Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Philips 60PP9202/17F Blue Problem
I just paid a repiar man to replace both convergence chips and four resistors and now I can not seem to get a blue color. Everything that should be blue is a green tint to it.
  • kevles Jan 27, 2009
    Ronnieh49...thanks for the reply. I did call repairman back at 10:00pm last night thinking I would get his machine at the shop (he answered). He drove a half hour and worked on the set until 12:30 this morning, and still can not figure out what is wrong (he twisted all the adjustments in the back). We can only get either a full "blue" cast on everything, or when the settings look good for "fleshtone or the other reds", the area's like the sky are green. After paying $400.00 I am stuck with a set that can not even show a blue sky!!!
    Genius:
  • 2,920 Answers
Call the repairman back and tell him the tv isnt fixed correcctly. have him come back and finish the work he started
Posted on Jan 27, 2009
My red convergence won't move side to side only up and down what do i do? the blue moves up down and side to side, i noticed this when the picture as we were watching it decided to turn 3d, so i tried to...
Most of these Philips sets use two STK-392-120 convergence IC chips; if you can locate them inside look at all the little blue resistors to the left and front of them---these are feedback (protect) parts---if any of them are discolored in the middle--not powder blue but somewhat white in the middle---you have a bad ic and both need to be replaced---most of the protect resistors are 6.8 ohm in value. If this has been helpful give me a vote.
Aug 14, 2009 | Philips 60PW9363 60" Rear Projection...
Philips Magnavox 55P8288 Entire picture has green
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 09, 2009 | Philips Magnavox 51MP392H Rear Projection...
Blue haze on the lower part of rear Projection TV
  • Screen looks 3D
Mar 23, 2009 | Philips Magnavox 51MP392H Rear Projection...
Blue color is ober screen
It may be the fluid in the CRT or convergence chips are bad.
  • Screen looks 3D
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Jan 30, 2009 | Philips 46PP9302 46" Rear Projection...
Convergence will not line up after replacing ic & resistors
Did you replace the resistors when you replaced the convgence chips? If one of them was bad you would still have the problem.
Here are some of the most common symptoms and example photos.
  • Screen looks 3D
2c07611.pngSolution
Jan 03, 2009 | Philips 51PW9303 51" Rear Projection...
Philips 60PP9502 60" TV has problem with Red convergence or red and blue fringes
You will need to replace both convergence ICs they are both STK392-120 and you will also need four 6.8 ohm 1 watt resistors. you can get the Convergence ICs and resistors at the following link and they provide free instalation instructions with pictures so you can do the repair yourself. Here is the link.
http://servicemanuals.vstore.ca/
Jul 06, 2008 | Philips 60PP9202 60" Rear Projection...
60PP9352 60 in. Rear - Blue convergence issue
Replacing only the ICs MAY solve the problem, however, many people have also had blown resistors requiring replacement. Also the convergence board should be checked for cracked solder. If you replace the ICs and the resistors are shot, the ICs may blow again almost immediately, meaning you may have to do the repair twice.
You do not have to replace any transistors to fix this convergence failure.
May 28, 2008 | Philips 60PP9352 60" Rear Projection...
Convergence problem???
Check the resistors by the STK ic's, should be 2.2 ohms. Under the heat sink, also check the 1.8 Ohm 1W, fusible resistors found around the area as well.
Good Luck.
Feb 05, 2008 | Toshiba 50H72 50" Rear Projection...
Phillips 60PP9202 Convergence Problems
The two convergence IC's are generic part# STK392-120 (Philips original part# 932212344682) The two resistors are sitting side by side (6.8 ohm 2 watt)
Sep 15, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
177 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
