Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
Need drain gpm specs - Kenmore 3.2 cu. ft. Plus Top Load Washer
  • Kenmore Master
  • 17,129 Answers
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged. Now remove the drain hose clamps and remove the drain pump/valve, clean the drain pump/valve, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Posted on Jan 22, 2013
How to set up the pump for the waterfall
you will need a pump that has a greater ability to pump water thru two or more nozzles , this pump spec is known as (GPM) this number needs to be greater than all the nozzles gpm , second pump spec goes hand in hand with the first spec and that's LIFT the pumps lift (head pressure) needs to be greater than the height of highest waterfall plus 2 inches , id suggest using two valves after the pipe Tee from pump to restrict flow to the lower of the two outlets (water seeks its own level ) so the lower of the two or more outlets will receive all the flow , and last but not least the PIPE or tube size needs to be of large enough size to handle all the flow needs of your pump ,simple std pipe size flow rate charts are avail on internet easy enough so I wont go into that
Aug 24, 2015 | Garden
My Intex pump (sf 20110) has broken. Neighbor has a pump that will do 40-50 gpm (XL-VI pump model 16841 by Swimquip Inc.)with 3/4 hp AO Smith motor. Is this pump compatible with the sand filter?
The More Important Question... What sand filter do you have?
This model of pump will move around 35-55 gpm,
that may be too much for filter?
It can or will break the lateral drain assembly inside the tank, if flow is too great.
. Especially if it is an Intex brand.
May 26, 2015 | Intex Pool & Spa
Eratic hot water flow
Bosch 1600H NG??? I suppose. If so you need a digital manometer.
Take a static (off) reading then leave it hooked up and start flow. Watch pressure draw down and you should see the heater draw Water Column down below 5" as the pocket of NG in the pipe just before the unit draws down to minimal to keep heater lite. In that case problem in gas line size/gas line run length, Meter pressure.
If you have and maintain in operation 5" WC then is probably the water valve needs rebuilt along with a new diaphgram and also the water filter should be replaced too. This occurs esp after 2-3 year as Bosch specs rebuild at 3 yrs on the Maint Schedule. Also clean all the faucet aerators for good flow above 1.25 GPM Min at all faucets.
Under a single faucet flow (laundry sink) of 2.25 GPM the flame bed of the Unit should be 1"+ high and uniformly Blue.
I assume at this time you either have a Maint problem or you could be overflowing the heater's Winter capacity. This unit @ 70F rise only makes about 2.2 GPM. It's strictly a single use faucet heater at 117,000 BTU.
When you do the Maint look to see if there is corrosion between the GV pushrod and the water valve pushrod. Notice there is a huge mis- match in the 2 rods sizes.These units occasionally (more the 125B) corrode there and the GV will seize on and boil the heater dry and open a seam so you really want to maintain it to Bosch Specs and Schedule.
Note: This is a gas appliance & requires skill and knowledge to service. While Bosch may say you can DIY, I'd readily advise a Bosch approved Service Tech or Plumber do any rebuild. The Digital Manometer alone is a $100-150.00 item and it's the ONLY way to get accurate gas pressure readings.
Mar 14, 2014 | Bosch 1600H-NG Natural Gas AquaStar...
How many hours should my Coleman Powermate PM0543000.01 run on one full tank?
That is directly propertional to the amount of load. Most OEM's on their specs will say how many gpm it will take under 1/4,1/2 full etc
Aug 02, 2013 | Coleman Powermate Powermate 5000W...
Where to find needed parts/costs?
You've given the specs of the power washer, but what make and model is it?
Jun 13, 2013 | Garden
Water is draining from pool iwth Rike 1800 pool pump, but flow is very slow and weak and definetly nothing like 1800 GOH
How long is the hose the pump is connected to?
What is the inside diameter?
With no hose, the pump gives 1800 gph, 30 gpm
with lots of small hose, that could drop to 5 gpm.
Ensure no debris in inlet or hose.
Gary
Sep 24, 2011 | Rule 1800 H53SP-24 Swimming Pool Cover...
How far will a 1 HP jet pump jet.will it jet at 125feet.if so how much gpm and what size jet do I need
That is quite a large distance to pump for most electric pumps. We had a gas 8-10 HP firepump which was used to pump out of several 6" steel cased drilled wells on a ranch. It was a KUBOTA with high performance " high head" design which gave both lots of water for fire control and the ability to do the work of raising water a long way up a hill if needed. The clearance between the impeller and the case needs to be very small so expensive machining is involved, possibly even "Crane" seals with spring loading and sliding nitrite discs instead of just a bronze bushing in a so-so aluminum casting. All pumps will have specs for GPM but they shy away from giving you a graph of GPM versus Pump Head at those 125 foot amounts, the KUBOTA states the chart right away since it is a very high GPM pump in those high water lift conditions. Residential jet pumps just build designs for a lift of 40 feet or less so they might even stall out at half of your requirements. You might even think of the old DURO pumps from CANADA with a 1/3 HP GE motor and use two pump houses with electric power and small 20 gallon steel pressure tanks to relay the water in three steps from the source. I purchased two of them for rebuild for $50 and you can fix them up easily using Generic Chinese piston pump parts which are an almost exact fit copy of the DURO.
Jun 04, 2011 | Hardware & Accessories
What is the minimum GPM's for a Rheem tanklers water heater to work? I can only run the shower by itself. Also can I install an outdoor tankless Rheem in an area where it gets down to -10 degrees F ?...
Rheem makes a number of tankless models
http://www.rheem.com/products/tankless_water_heaters/
They make a tankless 95 outdoor series
http://www.rheem.com/product.aspx?id=EBA80FAA-3C0F-411D-AF83-82061C28ED1B
The 95 outdoor series spec sheet says .4 GPM minimum activation and .26 GPM flow to keep burner activated. The colder the incoming water, fewer users can take a shower at once.
http://globalimageserver.com/fetchDocument.aspx?id=ea5f0816-dfd4-4bcf-a605-79945619f5bb
The .4 GPM and .26GPM numbers are fairly typical for tankless units.
These numbers are good when the unit is new.
After a few years the number may be different because the tankless is a high-tech machine with sensors that are susceptible to particulate in the water, and susceptible to perfect-functioning of other parts in the machine.
The outdoor series spec sheet says the tankless is good to minus 30 F.
But remember that's when the unit is new.
Outdoor tankless water heaters have an electric heater that keeps water pipes inside the unit from freezing, as long as electricity is ON.
If electricity goes off, the house stays warm inside for several hours.
But a steel box located outside would get cold immediately without electric heat.
The electric heater adds standby cost to operational expense.
The tankless has a heater, but you still have to protect the incoming and outgoing pipes.
If your incoming water is very cold, the tankless heater may not be able raise the temperature fast enough to give two showers -or- even 1 shower depending on age and efficiency and capacity.
You can add a tempering tank located in naturally warm area that passively pre-heats incoming water before it enters the tankless burner.
It might be best to locate tankless inside the house >> and use direct vent through the wall for both incoming air supply and outgoing vent gas.
If incoming air is taken directly from the living space, then tankless will draw air into the house through cracks and around doors.
A lack of sufficient air, or poor air quality can cause the burner to shut down.
When buying a tankless, read the spec sheets and really ask questions about everything you don't understand.
Oct 24, 2010 | Rheem RTG-53PVN Indoor Natural Gas...
Looking for specs
You can get from BJ Hydraulics 269-623-6743
Jan 07, 2009 | Danfoss Sundstrand-sauer-danfoss...
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
56 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
