Turn off filter keys - Computers & Internet
  • Computers & ... Master
  • 27,725 Answers
The Filter Keys feature in Windows enables the system to ignore keystrokes that it determines are unintentional, such as when you press a key quickly or hold it down for too long. This is a particularly convenient feature if you are learning to type or have trouble typing. However, if you turn the feature on by accident, the system may mistake your typing style as mistakes and ignore some keystrokes. Open the Ease of Access Center to access the settings to turn the feature off.
Click "Start," then select "Control Panel." Click "Ease of Access" at the bottom right corner of the window. Click "Change How Your Keyboard Works" under Ease of Access Center. Uncheck the check box next to "Turn on Filter Keys" in the Make it Easier to Type section. Click "Apply," then "OK" to save the settings. Hope this helps.
Posted on Jan 21, 2013
The.spacebar.stopped..working.
If your space bar isn't responding when you press it, or if it responds sluggishly, it's possible that you have inadvertently enabled the "Sticky Keys" or "Filter Keys" accessibility option in Windows.
When these options are enabled, your keyboard response time will be dramatically slowed and may require more than one tap to register a keystroke.
Fortunately, it's easy to disable these functions and return your keyboard to normal working order.
Click "Start" and select "All Programs."
Click "Accessories" and select "Ease of Access."
Click "Ease of Access Center."
Click "Make Keyboard Easier to Use."
Click "Set Up Sticky Keys." Deselect the checkbox that says "Turn on Sticky Keys When Shift is Pressed Five Times." Make sure the box that says "Turn on Sticky Keys" is not checked. Click "OK" to save your changes.
Click "Set Up Filter Keys." Uncheck the box that says "Turn on Filter Keys."
Click on the checkbox next to "Turn On Filter Keys When Right Shift Is Pressed For 8 Seconds" to deselect it. Click "OK" to save your changes.
Click "OK" again to save all of the keyboard accessibility changes you have made.
Hope this helps
Oct 29, 2012 | Gateway LT2021u Netbook
Tip
How to Reset Your Air Purifier Filter Light
<span style="font-weight: bold;">Airgle Air Purifier:</span><br /> <ol> <li>Turn off and unplug the unit </li> <li>Press the light button to the "on" position </li> <li>Plug in the unit, and then release the button after the Filter-check starts</li> <li>The system will automatically reset the Filter-Check Gauge in about 25 seconds</li> <li>Once the procedure has completed resetting, please turn on the unit and press "Filter Check" button again.</li> <li>This time, the system should report an accurate result. </li></ol><span style="font-weight: bold;">Alive Air Purifier:</span><br /> <ol> <li>Insert a straightened out paper clip into the reset hole, with the unit off, and push the Timer button.</li> <li>You should hear a 2 beeps, signaling that the Reset was successful.</li></ol><span style="font-weight: bold;">Holmes Air Purifier:</span><br /> <ol> <li>Units which have an indicator light must be reset once the HEPA filter has been replaced. Reset indicator by inserting a small object (such as a pin or paperclip) into the hole marked reset.</li></ol><span style="font-weight: bold;">Honeywell Air Purifier:</span><br /> <ol> <li>Reset the filter indicator by pressing and holding the "Filter Monitor" button until the indicator light shuts off.</li></ol>or<br /> <ol> <li>With the unit powered on, press and hold the appropriate filter<br />indicator button down for approximately 10 seconds until the<br />light turns off.</li></ol><span style="font-weight: bold;">Hunter Air Purifier:</span><br /> <ol> <li>Change the filter and/or pre-filter.</li> <li>Now, you must choose which counter you want to reset. Press and hold the filter reset key (approximately three seconds) until the prefilter indicator flashes. Press and release the reset key again to alternate between the two indicators. The counter that will be reset is designated by the flashing indicator. For Models 36394 and 36395: Use the tip of a pen or pencil to press the key.</li> <li>Once you have the correct indicator flashing, press and hold the reset key for three seconds to reset that counter to zero hours. The indicator will stop flashing when it has been reset. If needed, repeat these steps to reset the other counter.</li></ol><span style="font-weight: bold;">IQAir Air Purifier:</span><br /> <ol> <li>To reach the Filter Life Reset function from the main display window, press the Menu key seven times.</li> <li>Press and hold the Enter key until the flashing cursor appears. Release the Enter key. The first filter selection to appear is the Pre-Filter.</li> <li>Press the Up Arrow key to select the filter that has been replaced. The Filter Life LED for the appropriate filter is now flashing red.</li> <li>Press the Enter key to confirm that the selected filter has been replaced. The filter life LED for the appropriate filter is now flashing red.</li> <li>Press the Enter key one more time to confirm the filter change or to exit without resetting the filter life, press the Menu key (M=Menu).</li> <li>Upon successful reset of the filter life, the new remaining filter life (taking the currently selected fan speed into account) will be displayed, and the filter LED light on the control panel will change from red to green.</li></ol><span style="font-weight: bold;">Kenmore Air Purifier:</span><br /> <ol> <li>Press the FUNCTION and OFF TIMER buttons at the same time for five seconds. The CHANGE FILTER INDICATOR will flash five times and turn off </li></ol>
on Jun 17, 2011 | Air Purifiers
How to turn off filter keys on my keyboard
Filter keys? That must be one of those new-fangled i-Keyboards that Steve Jobs was working on before he died.
Did you mean F-keys, as in function keys? There's usually one key labelled "F-Lock".
Oh gawd, you have a musical keyboard with different sound filters. Is that correct?
May 06, 2012 | E-Machines Computers & Internet
How do you reset change oil/filter in a 2009 nissan murano?
turn the key on but dont start, press the gas pedal 3 times to the floor. shut key off then start as normal
Dec 23, 2011 | Nissan Murano Cars & Trucks
The filter keys on my keyboard are on and i dont know how to turn it off.
hold the shift key down while holding down the filter keys should turn them off
hope this helps
Jun 01, 2011 | Computers & Internet
How to turn off filter keys on a Eee pc and what
Filter keys was introduced by the windows operating system its function is to filter out quick repeated keystrokes.
To toggle filter keys on and off hold the shift button down for eight seconds until you receive a pop up asking if you wish to turn filter keys on/off. In that pop you you will also be given the option to disable the function all together.
Mar 01, 2011 | ASUS Eee PC 900 Notebook
How to remove cabin air filter
2000 and later model the filter is in the passenger side cowl area Turn the ignition key on turn windshield wipers on stop them at the top by turning key off. Open hood aand remove weatherstripping from back of engine compt. at the cowl. Remove the right side air inlet to get to filter
Dec 19, 2010 | 2004 Chevrolet Monte Carlo
How do you check to see if fuel pump went bad on 2004 Nissan Tita
Careful doing this. Disconnect the fuel filter line between the tank and the filter. Have a bucket or equivalent below to catch incomimg gasoline pouring out. Have some one turn the ignition key to on. Do Not Try and turn the key to START!! Just turn the key to the ON position. This will kick in the oil switch to feed gas to the engine for 5 seconds. If gas comes out the pump works. Reconnect the filter and try again. If no start is happening still disconnect the fuel filter's line towards the front of the engine this time. Turn the key ON. If gas comes out the filter is fine. If not the filter is clogged up fully
Jan 24, 2010 | 2004 Nissan Titan
Why am not getting no fuel to the carburetor?The engine turns but doesn't start.
check fuel pump relay, you should hear a click when you turn the key to on, you should hear a whirling sound in gas tank when key is turned on
Oct 04, 2009 | 1993 Chevrolet Lumina APV
1999 sov v8 does not start instantly on key turn instantly
Many newer Jaguar owbers of the 1998 to 2003 models think there's a problem with the ignition because the car sometimes doesn't start on the first turn of the key. You have to turn the key "all the way" to get the ignition fully engaged. I have a 1999 XJ8 and will turn the key part way, then grab it a second time to fully turn it. It's a design flaw because you have to twist your hand really far to get the key turned enough to get the ignition fully engaged.
Jun 20, 2009 | 1998 Jaguar XJ8L
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
