Question about Dell Latitude D800 Notebook
Tooland task bars shrunk along with text.
I am writing to apologize. I asked about a problem with the size of my tool and task bars along wih my text on my dell d800.
The solution one of your experts told me to do was actually correct. I just didn't apply it correctly.
I am sincerely sorry.
Enlarge text size
Create Menu tab right click in the top of screen (toolbar) you will see a number of toolbar options select the menu bar
This will add to your screen toolbar File Edit View Favorites Tools and Help select the View from the drop down list will be a Zoom with percentages % and text sizes largest to smallest and Full screen option
Increase the Font Size in Email
Email font size is easily controlled while composing messages, but the messages you receive have been sized by the sender.
Some contacts may be perfectly comfortable writing in size 8, but such text can be a strain on the eyes, even with good reading glasses.
The printed hard copies of email messages with small text are even more difficult to read.
There are a few ways to quickly change font size for ease of reading and better quality print-outs.
Open an email message with particularly small text. Increase the email font size of the text using step 2, 3 or 4.
Click on the "View" selection from the menu bar.
Roll the mouse pointer over the "Zoom" choice.
Click on one of the choices that is greater than 100 percent.
Click "View" and cover "Zoom" to make a larger choice if the first choice does not increase the text size sufficiently.
Click the "View" option on the menu bar. Roll the cursor over the "Text Size" selection.
Choose one of the options that will increase the text size.
For instance, if the current size marked with the dot is "Medium," then click "Larger" or "Largest" to make the print appear bigger.
Use a mouse with a wheel to increase the email font size.
Press and hold the "Ctrl" key while rolling the wheel on the mouse.
The text will shrink as you roll in one direction, and grow bigger as you roll in the other.
Change font size before printing.
Click the "File" option on the menu bar.
Click "Print Preview."
Click the "Size" drop down which may display "100%," or "Shrink to fit."
Select a choice greater than 100 percent to increase text size.
Click the "Print" button to view the results on a hard copy.
Nov 13, 2013 | Computers & Internet
Gmail problems
in the upper left of your screen you'll see "File" "Edit" "View". Click on "View" A drop down bar will appear. Check That 'Zoom' is at 100% and 'Text Size' is at medium or large.
Nov 12, 2013 | Computers & Internet
Text too small
This can be changed from display settings if you are talking about the text on the desktop ..Just click right on the desktop ..choose properties and select the last in the right ...settings ..here you can select a smaller resolution ..(best for 17 inc is 10024 /768 )and click apply and OK ..
if you do not want to change the resolution but need larger icons and text ..just select on the same window advanced..and you will have the possibility to increase the icon and text size with the percent you want ...After that click apply and OK to exit ..It may ask to restart for to apply the changes..
if you are talking about the writing in the browser..you can zoom it by changing resolution ..or by pressing down the ctrl button and scroll up or down ..
Also all text size can be selected manually for each location if you click right on desktop and in the window select appearance (second in the right 0 and advanced..This advanced feature will allow you to select the size color and font size for each item ...one by one ..icons...space between them ..for title and menu bars..etc.
But , I suggest not to mess with that ..cause you may not be able to manage it well ..just engage a smaller resolution and will solve the issue for the writing .
Nov 20, 2011 | Microsoft Windows XP Home Edition
How to get the task bar to it natural size?
It is possible to make the task bar taller than it is by default, and this is the only way that I know of to change the size of the task bar, so I have to assume that you are asking how to take the task bar back down to the original "tallness." You would put your mouse cursor at the top of the task bar until it turns into a double-headed arrow, and then click down and drag the top edge toward the bottom of the screen until it is the normal height. If the task bar is locked, this cannot be done, so make sure it is unlocked by right-clicking on an empty spot on the task bar and make sure that "lock task bar" is not checked first.
Jun 10, 2011 | Microsoft Windows XP Professional Full...
Print is to small i need it to be larger but i dont know how!
Open the document you are trying to print
Look at the top tools bar
Take the cursor and place it over the writing on the document
The type of font and size should appear in the boxes on the tools bar
If you want to make them bigger
Highlight all of the text which is to be enlarged
Go to the box and select which Font you require ie Times New Roman
Go to the next box and select the Font Size ie 12
That will make the writing bigger and will come out of the printer at that size
Jun 07, 2009 | Dell Inkjet 720 Printer
Taskbar is hidden by about an inch of coloured vertical lines!
Left click on the top edge of the Task bar and hold it doen, and drag it down to resize the task bar to the size you want then release the left botton.
Apr 05, 2009 | Compaq Computers & Internet
Tool, task bar and text miniaturized
right click on task bar... select properties... should be in there
Robert
Jan 21, 2009 | Dell Latitude D800 Notebook
Tool, taskbars and text all shrunk to half normal size
Did you try Control Panel and Display, Setting tab and adjusting the resolution by moving the slider? That should take care of it.
Jan 17, 2009 | Dell Latitude D800 Notebook
Tool and task bars shrunk along with size of type
try changing to a lower resolution... that should make your icons bigger and more of what you're used to.
Jan 16, 2009 | Dell Latitude D800 Notebook
Taskbar gone crazy on win xp pro sp2
YOu have either a Display Driver problem or the Display Chips itself. try downloading the latest version of display driver if does not fix the problem you need to get your onboard vga repaired.
good luck.
compexaustralia@yahoo.com.au
Dec 05, 2007 | IBM ThinkPad T41 Notebook
Dell Latitude D800 Notebook Logo
44 people viewed this question
Alun Cox
