Question about Acer Aspire One D255-2256 Netbook
My Acer Aspire one D255-2256 is not working
It Will Not Cut On
  • Acer Master
  • 27,725 Answers
If your laptop won't turn on, you could have any number of problems. The problem might be a genuine power issue derived from either battery failure or simply a loose AC adapter. Conversely, it may only appear to be a power failure, and the problem may lie with another component. Errors in brightness settings and LCD display malfunctions can both make a laptop appear to be powered off, and all these problems will need to be corrected. Look at the battery indicator light on your computer. Is it on? If so, check your brightness settings. If your laptop appears that it is not on, it may in actuality have lowered brightness settings. If the brightness setting is at its lowest setting, the laptop screen will be completely dark, and the laptop will appear to be powered off, even though it is not. Try cranking up the brightness settings. Check your AC power adapter. Is it snugly plugged into the wall or surge protector? Make sure the connection is made and it is not loose. Also, try connecting the power adapter into a different wall outlet. Check the status of your laptop battery by considering how long you have had the same battery. Most modern batteries are only good for about 1,000 full charges. After that point, the battery can and eventually will greatly deteriorate. Replace your battery if necessary. Replace your battery by powering off your laptop and then flipping it over and locating the battery cover outline, which will be near the bottom back of your laptop. Remove any screws with a Phillips screwdriver and pop off the battery cover. Slide out the old battery. Put in the new battery by sliding it in until it clicks, and then replace the cover. Consider replacing your laptop monitor. Your laptop may power on, but if the monitor display does not work, it will appear to be off and you will not be able to operate the machine. Check to see if your current LCD display works by plugging your laptop up to an external monitor using a VGA cable. If the external monitor displays your computer contents, your computer motherboard and underlying systems are still working, but your display will need to be replaced. Replace an LCD display by removing the screws around the bezel of your current display with a Phillips screwdriver. Pop off the bezel carefully and remove it. Then, locate the screws on the two metal brackets beneath the bezel and on either side of the display, and remove these too. Disconnect the inverter cable, which is plugged into the inverter. The inverter is located just beneath the display, at the bottom-center of the laptop. Then, pull back and slide out the old display, and replace it with the new. Put the metal bracket screws back in place, reconnect the inverter cable, and then pop the bezel in place. Replace the bezel screws. Hope this helps.
Posted on Jan 22, 2013
What are the key functions on top of my acer aspire 7720
Hi Shawna
From the owners manual for the 7720, (Page 15) all of the functions of the buttons are listed. Just cut and paste this address into your browser.
ftp://ftp.acer.at/notebook/aspire_7720/manual/Aspire_7720G_7720_EN_McAfee.pdf
Hope this helps you out.
-Steve
Apr 02, 2015 | Acer Aspire 7720 Notebook
Internal speed of Acer Aspire One is extremely slow
The problem is that the Aspire One is extremely slow. it was designed to run a Linux operating system not windows. Microsoft just cut down Win 7 to make it work- It just doesn't work well. The only thing that may speed things up is an upgrade to 2GB of RAM. If you already have this then, you will have to live with it. Sorry.
May 02, 2013 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire 3000 Help required to restore to factory
Acer does have a good support team, I think you would be further off getting the recovery disc, it comes with all the drivers eliminating guess work, and it is there if it is needed again.
Apr 01, 2012 | Acer Aspire 3000 Notebook
Owners user guide for Acer Aspire desktop AX1430G
The ACER website lists a "generic" user's guide under this model. Cut and paste this link to your browser to download.
http://global-download.acer.com/GDFiles/Document/Generic%20UG/Generic%20UG_Acer_1.0_A_A.zip?acerid=633795209170291059&Step1=Desktop&Step2=Aspire&Step3=Aspire%20X1430G&OS=721&LC=en&BC=Acer&SC=PA_6
Jan 15, 2012 | Acer Computers & Internet
My acer will not power up ...when I push the power button the light just blinks ....
Have a look on youtube http://www.youtube.com/watch?v=l6GRhsvP-og this video will explain all to cut a longish story short you need to re-flash the bios using a usb flash drive this has worked for mine so follow the instruction on the video carefully and it will work for you good luck (you wont need it) Marc...if the you tube address is wrong search Acer aspire 1 black screen of death
Jan 23, 2010 | Acer Aspire One PC Notebook
Won't power on
Have a look on youtube http://www.youtube.com/watch?v=l6GRhsvP-og thisvideo will explain all to cut a longish story short you need tore-flash the bios using a usb flash drive this has worked for mine sofollow the instruction on the video carefully and it will work for yougood luck (you wont need it) Marc...if the you tube address is wrongsearch Acer aspire 1 black screen of death
Screen is blank when machine is turned on
There is occasionaly a BIOS error that can cause a black screen on the aspire one.
you can find the BIOS update here:
http://support.acer.com/drivers_download.aspx
And you can find flashing instructions here:
http://netbooks-us.custhelp.com/app/answers/detail/a_id/66/session/L3NpZC9nSzRWRzNTag==
Jan 14, 2010 | Acer Aspire One PC Notebook
Aspir 3680 Center button for mouse not working
Go to www.acerpanam.com and download the touchpad driver for the 3680. You will find it listed for xp i think, But it works with vista as well.
Oct 14, 2008 | Acer Aspire 3680 Laptop
Obicam application has stopped working
i think u r using windows vista . and using xp drivers for the cam . go to acer support section and downlaod the latest driver for vista
Jan 22, 2008 | Acer Aspire 3680 Laptop
Acer Aspire One D255-2256 Netbook Logo
59 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
