Question about GE GSH22JFR Side by Side Refrigerator
Freezer/Frig will not get Cold
"I have a GE Side by side frig GE22JFREWW that will not cool. The lights come on and the fans are running but the cooling element does not get cold. No clicking can be heard on the motherboard. Where shoud I look next?"
  • 5 more comments
  • Scott
    Scott Jan 27, 2013
    I got back to my project today and noticed that the compressor is no longer running. Both fans are still running. I am not sure how to check the voltage. There are three wires going into the compressor Orange, Black, White. There is a small black box to the left of the compressor that is not directly connected other than the orange wire. I checked the two leads and there is no continuity. I checked both sides of the input and exit wires and get no voltage reading. ?? Bad Compressor? Bad Mother Board, Bad Relay???
  • Vince Pilgreen Jan 27, 2013
    You might check to make sure it did not trip the breaker in the house panel. Sometimes when a compressor shorts out that will happen. There is a possibility the safety limit has failed completely, this will kill power completely too.
  • Scott
    Scott Jan 27, 2013
    I think that I have it narrowed down to the Start relay. The contacts look burnt inside the box. Or the start capacitor. I may just order them and see what happens
  • Scott
    Scott Jan 27, 2013
    I replace with a three in one. The compressor started vibrating but no temperature change. Both tubes coming out of the compressor are about the same temp.
  • Vince Pilgreen Jan 28, 2013
    Did the compressor run for a long time? Did it shut off again?
  • Scott
    Scott Jan 28, 2013
    I let the frig run for at least an hour with no notable changes, compressor still running but no change in temps noted on compressor, tubing, or freezer.
    If the valves are bad in the compressor it will not pump and you will not be creating any heat on the lines. There is a possibility you may not have any freon also. The only way to know is to install a piercing valve and see if there is pressure in the system.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 169 Answers
Check the compressor to make sure it is running. If not then check to make sure you are getting the proper electrical supply to the compressor.
Posted on Jan 22, 2013
  • 2 more comments
  • Scott
    Scott Jan 22, 2013
    The compressor seems to be working. Slight vibration felt. Temp on the two tubes are about the same temp which are ambient (its cold in the garage where I am working on it.)
  • Vince Pilgreen Jan 22, 2013
    If the compressor is running and both lines (tubes) are the same temperature it seems there is not freon being pumped by the compressor. This could be because there is no freon in the system or the compressor has failed. Sounds like you need to find someone with a way of checking pressures on the system.
  • Scott
    Scott Jan 24, 2013
    How would I check to see if it is compressor failure. If it is a freon issue, it is not going to be worth me going any further to fix it.
  • Vince Pilgreen Jan 25, 2013
    Typically if the compressor is pumping and there is any freon, one of the lines from the compressor will be very hot, the other cold. It's hard to diagnose without the proper tools.
3 Suggested Answers
SOURCE: Side by Side GE Frig not cooling
Check the superheating of the evaporator.
Posted on Mar 22, 2009
Sea Breeze
  • 4654 Answers
SOURCE: my frig is running but not cooling - frig is 50
I can help you diagnose the problems with your GE. Several things can cause these symptoms. All you need is a voltage meter patience and a want to, to repair and do it better than a paid technician. In most cases with the PSS26MSRSS the defrost heater is the cause for this. Look into rear of your freezer and back wall. Is Ice or frost building on rear wall? If yes unplug and prepair to remove contents in freezer compartment. Remove rear panel in freezer and use hair dryer to defrost ice until the defrost heater is visible. BRB , Sea Breeze
Posted on Jan 23, 2010
Testimonial: "Thanks for the quick help - yes frost on back wall. Once I unload and defrost should I then take out defrost thermostat? "
Samsung RS2630SH Side by Side Refrigerator not cooling down frig or freezer
Is the compressor running? If so, feel the discharge line is the line cold? If not the unit is probably out of Freon, which means it will have a leak somewhere in the system.
Aug 25, 2014 | Samsung RS2630SH Side by Side Refrigerator
Refrigerator freezes
Sounds like might be the Temperature Control Thermostat or some sensor in the circuitry telling the compressor and cooling parts to keep running because it thinks it isn't cold enough. There is probably a circulation fan to blow the cold air through the damper and it may not shut off either, conveying too much cold thermal conduction through ducting and all frig parts, regardless of damper being closed or open. With the temperature set on low, do the compressor and fans ever shut off once cold temperatures are attained? Freezer should be 0 or lower, frig 35-40.
check this video at RepairClinic.comhttp://www.youtube.com/watch?v=5vA8Ksv5kVY&feature=player_embedded
Apr 07, 2013 | Electrolux Refrigerators
Frig side does not cool. freezer side cools
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Apr 16, 2010 | GE GSS25KGMBB / GSS25KGMWW / GSS25KGMCC...
My frig is running but not cooling - frig is 50 degrees,freezer 40 degrees, cleaned the coils,etc GE side by side coils in bottom if frig side feel cool, "box" between freezer and frig side is not blowing...
Jan 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Our ge refrig runs constantly,freezer is freezing but the refrig is not cooling. I cleaned the dust and dirt out of the bottom and back of refrig.
See if the fan in side the frig is working It mite be on the freezer side If the fan is not working it will not blow the cold air in to the frig side
Jul 12, 2009 | Refrigerators
Not cooling,lower part of the frig and freezer gets cold
You may need to set the Fridge side thermostat cooler or there may be a slide switch that allows ou to set the "bias" more toward the fridge side.
Jun 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a Kenmore Cold Spot fridge, freezer on top. Fridge is warm, and freezer keeps freezing up on sides and bottom. I cleaned it all out, defrosted it, and it still freezes up and fridge still won't get...
Is this a self defrost model? Frost inside the freezer could be an air leak around the door gasket. Remove the back panel in the freezer and completely defrost the coils. Is the fan running in the freezer. That will make the frig not be cool. With the door closed peek in the gasket to make sure the light is shutting off, this will warm a frig also.
Eric
Jun 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Mar 22, 2009 | GE Refrigerators
Frig side is not cooling.
Check if there is frost on the back wall of the freezer, if so it is not defrosting. Many GE fridges need a new defrost heater every couple of years. If it's not defrosting, you can get by for a while by unplugging the fridge and leaving the freezer door open for 24 hrs, then plugging back in.
Jun 30, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side frig: JSS22JEMC WW
sounds like defrost or fan problem let me know and I can help you
Apr 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSH22JFR Side by Side Refrigerator Logo
60 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
