Question about Kenmore Kitchen Ranges
Change from natl gas to propane - Kenmore Kitchen Ranges
Change the oriface which can be purchased at any hardware store
Posted on Jan 21, 2013
I had a natural gas furnace installed in place of a propane gas furnace. will this cause my rollout switch to trip constantly. my fuel source is propane. gas valve on furnace wasn't change to propane
If it has a position for natural gas/propane then it needs to be changed to the position that the gas source is either propane or natural gas..
Nov 22, 2015 | Heating & Cooling
Instuctions on how to change a pitco fryer from nat gas to propane
Hi there!
You need to order a gas valve conversion kit (from nat to propane), propane pilot orifice and propane burner orifice,
Gas valve conversion kit consists of a replacement spring thicker than of natural gas valve spring, gas valve cap and a sticker.
Pilot orifice for propane has smaller bore than of natural.
Burner orifice for propane has also smaller bore than of natural burner orifice (one for each burner).
You will be able to find these parts on the list of Pitco Distributor when you visit http://www.pitco.com
Regards.
Jul 08, 2012 | Pitco Frialator E24 Deep Fryer
I have a small counter top fryer set up for lp gas how do i change to nat
check the supplier for the conversion kit.the kit contains burner orifice, pilot orifice and gas valve spring which are commonly needed for conversion from propane to natural gas or from natural gas to propane.
****natural gas orifice has larger bore than propane, gas valve spring for propane is thicker than for natural gas.
Mar 29, 2011 | Cecilware FMS-40 Deep Fryer
How to change a weber natural gas grill to propane
According to Weber, "There is no conversion kit available to convert any Weber gas grill from one gas type to another. Any attempts to do it will void your warranty."
Sorry, but if it's any consolation, Propane Gas burns cleaner and hotter that Natural Gas in an outdoor environment. Which translates into faster preheating and hotter searing temperatures.
Hop e this helps and happy Grilling!!
Mar 19, 2011 | Weber SUMMIT S-620 Propane Grill
Converion kit to natural gas.
I don't believe Weber makes a gas conversion kit for your model grill. I say this, because your model grill comes two ways, Natural Gas or Propane. This indicates to me, that there's more than just changing the burner orifices involved.
I can tell you this ... If you could convert it to Natural Gas, you would soon discover that the grill doesn't preheat as fast as with propane. Nor, will it maintain heat as well as propane, in an outdoor environment. Propane burns cleaner and hotter than Natural Gas in an outdoor environment.
Sure, it may seem like a hassle to refill and change the tank, but I can assure you, you won't be satisfied with it's performance.
Feb 03, 2011 | Weber Spirit? E-310 Propane Grill
Whirlpool model SF385PEEQ0 Gas stove was on Natural gas we have propane is there an adj or part needed as burns yellow flame!
You need to adapt your range for the propane gas. You need to change the orifices, propane needs a larger opening than natural gas. If you contact your propane company they can help you and some will even do it as a free service (or used to).
Jun 18, 2010 | Whirlpool SF325 Gas Kitchen Range
I DO NOT HAVE NATURAL GAS AVAILAABLE WHERE I LIVE/
You can order an LP conversion kit to change it over to propane. Most kits cost between 30 and 60 dollars, and require you to take the drum out of the dryer to access the gas valve for the change over.
May 07, 2010 | Kenmore 73952 Gas Dryer
Switched from natural gas to propane now oven flames up sides how do I fix? Model#362.75571691
Propane and natural gas are two different fuels and require adjustments to the appliances to which theye are connected. Typically, when converting to propane from natural gas, a pressure regulator and a change in gas jets are required. This is because propane has a different heating value (hotter) and behaves differently.
Also, propane doesn't burn as cleanly as natural gas so after you have made the hardware changes, if you start to smell something in the kitchen, you may need to crack a window slightly to provide for better venting.
Please be careful
Jan 01, 2010 | Kenmore Kitchen Ranges
Maytag Range Model MGR5870 how to convert to propane
set the regulator to propane and change the orfices to the blk ones. copper is for nat gas / black for propane .. thanks hope this helped .mm
Dec 22, 2009 | Maytag MGS5870 Gas Kitchen Range
Kitchen Ranges Logo
35 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
