Question about Dryers
How connect GE P938S motor - Dryers
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 169 Answers
Is this the main motor or timer motor?
Posted on Jan 22, 2013
Gentlemen, I have a GE P547BS fan motor.I'm trying to replace it with a Mars 10584 fan motor.
You can check the colors on the wires with an ohm meter to find there function. Highest resistance is low speed lowest resistance is high speed the one left is medium.
Aug 25, 2015 | GE Heating & Cooling
I have a GE Minisplit model AE1C12DBH1 and the fan motor does not work, I would like to know where I can get it or a replacement part?
check for tight connection of motor in pcb and in strip, check for capacitor , if everything found ok then it means motor get blown off , replace it
Oct 12, 2013 | GE Quiet-Aire Ductless Mini Split System...
How to wire a ge 15350 timer for two 120 circuits
1) Copy following links for GE 15350 timer single-pole single-throw 120Volt timer (Made by Tork, same as Tork 1101):
http://waterheatertimer.org/GE-timers-and-manuals.html#15306
2) Use following link to control one 120volt load
http://waterheatertimer.org/images/GE-15306-wiring-250.jpg
2) To control two 120Volt loads:
Use wiring illustration above.
2nd 120V load will have black and white wire, same as 1st 120V load..
Connect 2nd black wire to terminal 2.
Both wires must be same gauge and solid wire. Do not use stranded wire under screw-down plates.
Connect 2nd white wire to terminal X.
Except do not connect more than 2 wires to screw-down terminals. Instead join white wires with wire nut, and then add jumper that connects between wire nut and screw-down terminal.
Jan 17, 2013 | Hardware & Accessories
I had an intermatic 220 timer that died. I am trying ti reconect my wires to a replacement timer from GE. The GE is the 208-277 VAC. On the intermatic there was two red wires connected to the second...
Necessary for you to match up terminal numbering with actual numbers for each timer.
Information below is for 240volt timer controlling one single 240Volt load.
GE15601 has terminals L 1 X 2 from left to right
Intermatic T104 Has terminals A 1 2 3 4 from left to right
Here's the crossover from 240Volt T104 Intermatic to 240Volt GE 15601 for single-240Volt-load
Intermatic terminal 1 connects to GE terminal L
Intermatic terminal 2 connects to GE terminal 2
Intermatic terminal 3 connects to GE terminal 1
Intermatic terminal 4 connects to GE terminal X
Intermatic terminal A is not used in typical 2-wire 240volt circuit.
More links:
http://waterheatertimer.org/GE-timers-and-manuals.html#15601
http://waterheatertimer.org/images/GE-15307-wiring-250.jpg
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
http://waterheatertimer.org/images/T-104-control-240V-Load4-35.jpg
Jul 30, 2011 | RTO Intermatic T106M Timer Mechanism Only...
GE washer WCSE3100A1WW will not spin or drain led light up for spin and drain
check out the DRAIN MOTOR PUMP it could be clogged , its a small motor at the bottom with 2 hoses connected to it , AJ
Nov 20, 2009 | GE WSXH208A Front Load Washer
Hello: I have a ge gsd5500 dishwasher. I want to remove the pump connect which is leaking. Key 455 This connects the pump to the main tub in the middle. How do you remove it? Thanks
Remove dishwasher from under the cabinet. Turn dishwasher on it's side. Loosen the clamp holding the motor/pump from the pump connect. Loosen the clamp holding the motor to the sump. Carefully remove the motor from the sump and pump connect. Turn the rubber connect counterclockwise several turns till it is disconnected from the bottom of the tub. Mine had a small crack right along the top. You needed to bend the connect to see it.
May 12, 2009 | GE 24 in. GSD5500G - Multiple Color...
GE Washer fills but will not run through cycle
Sounds like a bad motor. It's likely shutting off from it's internal thermal switch. Try unplugging the motor's molex connector and replugging it, it could also be a loose connection.
Good luck.
Feb 21, 2009 | GE Washing Machines
GE Washing Machine Replacement Motor - Capacitor? Relay? Schematic?
The new units have all of your schematics, capacitor and a higher price for a reason. With GE I avoid used parts because there is so much electronics you don't want to fry. The wire harness leads match the old and there should not be an extra wire, were would it go if there is not a receptacle for it?
I looked up your unit and the motor replacement is WH20X10009 for the model you quoted. As of now GE is has updated this to model wh20x10006 for around 263 dollars.
Oct 03, 2008 | Washing Machines
General Electric Refrigerator
Check the connection of the electrical harness to the fan motor. If it is fully connected and the motor still does not run replace the fan motor. The fan MUST operate at the same time as the compressor to properly cool the system. Spin the fan blade by hand with he power off. If it turns with any resistance the bearings are dry and in most cases the motor is replaced.
Jun 07, 2008 | GE Refrigerators
GE Monogram Wall Vent zv750SY blower Problems
javascript:launchURL('/IPCNet/Dispatcher?REQUEST=IPCNETGETPDF&file=00000000/00035500/00035520.p01.pdf')
Jan 29, 2008 | GE ZV750SY Kitchen Hood
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
