Ip address unknown
TP-Link gives good signal
  • 7,627 Answers
If you need your IP address, Try this: http://whatismyipaddress.com/
Posted on Jan 23, 2013
ayamaya
  • 143 Answers
SOURCE: cant get internet on ps3
make sure that the ip address that you are getting is a valid one and you are connected to the correct wireless network. for example, if your router's ip address id 192.168.1.1, your computer should have an ip address of 192.168.1.x. if you are getting a valid ip address and you're still getting the dns error, the thing that you can do is set a static ip address and dns to your ps3.
if you don't know the dns to use, go to the command prompt and type ipconfig/all and it'll give you a list that'll contain the dns servers. copy the dns and enter it on the ip settings of your ps3 together with the default gateway (ip address of the router), subnet mask (it's usually 255.255.255.0) and your ip address (make sure that the ip address that you'll set on the ps3 is not being used by any of your computers)
hope this'll help you and just ask me if your still having any problem
ciao!
Posted on Jul 07, 2008
beeveez
  • 167 Answers
SOURCE: My D-Link DI-614 Router is issuing ip strange DHCP ip addresses
Hi Todd, try uploading the latest of your router to fix the issue.
Posted on Mar 15, 2009
  • 145 Answers
SOURCE: Have D-Link G604T router/modem and want to connect
Dear,
I think this will help you http://www.tp-link.com/support/showfaq.asp?id=151
Posted on Oct 17, 2009
  • 1768 Answers
SOURCE: How do I set D-link DIR-615 router to issue IP
You will need to visit the D-Link and check the virtual videos to help you set up the D-link for static addresses. this is what you will need to do.
Posted on May 31, 2010
shademand
  • 114 Answers
SOURCE: I'm using TP-LINK TD-W8101G ADSL
Unfortunately, you can't use two routers together in that manner. You must have a device in between them such as a switch or bridge or you'll have to disable the DHCP server settings in the second router. The second router then pretty much becomes a switch you may then use all the ports on the second router with the exception of the WAN port it must remain unoccupied. However, if you need wireless connectivity in another location far away from your main router then your only solution would be to indeed purchase an actual access point/bridge device
Posted on Sep 06, 2011
Cell phone not connecting to TP-wa5210g
A "repeater" cannot give an IP address only pass the request back to the main router. You could set a fixed IP in the phone but that would screw it when away from your router.
Something is going wrong with DHCP requests passed through your repeater. Check the settings.
Apr 13, 2014 | Computers & Internet
Connect mifi
Open internet option's or "create homegroup" option on your pc and enable your pc to become an access point. Doing so will allow the pc to share the wifi with any compatible device. The handset cannot find the IP due to a firewall so turning those off manually would also work but do so only as a last resort.
Apr 03, 2014 | TP-LINK Computers & Internet
How i can change ip address of tp link 5210g throw ethernet cable
ok , need to assign your computer a Static IP address within the same
range as the AP's IP address, ip address of AP is : 192.168.1.254
the ip address for pc such: 192.168.1.253, then open your browser and write the ip address of your AP then you will be inside it .
Jan 10, 2014 | TP-LINK TPLink TLWA5210G 24GHz High Power...
Does a Ethernet Switch(Unmanaged) have a default IP address?
There is a user guide on the tp-link web site. It looks as if this is just a layer-2 switch (ethernet) and there is no user configuration to enter. The IP addresses would come from another device on your LAN. A router or a server that supports layer-3 (IP) would issue addresses by running a DHCP server process on it.
Nov 02, 2013 | TP-LINK TL-SF1008D 8-Port Ethernet Switch
I have a TP LINK router, it transmit signal properly. the problem is when the 3G USB internet modem is fixed into it, it does not send internet signal so the laptop shows TP Link signal: excellent, but no...
To solve your problem:
go here
http://www.tp-link.com/us/article/?faqid=92
Basically what you have done is plugged it in but did not set up the router on a static or dynamic IP address.
Once you have established the IP address of the router and it is recognized by your ISP device (DSL, Cable, Satellite modem ....etc etc.) then you have to decide which device will be the DNS server and assign IP address to all the wireless devices that connect to it.
Lots of things can be wrong. You need to follow the steps on the set up link i gave you properly and in the correct order
Oct 23, 2013 | Computers & Internet
No light only power light is on...
First, did you pay the bill? Unplug the IPS modem, remove battery, if applicable, unplug TP Link, shut down computer. Ckeck ALL cables reseat, Replace battery, plug in ISP modem, allow it to selftest, plug in TP Link, allow it to selftest, Reboot computer. If you connect ISP Modem directly to PC and it doesn't ID your IP address use this: http://helpdeskgeek.com/networking/release-and-renew-an-ip-address/ To assist you. If this doesn't work contact your ISP provider . Try another Wireless Access Point. My ISP, Xfinity, drops from time to time , for no appearent reason, due to a number of outside difficulties.
Dec 14, 2012 | TP-LINK TPLink Tp link Tl wr940n 300mbps...
Possible ip conflict
Sounds more like a bad ethernet cable or bad port on the Iomega. Try using a different cable
Jul 20, 2017 | Iomega 1TB Home Media Network Hard Drive...
TL-WR940N
Hello
I can give some details on port forwarding for TL-WR940n. You could follow this procedure given below. here is the link too. http://www.tp-link.com/en/article/?id=72
How do I open ports on my TP-LINK wireless Router?
Suitable for: 300Mbps Wireless N Routers, 150Mbps Wireless N Routers, 54Mbps Wireless G Routers
Step 1 Open the web browser and type the IP address of the router (default is 192.168.1.1 or 192.168.0.1) into the address bar and then Press Enter.
Step 2 Type the username and password in the login page, the default username and password both are admin.
Step 3 Click Forwarding->Virtual Servers on the left side, and then click Add New... button.
Step 4 Type the Service port which you want to open and the IP Address of your computer; Select Protocol to TCP, UDP or ALL; Change Status to Enabled
Step 5 Click Save button to save the settings.
Note:
If you want to open port 80 for Web server in your computer, the Management port of the router will be changed to 8080, you need to type Http://192.168.1.1:8080 to connect to you router.
TP-Link_SupportForce
TP-Link USA Corporation
Tel: +1 866-225-8139
E-Mail: steve.crow@tp-link.com
Website: www.tp-link.com/en/support/index.asp
Jun 08, 2012 | TP-LINK TPLink Tp link Tl wr940n 300mbps...
I have installed my new TP-link wn350GD and installed the driver included but stilll i cant connect to the internet. i tried updating to a latest driver but nothing happens.. It actually detects wireless...
in your network connection, there is an Internet protocol(tcp/ip) double click it. put in obtain ip address automatically. same in dns server then ok.
If not work, configure it manually by using your laptop copy the ip addresses in your laptop, including subnet mask, and defualt gateway, and put it to your pc..
hope it can help you.
Dec 16, 2010 | TP-LINK TP link TL-WN350GD 54 / PCI / 11...
Tp link wireless router Ethernet not working
Make sure the TCP/IP settings on the PC's LAN gets an IP address automatically, don't use a fixed IP address.
Apr 21, 2009 | Computers & Internet
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
