048
I suggest you to install DivX on your system and play it. or play it by different player like real player or jet audio
Posted on Feb 10, 2009
Which video format is most preferred for QuickTime? can i convert wmv to mov format?
MOV is a commonly used format.I think MOV/MP4 format is suitable for QuickTime,WMV means windows media video which is most preferred for windows apps.QuickTime apps provide by apple,some apple apps are not supported other OS apps format file.so i think MOV/MP4 format is a best for QuickTime. http://www.aimersoft.com/convert-mov/convert-quicktime-mov-to-mp4.html
Apr 20, 2013 | Apple Audio Players & Recorders
Tip
Mac MXF to MOV Converter-Convert MXF File to QuickTime MOV on Mac OS X
Best MXF to QuickTime MOV Converter on Mac OS X <br /><br />MXF is a "container" or "wrapper" format which supports a number of different streams of coded "essence", encoded with any of a variety of codecs, together with a metadata wrapper which describes the material contained within the MXF file. MXF has been designed to address a number of problems with non-professional formats. MXF file format is not compatible with many programs. So you may have problem to play, edit or use these format. So are Panasonic HVX200/HPX300 MXF files, P2 MXF files. <br /><br />Apple QuickTime movie is stored in the format of Apple QuickTime (.mov, .qt) which is a file format for storing and playing back movies with sound. Though developed and supported primarily by Apple Computer, the format of Apple QuickTime isn't limited to Macintosh operating systems. Apple QuickTime is also commonly used in Windows systems, and other types of computing platforms. In Windows, QuickTime movies usually appear with the .mov filename extension. <br /><img src="mxf-mov1.jpg" /> <br />With Aunsoft <b><a href="http://dts-ac3-converter.com/2011/07/mac-mxf-to-mov-converter-convert-mxf-file-to-quicktime-mov-on-mac-os-x/">Mac MXF Conversion</a></b>, we can convert mxf file to QuickTime MOV on Mac with best quality, fastest converting speed, excellent A/V sync and so on. And we also can use the Mac MXF File Converter to convert mxf file to friendly video formats just like mpg, wmv, mp4, mov, mpeg, dv, etc for playing on iPad, iPod, iPhone 4, iTunes, PSP, Apple TV, Android Phones, etc so that we can watch our favorite mxf conversion file everywhere. <br /><br />Follow the step to <b><a href="http://www.aunsoft.com/video-converter-mac/">convert MXF files to QuickTime MOV</a></b> on Mac now. <br /><br />Step1: Download and install the <b><a href="http://download.aunsoft.com/video_converter_mac/videoconvertermac_setup.zip">best Mac MXF File Converter</a></b>, add your MXF file by clicking "Add" in the File menu or in the main interface. <br /><br />Step2: In "Format" drop down list box, you may select output format. The software allows setting different output formats according to different files. For example, I just set the QuickTime MOV as output format of the MXF file. <br /><img src="convert-mxf-to-quicktime-mov.jpg" /> <br />Step3: Now let's select the output folder by clicking the "Output folder" icon. <br /><br />Step4: Finally, click "Convert" in the main interface. After a successful conversion, click "Open" to check the QuickTime MOV files. <br /><br />If you're interested in converting MXF files to QuickTime MOV on Mac without losing quality, please visit: <b><a href="http://www.aunsoft.com/mac_mxf_to_quick_time_mov_converter_convert_mxf_files_to_mov/">Best Mac MXF to QuickTime MOV Converter</a> ; <a href="http://www.aunsoft.com/convert_p2_mxf_to_quicktime_mov_for_fcp_on_mac/">Convert P2 MXF to QuickTime MOV for FCP</a> ; <a href="http://www.aunsoft.com/edit_mxf_in_avid_media_composer_convert_p2_mxf_to_wmv_for_avid/">Convert P2 MXF to WMV for Avid</a> ; <a href="http://www.aunsoft.com/edit_mxf_files_in_adobe_after_effects/">Edit MXF Files in Adobe After Effects</a></b> .
on Jul 13, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Tip
MXF to Quicktime Mov Converter - Convert mxf file to Quicktime mov video on Mac...
MXF to Quicktime Mov Converter Mac, why do you need to convert mxf file to mov? How to convert mxf file to Quicktime mov on Mac with the Mac MXF file to Mov Converter so that you can watch your mxf video on mac by QuickTime?
MXF file format comes from like Panasonic HVX200/HPX300, Canon XF300/XF305, Sony EX camera, etc. It is not compatible with many programs just like Apple QuickTime. So convert mxf file to Quicktime mov video is a necessary step to do if you want watch your video from your camcorder which export mxf file.
Mxf file to Mov Converter Mac is the best partner for you to convert mxf files to mov on mac, just need several simple steps, you can convert mxf file to QuickTime mov video and then preview mxf file by QuickTime. Do you need the best mxf to mov converter for Mac? Just choose this powerful Mac MXF file to QuickTime Mov Converter, enjoy yourself.
http://www.4yousoft.com/how-to/convert-mxf-file-to-quicktime-mov-on-mac.htm
on Aug 04, 2010 | Computers & Internet
Cannot play MOV video and the problem was MOV Codec mot installed to the laptop
The first solution is download Quicktime in Apple official website. And the second one is just get this video converter to convert your video to MP4 or WMV format and play with Windows Media Player.
Mar 01, 2011 | Compaq Presario Notebook
I cant watch my mov video on my pc.i have a vista and it works fine before on my mov videos.its just suddenly when i tried to watch 1 of my video and i cant open it.it says my quicktime has been change or...
This is a quite simpe work around...
just download and Install VLC Media Player and that will play it.
Right click on the mov files, then click on Properties and select open with as: VLC Media Player.
You will get it from:
http://www.videolan.org/vlc/
Jan 03, 2010 | Apple QuickTime
Quicktime
You can try the following,
1) Navigate to library, it will be in your main drive.
2) Remove all files from the QuickTime*.PKG, where "*" is your version number. This tells you that those packages are not installed.
3) Click on the "download Quicktime" link. DO NOT USE THE AUTOMATIC UPDATE UTILITY. Download QuickTimeInstallerX.dmg. Double click this file (probably on your desktop) and then invoke the installer by double clicking QuickTime701.pkg.
4) Restart the computer.
Regards,
Shrey
Dec 21, 2009 | Computers & Internet
Error 2048 could not open .mov
i facing error 2048 problem pls solve
Jan 31, 2009 | Apple QuickTime
Quicktime .MOV file error 2048 when opening '"QuickTime does not understand the file" I have raw .MOV file which I cant open in Win Vista. Any reccomendations? Jay
Jan 30, 2009 | Apple QuickTime
Cannot view the movies I made on my camera and downloaded to my Vista PC
I assume you can view them in you camera, right? If not, the following solution will not help.
The .MOV Apple QuickTime format Panasonic uses for its camera movie clips cause problem on with viewing, as seen from several other problem posts here and the net.
Some computer use a Win 32Bit operating system, other better ones use a Win 64. It is hard to believe QuickTime would let you load a 64bit version into a 32bit OS, or vice versa. But who knows. Rather double clicking on te file name itself, open QuickTime, then go to File Open and Browse to the file and select it that was. If this doesn't work, go to QuickTime website and try their User Forums first to ask a question or find a thread talking about movie files not playing. Else, CONTACT website and ask question. Post any solution here for readers.
Feb 12, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Apple QuickTime Logo
1,698 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
