Question about Kitchen Ranges
I have a Kitchenaid KESC307HWH3 range. There was a loud pop inside the oven and now it won't heat. I can set the temperature and press start and it clicks like it's starting, but it won'
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
You blew the relay inside the oven and it will need to be replaced. Here is the part to order. Here is a diagram of the unit. The relay is number 30 on the diagram.
Posted on Jan 21, 2013
aborcass
  • 2651 Answers
SOURCE: oven temperature adjustment
well no need to fret, if you oven is heating over 100 degress off theres problably not an adjusatment to compensate for that, youll need to either replace the htermostat or the thermistor, depending on which your machin uses
Posted on Jan 20, 2009
  • 146 Answers
SOURCE: Oven not heating KitchenAid KERC506HWH3
It could be the sensor. Remove the sensor and check for 1 to 1.1K ohms. at room temp. If that's not the problem it may be the oven solenoid on the burner. You can also have a problem with the door lock making when it shouldn't check that also.
Posted on Dec 29, 2007
SOURCE: Kitchenaid Superba Gas Range - Oven temperature problem
The problem is: the temp seems to be 'stuck' at 260 and will not allow any higher settings.
Calling KitchenAid proved to be unuseful. The manual did not have this item in the troubleshooting pages. Resetting the power does not help.
The SOLUTION:
There is really no problem besides that the temp display setting has been somehow set to be celsius (metric system) rather than farhenheit (english system). Changing this setting somehow can be easily touched off without knowing, thus the "I didn't do anything and yesterday it was working fine..." comment from family members.
The FIX:
Reset the temp display back to farhenheit (F). This is done by opening the oven door, then hold down the 'Broil' button until you hear a beep from the control panel. The same method may be used to change from Farhenheit back to Celsius.
Prevention:
I speculate the inavertent change of the temp setting is done while cleaning the flat control panel. So the best thing to do is to always 'LOCK' the control panel when cleaning the controls. This is done by holding down the keypad "3/lock" for a few seconds until the display shows LOCK.
(The solution was already posted when I arrived at this page. I just organized it a bit by adding some details and a preventative comment. Many thanks to those who posted earlier, solving my issue as well. I hope my writing presents a clearer and quicker read to the next person)
Posted on Aug 28, 2009
SOURCE: I have a Tappan gas range.
how do you replace igniter?
Posted on Nov 25, 2009
SOURCE: Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
i dont know want is wrong with it when i turn the oven on it keeps saying e2 and f3 i dont know what that mean please help me one on .... :(
Posted on Nov 28, 2009
Oven shuts down while baking
thermostat my be brokenit thinks its hot so it shuts the heat off....
Apr 21, 2014 | KitchenAid KERS807SSS Electric Kitchen...
Kitchenaid KESC307HWH3 electric range will not heat. I can set the temperature and press start and it clicks like it's on, but it will not heat. No codes are displayed.
Look closely at the bake element to see if you see any cracks in it. Does the broiler work? Post back your results.
Jan 21, 2013 | Kitchen Ranges
Oven won't heat
You might have to unplug it let it set for a hour then plug it back in and it might set it self.
Dec 31, 2012 | KitchenAid Kitchen Ranges
KitchenAid KGSC308LSS Gas Kitchen Range OVEN won't heat up
Does the igniter in the oven glow white hot when it tries to start?
Dec 20, 2012 | KitchenAid KGSC308LSS Gas Kitchen Range
KitchenAid Electric Range KERS807 Oven won't do anything, flashes S3E3 code
Do you mean an F3-E3 code? I've never seen a KitchenAid S3 code.
The F3 code means that the oven temperature sensor is bad. The E3 indicates that the sensor indicated an excessively high temp during the clean cycle.
Please determine the full model number of your range to ensure that you get the correct sensor. The sensor costs between $75-80, depending on the vendor. I used the KERS807SSS02 for a guide. www.searspartsdirect.com and http://www.appliancepartspros.com both have the sensor in stock.
If the range is still under warranty, contact KitchenAid for the repair.
I hope this helps.
Apr 30, 2012 | Kitchen Ranges
Lower oven element won't heat
check the oven compartment sensor that actuating the oven temperature
Apr 26, 2012 | Dacor Preference RSD30 Gas Kitchen Range
The temperature in my oven is not accurate.... If I set it for 350, it pre-heats and then buzzes [to let me know it's reached temp]....but the temperature is NOT 350; rather, it is at 275 [I have a...
Your oven's manual should tell you how to adjust this. The manual should also have a trubleshooting chart. Also remember, your temperature sensor may be going bad and will need to be replaced. For now, you can set the temperature 75 degrees higher to get the correct temperature you need.
Sep 15, 2011 | Whirlpool Electric Range
WHAT I NEED TO DO TO MAKE OVEN HEAT UP
can you see the glow inside the bottom of the oven?if you can then your bake ignitor may be bad.
Nov 05, 2008 | Frigidaire FEF355 Electric Kitchen Range
KitchenAid superbra range KGST307
I am not a repair man or anything, just an owner with the same gas range slidein appliance. What we have found to work was 1) plug in the probe into the socket in the oven 2) Turn on oven with the probe set at the minimum 160 degrees. and oven temperature to 325 degrees. 3) click start 4) wait for oven to reach probe temperature. 5) oven will then beep show end 6) Click cancel 7) open door and remove probe. 8) wait five minutes before trying to use again. I hope this helps you it has work for us so far. 6)
Aug 27, 2007 | KitchenAid KGST307 Gas Kitchen Range
Kitchen Ranges Logo
174 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
