Question about Panasonic Fisher Mt-729 Studio Standard Turntable. Tested And Working
MT-729 Fisher turntable
Turntable spins, tone arm doesn't move
2 Suggested Answers
johncaman
  • 201 Answers
SOURCE: Turntable will not turn (spin)
It would appear this is a belt drive turntable - here's a link to a site where you can order a replacement, although you may be able to find a cheaper one.
http://www.elexatelier.com/panasonic.htm
Hope this helps!
Posted on Mar 26, 2009
My Mt 750 Fisher turns on the table spins a moment but the arm does not move what is wrong?
What you have is a record changer; and malfunctions today are probably more likely that in the past--even after the prestigious Fisher name and price had been largely supplanted in the post war years--before mfg quality control as a customer fault under protection (for sellers) by Warranty dodges had come to the fore. (In actuality, while record changers would would have been favored by record producers--for the rapid rate at which they destroy records--they would have been looked upon with disdain by pro disc jocks as well as high-end audio equipment producers (including Fisher) in favor of single play turntables that don't destroy records that must be played "on the air," repeatedly, hundreds of times per week in successsion.)
1. Did you unclip the tone arm from its resting post?
2. Remove record and turn off platter (name for a turntable record support) drive motor, and unplug the player machine.
  1. While manually rotating platter in PLAY direction (that's CW), actuate PLAY lever to its extent, release, and watch for tone arm movement as you continue platter hand rotation.
    1. (Oh yes, make sure the record hold-down arm is up and rotated outward to prevent hold-down-arm drop from causing changer to return tone arrm to stow post and dis-actuating START lever...such features once accurately called "self stop,: today inaccurately called "auto stop."
      1. ...by the way, could your problem be that you did not lower hold-down arm onto record(s)? ...making the changer mechanism below the platter "think" that all records had been played...so that it swung and stowed tone arm and then Self Stopped the player rather than repeat-playing the top-of-stack record (in order to save changer and record wear and tear)? Is your problem now solved? Just in case not, continue...
  2. As you hand rotate and watch, the tone arm (and release spindle with no record on it) should "recapitulate" its normal, record changing and playing motions--you are simply "handing" in for the platter motor.
  3. If there is a "hitch in the changer's stride" (that means a jam) it will also occur and be felt operating the changer manually. At that point, you will have "set" the changer mechanism in conflict-fault position for facilitating inspection to find the specific problem.
  4. Note that since record-changer-/turntable-type players are permanently confined to level-only use, that means the turntable/changer platform need not be affixed to its base (some are--some aren't) so it might be possible to simply lift the turntable/changer platform assembly up off the base to inspect underneath. Some (possibly most) turntables/ changers, on the other hand, are apt to be fastened to the base (lest the furniture be bumped into...but those typically did little more than prevent tone arms from skating some ot the time) in a suspension arrangement (if not rigidly) that incorporates helical thrust springs and hold-down screws at each hold down point, typically 4 in number. Detaching the platform is apt to involve simply looseing and then over loosening the screws...or by some other obvious or not so obvious means.
    1. Being mindful of any hard-connected wires, unfasten, lift, and invert changer platform to inspect underneath.
    2. Take appropriate corrective action at point of jamming.
    3. Revert and refasten platform and re-run manual-unpowered operation to confirm corrections.
    4. Return power to player and test using a record.
    5. Thank yourself for posting your question...if all or some of the above works.
Oct 19, 2014 | Audio Players & Recorders
JVC turntable AL-E300 turntable slowing down when tone arm moves iacross
Even if the belt looks fine it's almost certainly the problem. You mentioned "cleaning" - if you got any kind of fluid on the belt it might act as a lubricant and reduce the friction between the belt and the drive wheel, causing the turntable to slow when the tone arm puts a drag on it. The problem may go away when the belt dries out.
Nov 23, 2013 | Audio Players & Recorders
ION Profile LP Vinyl-to-MP3 Turntable, tone arm won't drop
I've got the same problem. When you put therecord on, spin it from the centre, and it will release the mechanism inside,this is what I do, and it works fine. I think the problem is that there are twoplates under the turntable, and there was grease between them, after a few goesthe grease disappears, causing the problem.
May 22, 2012 | Audio Players & Recorders
Why does my turntable not spin when I move my Tone arm over?
Hi Daniel, its a bit of a long shot however try this. With the turntable powered of manually rotate the platter approx 12 times to reset the auto operation back to default. John styluscity.com
Nov 30, 2011 | Sony PS-LX250H Turntable
Received a Numark TT usb back in 2007. Just plugged it in for the first time ever. Installed EZ Converter on my powerbook, was all psyched to get going. The turntable powers on, but nothing happens when I...
Try moving the tone arm lever to raise the arm, if it has one.(MAKE SURE YOU HAVE RELEASED THE ARM CLIP!) Then with the arm raised move the arm over towards the platter. If platter still doesn't rotate, and its a belt drive, A. The belt is bad. or B. The belt has come off the platter or motor pulley.
Jul 31, 2011 | Numark ttUSB Turntable
Hi. I have a Crosley CR40 mini turntable. When I turn on the power, the vinyl spins but when the needle is placed on the vinyl, the vinyl doesnt move anymore while the spinner underneath it is still...
It sounds like you have too much pressure on the tone arm. Check the underside for springs. You might be able to remedy the problem the old fashioned way. Tape a coin onto the top of the tone arm, as far to the rear as possible. This will eliminate some of the downward pressure onto the record.
May 07, 2011 | Crosley Stack-O-Matic CR40 Turntable
I have a Califone 1620 model economy classroom phonograph in need
Probably a bad relay switch. Open up the turntable. Identify the motor that spins the table. Follow the wires of that motor to, perhaps, some type of little circuit board with a relay. I have a Backley-Cardy 322-487 classroom phonograph which uses a Califone 1620 amp and a BSR turntable. To get the table to spin, you have to move the tone arm. Mine doesn't move and I'm in the process of replacing the faulty relay that is the problem.
Sep 30, 2009 | Califone International 1030AV Turntable
Tone arm moves to the middle rather than the beginning
There is 33and 45. that's the size of the record.There should be a level to change from one to the other.
Aug 07, 2009 | Sony PS-LX250H Turntable
Panasonic Fisher Mt-729 Studio Standard Turntable. Tested And Working Logo
97 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
