Question about Dryers
Drive belt replacement
What is the path for the new belt? There is too much slack
  • Old Folky Jan 21, 2013
    Thanks. The videos were helpful, up to a point. I found the answer here:http://www.fixya.com/support/t6135957-ne...
    Novelist:
  • 200 Answers
Here is a general video, that may help you, you can look up your specific model if this video does not help. http://www.youtube.com/watch?v=rtATa0a28bE&feature=youtube_gdata_player
Posted on Jan 21, 2013
Replacement of serpentine belt on a 2005 Ford five hundred
The actual serpentine belt does not affect timing. There should be a belt path sticker label under the hood. There is a spring tension pulley which can have a fitting cast on it for a racket or breaker bar drive. This is used as a handle, but on some units a firm hand can press on this tension pulley to provide slack for the belt to slip off and be replaced. Check Youtube for videos on this subject.
Jan 18, 2017 | Ford Cars & Trucks
Cutting blades not engaging when lever is pushed to engage.
First make sure that you have the right belt. If you have the right belt for your model then you have laced it wrong on the wheels. You will have to get a diagram of your belt path and redo it.
Apr 05, 2016 | Garden
How to replace fan belt on a Mitsubishi pajero
Instructions
  1. 1 Open the bonnet of the Pajero, and turn the bolt on the centre of the tension pulley with a socket wrench two full rotations. The tension pulley is the pulley directly behind the fan in the upper portion of the front of the engine.
  2. 2 Loosen the adjuster bolt on the tension pulley bracket. This bolt is on the left-hand side, situated in a long horizontal groove.
  3. 3 Slip the fan belt off of the engine. Draw a diagram of the path of the fan belt if the factory printed sticker diagram is no longer in the front of your engine on your Pajero.
  4. 4 Insert the new fan belt, winding it through the various pulleys according to your diagram. Put it on the tensioner pulley last.
  5. 5 Place the tension belt tool on the tension pulley bolt and pull until the slack in the belt is gone. When there is no slack, keep the pressure on the pulley, and tighten the adjuster bolt with the wrench. Tighten the lock bolt on the pulley.
Jun 17, 2015 | 2006 Mitsubishi Pajero 3.2
How to replace drive belt
Unplug it from the electrical outlet.
Remove the back panel.
Look for the "idler-wheel" -- it takes-up the "slack" between the drive-motor and the rotating tumbler.
Loosen it, to put enough "slack" in the drive-belt that the drive-belt can be removed.
Take the belt to a dryer-service store, and get them to match it.
Connect the new belt to the drive-motor and the tumbler.
Adjust the "idler-wheel" to take-up the slack.
Replace the back-panel.
Add power.
May 31, 2015 | Asko T712C Dryer
How do i put back on a pulley belt on a 93 continental
Follow the path on the label you find about belt routing. There is 1 arm with a pulley and it is spring loaded. Some people take digital photos before removing the belt and use them as a guide.
There is a shape on the pulley arm to fit a 1/2 breaker bar or wrench. Press against the spring tension to get slack to slip off the belt. Then slip the new belt around the same path leaving the easiest accessible pulley for last. Then slip the belt over the last pulley and restore the tension.
Feb 10, 2014 | 1993 Lincoln Continental
How to tension the BMW x5 4.4i 2003 serpentine belt
All BMWs use a spring loaded tensioner. if you are having trouble with the tension then you need to find /use the correct belt path. If you are having trouble getting the belt on the tensioner, then use a section of the old belt to tug the new belt onto the Alt. pulley.
The tensioner that is on the BMW 4.4L M104 motor is found near the idle pulley and can be locked into the slacked position with a 1/4" thick bolt that has the threads ground off also the tensioner can be operated with a 3/8 drive ratchet. Apply tension to this pulley after getting the belt wrapped around the other pulleys and then fit it over the Alt. pulley last.
May 24, 2011 | 2003 BMW 5 Series
Belt slips on bolens riding mower has new belt
there is a belt which drives the deck/blades, and another belt which transfers power to the transmission to move the mower. you do not specify which belt, but as they both have a tensioner, you need to locate the pulley which removes the slack from the belt and replace it and the spring which provides the tension. you had to release this tension in order to install the belt so you know exactly where it is. oftentimes a close examination will reveal that the belt was not put back on correctly. if it was slipping already, you replaced the belt and it is no better then replace the tension spring. if it was working fine and the belt broke due to wear and now it is a new belt and slipping i would closely examine the path of the belt all the way around and make sure it is in right. often times there are small dowel shaped steel keepers and guides which are supposed to hold the belt in but the belt has inadvertently been routed around them which makes it slip.
good luck
Apr 13, 2011 | Garden
Can't put the serpentine belt back on has to much slack
You have it routed the wrong way, there should be a routing diagram under the hood
Apr 04, 2010 | 2000 Jeep Cherokee
I HAVE A BAD ALTERNATOR AND KNOW i HAVE TO TAKE IT OFF AND REPLACE IT WHERE DO i START.
Removing the Old Alternator Step1 Pull your Mazda into the garage or your work area. Turn the car off and let it sit for a while to cool. Step2 Begin by disconnecting the negative cable of the battery. Step3 Remove the serpentine belt from the pulley on the alternator. Do this by using a socket wrench to turn the serpentine automatic belt tensioner so that it allows slack in the belt. Then simply slip the belt off the alternator pulley. Step4 Locate and disconnect all the mounting bolts on the alternator, use a vehicle specific manual if you have any trouble. Step5 Disconnect all wires attached to the alternator then remove the alternator from the Mazda. Installing the New Alternator Step1 Slide the new alternator into place. Do not worry about the serpentine belt yet. Step2 Replace the bolts that held the previous alternator to secure the new one in place. Step3 Attach the wires to the new alternator the same way they were attached to the old one. Step4 Adjust the serpentine belt tensioner the same direction you did in Section One to put slack in the belt. Wrap the belt around the pulley of the new alternator and then remove the socket wrench from the automatic belt tensioner. Step5 Inspect the belt to be sure it is not snug and follows the path required in the pulley and belt configuration diagram. Step6 Hook the negative battery wire back to the negative terminal on the battery.
Mar 21, 2009 | 2004 Mazda Tribute
Dryers Logo
29 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
