Question about Hotpoint (HSM25IFTSA) Side by Side Refrigerator
Water despencer does not get cold water
Hot point model no. h5m25gftasa s.n. dl234560
  • 65 Answers
The first glass of water may be warmer depending on size due to the tubing that runs under the warm underside of the refrigerator. if you run a couple glasses and it is still warm, then I would check your refrigerator tempurature as that is where the water resevoir is located.
Posted on Jan 27, 2009
Water running thrugh is cold
Make? Model?
General check points.
Are you getting hot water to the faucet?
If set to hot only is there water flow? What happens if the temp is set to cold only? Warm? Hot?
Oct 02, 2016 | Washing Machines
Got cold water in cold water tap but no water in hot water tap
It sounds like a hot water heater issue. At the top of the heater, there are two pipes - one brings in cold water; the other sends hot water to the house. Some heaters have a valve on one of those pipes. The valve would be controlled by a large handle that either points straight out from the pipe or points in the same direction of the water pipe. If points straight out, that means it is off. Pull the handle so it is pointing the same direction as the pipe. Note: handle only moves one direction and can be hard to move. If won't move one way, try the other.
May 21, 2014 | Vehicle Parts & Accessories
Hot water is very slow coming out spout. Cold water comes out fine with good pressure..
the anti scald is adjusted too low. its located under/behind the handle. it usually has am allen wrench head. remove the handle and adjust it all the all the way to hot that should fix it. on some models you can remove the entire thing,but on some that will cause the handle turn 360deg because in some models its also the stopping point of the handle. hope this helps
Dec 11, 2012 | Jacuzzi Home
I have a Hot Point refrigerator model No. HSS25GFTA WW. I changed the filter but water still not coming out of the despencer, every thing else is working normal.
Sometimes you will need to purge the air out of the line after changing the filter. Just hold down the water dispenser for a few seconds every hour or so.
Jan 30, 2012 | Hotpoint HSS25GFT 25.0 Cu. Ft....
HOT POINT SIDE BY SIDE ICE MAKER IS PRODUCING ICE BUT IT WILL NOT DESPENCE ICE OR WARTER
If you press the botton for ice or water do you hear anything? If not the switches could be out or your fountain assembly may be bad. Check to see if you hear noise. You can even wiggle the arm to see if it activates.
If you need further assistance or have questions please feel free to comment me back.
Jul 27, 2011 | Hotpoint Refrigerators
Help my washer wont fill with cold water
they are one unit but before you replace be sure have ckd the screen inside the cold side of the valve if screen is clean and no hum from valve on cold setting change the valve..i don't think sears would even charge more than 200 and probably less
Aug 10, 2008 | Frigidaire Washing Machines
Does Not Rinse
Check each temperature during initial wash fill. Set to hot water, is hot water coming out? Set to cold water, is cold water coming out? The rinse cycle is cold only. If cold water is not working machine will just stop at rinse.
If cold water not working:
Disconnect cold water hose from machine. Inspect the filter screen on the cold water connection. DO NOT REMOVE SCREEN. If full of debris, use a spray bottle with a hard spray to remove debris. If unable to remove or cold is still not working, replace valve.
Jun 14, 2008 | Whirlpool LSR6332K Top Load Washer
Ice despencer won't make ice any more
Is it the despencer or the icemaker which thing showing the problem makes a difference to giving you info on the repair.
Jan 31, 2008 | Whirlpool GS6NBEXR Side by Side...
Avanti water cooler
check the switch at back if it is working, check the motor compresor touch the top of the motor comp, if working, the possible problem is the freon, touch the condenser at the back of the unit if hot the freon is working, if no hot, load a freon, ok
Sep 28, 2007 | Avanti (WDE79BSS)
Hotpoint (HSM25IFTSA) Side by Side Refrigerator Logo
75 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
