Question about Dell Vostro Computers & Internet
When i insert memory card in my dell vostro i can not edit any documents in memory card it is showing "write protected", how can i solve this problem
  • Dell Master
  • 27,725 Answers
You have to be the computers administrator to change any values on any hard drive on your computer click start control panel user accounts on the users tab click the name of the computer administrator you must have full control click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7 click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
if you need more help with this post a reply
Hope this helps.
Posted on Jan 21, 2013
3 Suggested Answers
  • 24 Answers
SOURCE: Dell Vostro V1015. Asset Tag:
Please got to device manager (Right click on my computer>properties>hardware tab).
lookout for sound,video game controllers, Enlarge it and look for the sub options. look if there is any red x or yellow exclamation on any drivers . If red x give a right click and enable it. If it's yellow exclamation or no symbol on the driver. give a right click and uninstall the drivers .Once uninstalled click on tools on the left top and scan for hardware changes.
Posted on Aug 25, 2011
bronk50
  • 27725 Answers
SOURCE: dvd keeps saying insert a disc
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver You might have to physically unplug the leads for this cd/dvd computer then plug them back in restart your this should activate the found new hardware wizard. If this does not fix the problem it might be a registry problem "you only need to do the following" if you cant see your disk drive in windows explorer Close all open programs Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. if this fails to fix the problem
It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it Hope this helps.
Posted on Jan 20, 2013
Dell Vostro 3300 lagging with Intel HD Video card
Turn off built in video and add a better card. See the minimum graphics specs for software. The video memory is shared on those Intel cards. Meaning that 4GB RAM is not totally available. The OS is going to use 1-1.5gb for running the system, then 256 (.25 gb) for the video. Means that a max of 1.75gb is available to run the game. You should have at least 8gb min. in a modern system. Especially if Win7 to Win10.
BTW: 4gb is good for surfing, or writing documents, but when you get into gaming ware - the pc spends most of its time using the swap file, (source of lag, since HD is 1000x slower than ram). So it stops the game to write, stops the game to read back aka LAG.
Jun 27, 2016 | Dell Vostro 3300 Notebook
How to remove write protection
IF you are mentioning about a memory card.Please check on the side of the card there will be small movable stuff..Just pull it to remove write lock
Apr 20, 2013 | Dell Vostro 1015 Laptop
Vostro 3500 memory card reader doesn't work
Download and reinstall the card reader driver.
Get onlineand got to www.google.com In the google search box type: "DellSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Card Reader drivers.
May 12, 2012 | Dell Vostro 3500 Laptop Computer (Intel...
Memory card jiot to computer but its not open then say pls insert ur disk.what is the reason?and how is it solve problem?
look at page "3/9" of this document "http://www.pqi.com.tw/upload/download/SD%20%284%29.pdf" and it will show on
the lower right hand side of the picture a slot that says "write protect", move that tab towards the pins to unlock the card.
BTW this is a good technical document for SD cards in general if you are interested in how they function.
Feb 22, 2011 | PNY 2GB microSD Memory Card
I insert a sd/mmc card in the slotwhich is same as
Sounds like the drivers might be missing which is why there is no response.
Depending on which operating system your running on the laptop will determine what file you download.
Go to this page:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=VOS_N_1500&os=WLH&osl=en&catid=&impid=
Choose your operating system, either XP or Vista and then under where it says chipset choose Ricoh Driver and download now. choose download by internet browser. Save it to the desktop if possible and then run the file so it installs.
If you go thru installing the drivrr and the card is still not being read by the laptop then the motherboard is bad.
Aug 22, 2009 | Dell Vostro 1500 Notebook
How do i install a sandisk to my dell pc?
i had a dell 2400 to and there is NO memory card reader in it...you have to get a card reader or a usb adapter for it
Jun 08, 2009 | SanDisk 4GB microSDHC Memory Card
I cant copy song in memory card its shows card is write protected
What sort of memory card is it?  can you remove it and install it in a card reader directly on your pc?  What is trhe phone?
Jan 14, 2009 | Motorola Mobility ROKR E6 Smartphone
My sony ericsson W200i mobile is not taking m2 card.
i think your memory card is breaked somewhere
pls check it with your naked eye in bright light
and if problem still not solved try to clean the slot with some thin cloth and also clean the m2 card
reinsert it and if problem not solved try to contact your nearest service centre of sony ericcson
Nov 16, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Computers & Internet Logo
mukhtar21 shaikh
mukhtar21 shaikh
