Question about Kenmore Dryers
Haeting element on a kenmore model 76722
I am trying to see how a new element is installed, i had back surgery and i need to know which friend to help me with it
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 169 Answers
Who diagnosed the problem? It seems to me if they could diagnose it they should be able to install a new one?
Posted on Jan 22, 2013
aborcass
  • 2651 Answers
SOURCE: Tumbler doesn't rotate for Kenmore 76722 Gas Dryer
soulnds like the belt pooped, or broke, remove top you should see the belt wrapped around the drum, if not you need a new one
Posted on Feb 23, 2008
  • 1028 Answers
SOURCE: replacing Kenmore dryer parts
that one is old enough to vote..if filter on top remove back find small hole on right just below top may be hidden by pasted on tech sheet..through hole insert long socket 5/16 or reach up from underneath with short ratchet and socket remove screws and attached wires lift element housing up slightly and pull bottom of housing out and down..5/16 screw on backside holdes element in
Posted on Jun 19, 2008
  • 113 Answers
SOURCE: Getting the heating element casing back on to the back of a Kenmore elite dryer Model#11063942101
there are slots in the casing that slide down on tabs comeing out of the dryer. put the top part of the casing in then put the bottom part in and slide down on the tabs
Posted on Apr 23, 2009
Controlfrk
  • 304 Answers
SOURCE: I'm trying to install a new heating element to my
Replace screws at rear exactly as they were. Entrance for this dryer is at the lower front panel.
Unplug unit first. Place a putty knife in the space between the upper and lower panel at the front of the dryer about 4 inches in from either side to push up the retaining clips while pulling on the panel. This will release the lower panel and give you full access to all the main components.
The heater is on the right in the metal can with the cover at the front. On the left side of the can is a thermal fuse that may be open to turn off the heater. There is also a thermostat that may be bad or interconnecting wiring. Remove cover at the front of the can and disconnect wires to element.Element should slide out for replacement. Look for screws retaining it if it doesn't.
Reverse above process for reassembly. Good Luck.
Posted on Sep 11, 2009
heatman101
  • 43501 Answers
SOURCE: kenmore dryer will not tumble model/stock# 76722693
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Aug 05, 2011
Kenmore Gas Dryer does not dry clothes.
If this is the electric version then after 15 years you probably need a new heating element, they are not difficult to install and are not terribly expensive as a DIY project.
Jan 12, 2013 | Dryers
Kenmore dryer will not tumble model/stock# 76722693 76722 serial # MG710437
heatman101
Aug 03, 2011 | Kenmore Dryers
ICE FORMS ON FLOOR OF FREEZER SIDE OF KENMORE MODEL 53206201 REF. DOES THIS INDICATE HEATER NO.2188174 IS FAULTY. I HAVE THE NEW PART BUT DONT KNOW HOW TO INSTALL IT. I HAVE REMOVED THE COVER IN THE BACK...
Don't know this model specifically, but this can also occur from a bad door seal letting room air in. Check all the way around both doors before major surgery!
Feb 18, 2011 | Refrigerators
Gas dryer not maintaining heat. 70 Series Kenmore/Whirlpool 76722
Fuse is ok . Problem is the soils on the burner valve . If the dryer heats when started , the electricity goes thru the coils to open the valve . Once the coils get warm , 1 will open (short) until it cools back down . The coils can be replaced just by removing the front panel . Only 2 screws hold the coils in place . No turning off gas , dissasembling dryer .
Jul 14, 2009 | Whirlpool Dryers
No heat
Hello Friend, Your problem is very simple to fix. You need a thermal fuse and or heater element, both very simple and affordable to replace. Try replacing the thermal fuse first to see if that's the problem. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. If this don't solve your problem you will need to replace the heater element. To replace the heater element, with the back cover off of your dryer just look down and to the right of were the air blows out. You will see the electric heating unit with two fat red wires plugged into it. Unplug these wires and you will see on the sheetmetal housing two screws that hold it on, one on each side. On older elctric dryers there is only one screw that holds element in place, it is on the bottom center of element screwed in from behind. Remove screw(s) and remove old heater element. Now, lay the new element next to the old one and take notice that there is a heat sensor attached to the old element where one of the red wires unplugged from. Gently remove this sensor and install it onto the new element in the same location as the old one. If you have an older electric dryer, the old heater element doesn't have the heat sensor on it, just skip this step. Now, plug in your two red wires and re-install your heater element. Your dryer will run like new. Happy to help, Tim.
Apr 21, 2009 | Kenmore 62802 Electric Dryer
Kenmore 110.62602100 runs but no heat
the thermostat is normally located at the bottom rear of the dryer near the haeting element they are easy to change but some stats have a reset button on it if it needs reseting it will click when pushed
Nov 11, 2008 | Whirlpool LGR7646E Dryer
970-686133 Bake and Broil Element not working
Typically what happens on on these models, when the bake element breaks, it sends a surge back to the oven control (or clock) and causes it to fail also. Sounds like this is what has happened here. If the overlay (touchpad) is a separate piece, you will need to buy it also. Let me know if you have any questions.
Feb 25, 2008 | Kenmore 95680 / 95681 / 95682 / 95684...
Feb 21, 2008 | Dryers
Kenmore 76722 it won't light
could be a broken ignitor i would need more details. also the thermistor might need to be changed thats a more common issue
Nov 13, 2006 | Kenmore 76832 Dryer
Dryers Logo
52 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
