Televison & Video Logo
Larry wills Posted on Jan 21, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No power Worked for awhile, then quite with a bussing sound
DENNIS MITCHELL
Level 3:
Genius:
  • Master 1,003 Answers
  • Posted on Jan 21, 2013
DENNIS MITCHELL
Master
Level 3:
Genius:
Answers
1003
Questions
0
Helped
367421
Points
2185
REPLACE THE POWER SUPPLY BOARD OR LOOK FOR BLOWN Bulging CAPACITOR ON POWER SUPPLY HAVE IT REPLACED.
1helpful
My Goodman AC is model WMC24-1. Two years ago it quit responding to the remote control. We bought a replacement B1100108. That worked...for awhile.
Make sure the sun is not directly on the unit and nothing is blocking the unit. for once in awhile if the sun hits it just right when you try to use the remote it will not work.that seems to me what is wrong for spring time the sun is real low
Liftmaster 41a5483b quits working wile in motion. then it might go if you hit the button then stop agian. might go up then down and stop.
Might try lubricating the tracks and moving parts. Sounds like the motor is shutting down for thermal protection.
1helpful
My machine will not work. It makes a clunking sound when I try to run it. What is wrong?
it could be the timing, or it mght need a adjustment, or could have
a loose or broken part,, it would be a good idea to have the
machine serviced
All my zynga games freeze, want download..ect.. they used to but haven't in quite awhile.
Hiya honeybee, the same has happened to me when i click into zynga games try deleting your cookies it worked for me hope it helps kind regards
1helpful
Every time i start my car up, my kenwood DDX-514 loses control of the subs and the audio reverts to default settings. i have to press restart every time i crank the car up. the shop that installed it...
There should be a keep alive connection that has 100% power to the radio.
If you are tied to the accessory buss, that power is interrupted during starting to avoid damage due to spikes from the starter.
To fix, tie this connection to 100% power but use a FILTER to prevent damage to the radio by the starter.
RCA PROJECTION
This this sounds a bad flyback (a common problem with this type of tv) this part is a high voltage holder so if you never worked with type of fix do not do it yourself!
Soundcard problems
I'd say to look at latency settings and sample rates. also disable screen savers and power management.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
