Question about Kitchen Ranges
Kitchenaid KESC307HWH3 electric range will not heat. I can set the temperature and press start and it clicks like it's on, but it will not heat. No codes are displayed.
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
Look closely at the bake element to see if you see any cracks in it. Does the broiler work? Post back your results.
Posted on Jan 21, 2013
  • 146 Answers
SOURCE: Oven not heating KitchenAid KERC506HWH3
It could be the sensor. Remove the sensor and check for 1 to 1.1K ohms. at room temp. If that's not the problem it may be the oven solenoid on the burner. You can also have a problem with the door lock making when it shouldn't check that also.
Posted on Dec 29, 2007
fridgetech
  • 473 Answers
Need to check and see if you are getting 220 volts to the element or if the element is showing resistance with an ohm meter. Any resistance means it is ok. If you are not getting voltage to the elements and resistance is ok then the control board is bad. Note: Always check outlet for proper voltage first! Never know when a breaker has gone bad. Should have 220 volts from line 1 to line 2 and 110 volts from line 1 or line 2 to ground.
Posted on Nov 16, 2007
vegakitten20
  • 685 Answers
SOURCE: Range will not hold a consistent temperature
here is a site that might be helpfull http://forums.partselect.com/range-repair/index109.html
Posted on Nov 11, 2008
  • 126 Answers
SOURCE: kitchenaid electric range yker1201 with f2e0 error
F2-EO indicatwes a shorted key pad. Electronic parts on ranges sometimes have warranty for five years (may only cover parts) so check your owners manual to see what your warranty is then call for service. It is a good idea to save reciepts of repair for future reference if neccessary.
Posted on Jan 02, 2009
SOURCE: KitchenAid Gas Range Temperature Probe
We had the same problem, and we tricked it into running it's cycle be doing the following;
1. Wrap a wet paper towel around the probe, plug it in, and close the door. Then follow the temp. probe directions in the manual:
2. Set probe temp. at 130 degrees, then select a bake cycle. We selected convect bake.
3. Set oven temp for 275 degrees, but maybe any temp over the probe temp would work.
4. Then start. The cycle took 12 minutes to complete, and when it was finished, turn the oven off and then open the door and unplug the probe.
5. Now everything works fine.
Posted on Jul 04, 2009
Oven shuts down while baking
thermostat my be brokenit thinks its hot so it shuts the heat off....
Apr 21, 2014 | KitchenAid KERS807SSS Electric Kitchen...
KitchenAid Electric Range KERS807 Oven won't do anything, flashes S3E3 code
Do you mean an F3-E3 code? I've never seen a KitchenAid S3 code.
The F3 code means that the oven temperature sensor is bad. The E3 indicates that the sensor indicated an excessively high temp during the clean cycle.
Please determine the full model number of your range to ensure that you get the correct sensor. The sensor costs between $75-80, depending on the vendor. I used the KERS807SSS02 for a guide. www.searspartsdirect.com and http://www.appliancepartspros.com both have the sensor in stock.
If the range is still under warranty, contact KitchenAid for the repair.
I hope this helps.
Apr 30, 2012 | Kitchen Ranges
The oven preheats, but then "cools down" before I
Most likely the problem is your bake element. When the oven is preheating it uses both the bake and the broil element. When it's done preheating it uses only the bake element, so the broil element is heating it up, and since the bake element is not working the temperature drops until it starts preheating again.
Jan 30, 2011 | KitchenAid KERS807SSS Electric Kitchen...
Temperature probe in Kitchenaid YKEMC308 stopped working
4455636 sensor, 4451442 thermostat 4450812 thermostat controller, could be all three, I usually start with the controller over 80% of the time thats it
Nov 30, 2008 | KitchenAid KERC500 Electric Kitchen Range
KitchenAid Electric Range Model KESC307HB56
Electronic control has probably failed.....Self clean on many ovens can be a self destruct mode. Door latch motors, sensor probes and even the electronic controls can be destroyed by this operation. Suggest oven cleaner method next time.
Jun 12, 2008 | KitchenAid KESC307 Electric Kitchen Range
Wiring hookup for a replacement part
hopefull yyou havent disconnect old switch yet. whirpool and kit aid are same Co. same parts used. assuming the correct part was sent for the corrrect burner. diffrerent element will require different rated swties(ie. small , large, dual and so forth.), the indivudal switches are labeled, on the swithc itself ( L1,L2,H1 H2, P1 andso forth, so although the switches looke differnet they should stil have the same lettered terminal to plug into .
Mar 15, 2008 | KitchenAid KESC307 Electric Kitchen Range
KitchenAid superbra range KGST307
I am not a repair man or anything, just an owner with the same gas range slidein appliance. What we have found to work was 1) plug in the probe into the socket in the oven 2) Turn on oven with the probe set at the minimum 160 degrees. and oven temperature to 325 degrees. 3) click start 4) wait for oven to reach probe temperature. 5) oven will then beep show end 6) Click cancel 7) open door and remove probe. 8) wait five minutes before trying to use again. I hope this helps you it has work for us so far. 6)
Aug 27, 2007 | KitchenAid KGST307 Gas Kitchen Range
Kitchen Ranges Logo
62 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
