How to install router netgearwnr2000
Installing
  • 826 Answers
Step1: Plug the Netgear WNR2000 adapter into a wall plug. Connect an Ethernet wire into the yellow Ethernet port on the back of the Netgear router. Attach the other end of the wire to the Ethernet slot on the returning of your modem.
Step2: Insert the set up CD that was involved with the Netgear WNR2000 into your pc's cd drive. Simply select the language option you want to use and then click "Setup".
Step3: Follow the set up wizard's on-screen guidelines and then click "Finish". The wizard will automatically detect your Internet settings. Open a web browser and type "192.168.0.1" into the address bar and press Enter.
Step4: Type your username and password in the appropriate fields for login the panel. Click "OK".
Step5: Click "Yes" and wait for the newest firmware update to set up. Double-click the update file and adhere to the on-screen guidelines to set up the update.
Step6: Click the "Wireless Settings" link if you want to code secure your wireless network system. Simply select the "WEP" option and then type password which you want to use for your system in the "Passphrase" written text box.
Step7: Click "Apply" and then close the web internet browser.
If you need any kind of technical assistance you can contact support cell at here
Posted on Jan 22, 2013
ADMIN.PASSWORD CONFIGURATION
turn the router upsidedown and default password is on the bottom and i think user name is admin and passwor is(password)
Oct 27, 2012 | NetGear WGR614 Wireless Router
Nstallation cd is missing for DIR-600...Hello, If you don't have the installation disc anymore, you can...
open the setup page of the router and change the settings manually.
Like other routers, you can install wireless router without installation CD also,
Read how to setup router without installation CD
Jul 04, 2012 | D-Link DIR-600 Router
Wrt120bn wireless router cd installation
Are you trying to setup Linksys router?
You can run the installation CD to setup Linksys router or you can do it without installation CD also.
Connect the computer to the router with the Ethernet cable.
Open the setup page of the router.
Change the Internet connection settings.
Create a new wireless network.
Connect to the network.
I will suggest you a website that you can try to setup your Linksys wireless router without installation CD.
May 21, 2012 | Linksys Wireless-G WRT54G Router
I lost my belkin installation cd
You do not need the installation CD to use the router. Check this link to download the user manual and quick install manual. As well you can download an updated firmware for your router along with installation instructions.
Good Luck.
May 06, 2011 | Belkin F5D8236-4 Router
How to instal
You'll wanna check out: ftp://downloads.netgear.com/files/WNR1000_SM_WW_23Jan09.pdf
Look for "installation"..
To help you set up your router and get on the Internet quickly, the Resource CD contains a Smart Wizard™ Installation Assistant. The Installation Assistant walks you through the steps required to connect your router, modem, and PC(s); configure your wireless settings; and enable wireless security for your network. When you have finished, you will be Internet ready!
You can set up your wireless router using one of two methods:
• Smart Wizard Setup: The Smart Wizard Installation Assistant setup is available on your Resource CD. See "Installing Your Router Using the Smart Wizard" on page 9 to use the Smart Wizard Installation Assistant.
- This is the easiest option. The wizard guides you through the setup process. It automates many of the steps and verifies that the steps have been successfully completed.
- Smart Wizard requires a PC running Microsoft Windows.
• Manual Setup: If you cannot or prefer not to use the Smart Wizard Installation Assistant, see "Manually Installing Your Router" on page 13. For example, if you are connecting to a Mac, are using a Linux operating system, or are technically knowledgeable, select this option. If you choose to use this option and install your router manually, for best results, install and set up your router in this order:
Failure to follow these guidelines can result in significant performance degradation or an inability to wirelessly connect to the Internet.
NETGEAR does not recommend or support adding a NETGEAR router behind another router, or replacing a gateway with a a NETGEAR router.
If you have a Macintosh or Linux system, you must use the manual installation method (see "Manually Installing Your Router" on page 13).Getting to Know Your Wireless Router 7
1. Install and connect your wireless router to your network (see "Connecting Your Wireless Router" on page 14).
2. Set up your wireless router for Internet access (see "Setting Up Your Router for Internet Access" on page 18).
3. Configure your wireless network and select wireless security settings to protect your wireless network (see "Configuring Your Wireless Network" on page 21)
Feb 04, 2011 | NetGear WNR1000 Router
I have DI-604 in line between Windows Vista computer and cable modem. Works fine. Bought DIR-615 (wireless). Several places instructions say, ""Insert the DIR-615 CD into computer and click Install Router....
Contrary to the many warnings not to install the router before starting the installation with the CD, I got the installation to complete only AFTER I installed the router inline thusly:
1. Power everything off.
2. Remove DI-604.
2. Install and connect 615 router to computer and to modem.
3. Apply power to router and modem.
4. Apply power to computer and wait until Windows loads.
5. Insert 615 installation CD.
6. Follow the directions.
Nov 22, 2009 | D-Link DIR-615 Wireless Router
I cant install a router
If you are installing the router between your ISPs modem and your PC, first you will need a ethernet network adpater that installs in your PC, you will need two crossover ethernet cables, one to install between the modem and the router and one between your network adapter and the router, once the cables are connected, turn everything on, first your ISPs modem, then the router and then the PC, once the PC is up, insert the CD that came with the router and follow its instructions and that should work!
Apr 03, 2009 | Linksys WRT54G2 Wireless Router
Installation software
Don't worry the router does not have a driver. Just run the network wizard in windows. And set up a new connection you will see.
Oct 06, 2008 | Belkin (F5D7230-4) Router (587009)
How do I install a netgear adsl modem router dg834gt
no you can't use the belkin usb 10/100 ethernet adapter CD to install the netgear adsl modem.
click here to download the installation manual for the netgear device
Sep 09, 2008 | NetGear DG834G Router
Computers & Internet Logo
David Payne
David Payne
