Question about Canon WCDC58N Wide Angle Converter Lens Adapter for A710 A700 A640 A630 A610 A620 A720IS G3 G5 G6 Digital Cameras
How do i remove the adapter LA-DC58H lens from this lens
Canon g10
No. The LA-DC58K only allows you to use the TC-DC58K teleconverter with your camera.
The Tamron 28-200mm lens is intended for use with SLR (single-lens reflex) cameras, not with point&shoot cameras. As far as I know, there aren't any adapters which will allow you to use an SLR lens with the G10.
A teleconverter is an add-on accessory that works with an existing lens. The 28-200 is a lens, which is intended to be used as-is. Using it on the G10 would basically require removing the built-in lens on the G10. As that lens can't be removed...
Jan 05, 2014 | Tamron Cameras
Tip
Lens adapters beware!!..
I just purchase a new camcorder (sony Hd1000u) and order a lens kit with adapters for it, but not everybody has experience to how to install them.. Well.., it just about a bit of common sense. First be sure to know what size of lens your camera will use in my case I need to adapt my new 72mm tele-photo lens to my Sony 37mm. usually when you buy a lens kit they come with different adapters. I use a 37-58mm adapter for my camcorder. but be carefull, make sure that the adapter be place first in the lens to be use, in my case to my 72mm lens. Screw it carefully soft tight then screw in the lens of your camera. Do not ever screw the adapter first to your camcorder lens or you will encounter a big problem when you want to remove it later. Make sure you clean your lens before installing with proper lens cloth & solution. This tip will apply to just any camera with interchangeble lens system.0ccddce.jpg24a835f.jpg
on Aug 26, 2010 | Cameras
What's your pwill Tamron AF 1780 Lens 80mm - 210 work on a sony 200A dslrmmroblem?
you need a proper t2 adapter. when you remove the m42 adaptor on tair lens, you can attach the proper t2 to nikon adaptor on it. check my tair 300 photo. it has "t2 to m42" adapter on it. please be sure that find the correct adapter. i bought several adapters to find the correct one. one of them was different than t2 adapter but looking alike and sold as t2 by seller. it is hard to find the correct adapter. i guess there are variants of that standard(which is odd).
Feb 01, 2012 | Tamron 80-210mm f/4.5-5.6 Lens
How can I remove the adapter from the lens....... (Novoflex MFT/LEM with a Leica len)
The instructions come packed with the adapter. If you do not have the instructions you can contact us at 800 735-4373 in the USA to get a new set.
Jul 01, 2011 | Novoflex MFT/LEM Lens Adapter
Can you use a haze or UV filter on the Olympus SP-800UZ. what size would be used?
Yes it is possible with a lens adapter. Search for Kiwiphotos LA-67SP800 or LA-67SP800. Or look at: http://www.kiwifotos.com/Pro_show.asp?Proid=83
On Ebay they can be bought quite cheap. You can fit a filter onto the lens adapter.
Feb 12, 2011 | Olympus SP800UZ Digital Camera
How to install fisheye lens and adapter on kodak dx6490. Do I have to remove existing AF lens
No, you do not remove the existing lens. You need to purchase a lens adapter tube that fits around the existing lense. This adapter threads onto the inside bezel on the camera at the base of the lens assembly. Additional converter lenses and filters fit onto this. My adapter has 55mm threading for filters.
Oct 08, 2009 | Kodak EasyShare DX6490 Digital Camera
Stuck lens adapter
Try sending it to PhotoTech Repair Service in NYC. They are Nikon authorized, and can do the repair under warranty if you still have it. Also if you join they're facebook page, they will give you a 10% discount.
Here is the facebook page link, it has everything you need to send it in.
http://www.facebook.com/pages/New-York-NY/PhotoTech-Repair-Service-Inc/102527215194
Aug 07, 2009 | Nikon 50mm f/1.8 AF Nikkor Lens
Camera lense
There is a very very easy way to fix this problem..
This can happen if...
1.) If the battery dies when the camera lens is open (and you close it manually, or sometimes, even if you dont.)
2.) If you used a AC adapter with too much voltage or not enough. (this can happen even if you used the correct voltage, refrain from using AC adapters at all)
... all together its ethier a voltage or camera lens problem...
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
Hopefully all this information helped,
May 05, 2008 | Minolta Vectis 2000 APS APS Point and...
Lens cover only partially opens
This blog post outlines repair procedures for stuck lens covers. An A400 is used as an example. But it should be similar for the A430:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Mar 31, 2008 | Canon PowerShot A540 Digital Camera
Canon WCDC58N Wide Angle Converter Lens Adapter for A710 A700 A640 A630 A610 A620 A720IS G3 G5 G6 Digital Cameras Logo
14 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
